telford dorr Samba Member
Joined: March 11, 2009 Posts: 3556 Location: San Diego (Encinitas)
Posted: Fri Apr 06, 2018 9:02 am Post subject: Re: Fuel gauge sender |
You could also try repairing your OG sender:
bay forum link, website link (available 9am-9pm pacific time). _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14323 Location: Casa de Oro, California
Posted: Fri Apr 06, 2018 10:06 am Post subject: Re: Fuel gauge sender |
Yes, exactly all ^^^that. Talked to a guy there super knowledgeable and they can get them custom made at an affiliate shop.
Another boring pic of the top after removing the sticker.
Waterborn Samba Member
Joined: July 18, 2018 Posts: 179 Location: Ft Lauderdale, FL - USA
Posted: Sun Aug 19, 2018 12:26 pm Post subject: Re: Fuel gauge sender |
Been having issues with the gas gauge on my '64 splittie panel van and found this thread while searching the split bus forums. The gauge never bumps off of approximately 3/8 full, regardless if the tank is close to empty or just filled to the brim. The guy I bought the vehicle from said he remembers having an issue with the gauge about 18 months ago and that he "fiddled with the wires" to get it working. I would prefer a more technical solution to the issue
So is it likely that my issue is a bad sender, a faulty gauge or something else?
Also, while checking the wiring on the gauge I pulled it out of the dash and the white rubber o-ring that holds it in place disintegrated. What is the best place to find a replacement for this ring? right now the gauge is really loose in its socket and I would like to secure it. |
PeteSC Samba Member
Posted: Thu Dec 06, 2018 1:01 pm Post subject: Re: Fuel gauge sender |
Just thought I'd share this since it appears the e-gauges.com website seems to no longer work as a source for genuine VDO tube senders.
Jegs now carries the 190mm length VDO sender that should work in most split buses.
https://www.jegs.com/i/VDO/918/224-219/10002/-1 |
oldbusboy Samba Member
Joined: June 25, 2006 Posts: 604 Location: Bowen Island, BC Canada
Posted: Sun Dec 09, 2018 1:06 pm Post subject: Re: Fuel gauge sender |
Thanks PeteSC.
I was looking for a replacement for my faulty sender.
Trevor _________________ 1968 porsche |
Posted: Sun Dec 09, 2018 2:03 pm Post subject: Re: Fuel gauge sender |
Also need to get a new sender. Thanks for the link! |
greenboat4 Samba Member
Joined: April 04, 2014 Posts: 81 Location: Fort Myers
Posted: Wed Feb 06, 2019 6:54 pm Post subject: Re: Fuel gauge sender |
Hello;.
How is the VDO unit from JEGS working for you all. |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
velvetgreen Samba Member
Posted: Wed Feb 20, 2019 10:58 am Post subject: Re: Fuel gauge sender |
^^ thanks Evan if anyone has purchased one of these would be happy to hear some feedback! |
easy e Samba Member
Posted: Wed Feb 20, 2019 11:37 am Post subject: Re: Fuel gauge sender |
I tried & it said my bank stopped the transaction during checkout... incomplete purchase.
Either my bank stopped it... or the site is just collecting personal data. _________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12418 Location: Over 2002 posts deleted!
Posted: Wed Feb 20, 2019 12:31 pm Post subject: Re: Fuel gauge sender |
Hijack!
Sender schmender! How do I check if the gauge is good and/or the sender!
The gauge in the bus I’m working on just quit working! The tank and sender are new. _________________ Some people are so busy being clever they don't have time enough to be wise. |
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2230 Location: UK (South)
Posted: Wed Feb 20, 2019 2:05 pm Post subject: Re: Fuel gauge sender |
pyrOman wrote: |
Hijack!
The gauge in the bus I’m working on just quit working! The tank and sender are new. |
Could you bypass the sender and connect a variable resistor (potentiometer) in its place? I'd expect that dialling the pot up and down should make the needle move up and down if the gauge is working. If so, I'd suspect the sender or a short circuit somewhere. _________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
easy e Samba Member
Posted: Wed Feb 20, 2019 2:20 pm Post subject: Re: Fuel gauge sender |
Who.Me? wrote: |
pyrOman wrote: |
Hijack!
Could you bypass the sender and connect a variable resistor (potentiometer) in its place? I'd expect that dialling the pot up and down should make the needle move up and down if the gauge is working. If so, I'd suspect the sender or a short circuit somewhere. |
No fancy tools required.
Just hook it up to the correct voltage battery.
If it pegs to FULL... it’s good. _________________ aka: Evan
teahead Samba Member
Joined: October 30, 2019 Posts: 326 Location: Seattle
Posted: Wed Jun 24, 2020 3:12 pm Post subject: Re: Fuel gauge sender |
pyrOman wrote: |
Hijack!
Gauge ground wire to the sender...hook it up straight to ground. Does the needle move? _________________ '63 German Walk-Thru Deluxe 15-window - SOLD |
PeteSC Samba Member
BIG_TEXAS_PETE Samba Member
Posted: Thu Jun 25, 2020 8:26 am Post subject: Re: Fuel gauge sender |
I took mine out and took it apart, soaked it in citric acid for a few days with some cleaning and agitating, did the same with the inside of the tank. Tested it and put it back together. It was totally gunked up and stuck. Looked great when it was cleaned. Depends if you can be bothered.
The sender is just a float moving up and down two wires. you can test it when it's apart out of the tank.
_________________ https://www.instagram.com/big_texas_pete/ |
Posted: Sun Jul 18, 2021 4:00 pm Post subject: Re: Fuel gauge sender |
just order a Wolfsburg west one hope its good. |
noshorts_us Samba Member
Joined: October 06, 2009 Posts: 9 Location: valley stream
Posted: Sun Apr 28, 2024 6:58 pm Post subject: Re: Fuel gauge sender |
I have a 1975 Brazilian split it has a tube style fuel sending unit it kept giving me grief I sense replaced it with a 68 to 79 Beetle Fuel sender I tested it right out of the box. My bus gage is now reading correctly. |
mdege Samba Member
Joined: January 16, 2018 Posts: 947 Location: Niederkruechten, Germany
Posted: Sun Apr 28, 2024 11:15 pm Post subject: Re: Fuel gauge sender |
I gave up on the VDO sending units. The old one corroded over the years and the new Brazilian VDO unit was crap from day one.
But there is an alternative from VDO Kienzle for maritime applications. It works great with very little tweaking. You need to adapt the cabling and since the resistance value is a little off you need a 430 ohm resistor in parallel to get a full scale reading on your stock fuel gauge.
The sender itself is fully capsuled and made of stainless steel. Therefore you will not have the corrosion problem anymore even if the car sits for years.
At least in Europe the price of the unit is lower, than what you pay for the Brazilian crap.
https://kienzle-shop.de/marine-zubehoer/sensoren/t...ich-90-4-o _________________ - Michael
1963 Typ3 Notchback project
1988 Multivan Magnum 112i
1984 Standard: My son wanted a bug for his first car |
