luftgekuhlt Samba Member
Posted: Tue Jun 01, 2021 12:46 pm Post subject: Best buy 30/31 PICT1 carburetor |
in my 1600 industrial engine I have a non og Solex 30/31 PICT1 that I am not so happy with, difficult to regulate.
What is the best buy if I want to buy an og carb, the real thing?
Thanks in advance for all tips. _________________ Buy the best. Cry once.
1965* 21W Samba (MCode 430 114) - 51 BD Standard Microbus (Type 22A. M62) - 1967 Westfalia pop-top (SOLD)
* 1965 according to chassie number but regged as 1964 |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5395 Location: Good Hope, GA
Posted: Tue Jun 01, 2021 4:01 pm Post subject: Re: Best buy 30/31 PICT1 carburettor |
German. The Brosol ones are ok. _________________ -'85 c10 5.3 LS, cam, heads, long tubes, x pipe, 3 inch spin tech's
-'01 e46 325ci *tree modded
'65 Tourist Delivery Build
'66 RIP |
earthquake Samba Member
Joined: January 10, 2008 Posts: 4001 Location: SANDY VALLEY, NEVADA
Posted: Wed Jun 02, 2021 10:17 pm Post subject: Re: Best buy 30/31 PICT1 carburettor |
I thought a 34 PICT 3 would fit on the same manifold as a 30/31? wouldn't that be a better carb?
eQ _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
Posted: Thu Jun 03, 2021 6:29 am Post subject: Re: Best buy 30/31 PICT1 carburettor |
30/31 needs an adapter for a 1600 manifold. A 34 pict 3 is correct and a bolt on. _________________ -'85 c10 5.3 LS, cam, heads, long tubes, x pipe, 3 inch spin tech's
'66 RIP |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33200 Location: Hot Arizona
Posted: Thu Jun 03, 2021 7:34 am Post subject: Re: Best buy 30/31 PICT1 carburettor |
Chickensoup wrote: |
30/31 needs an adapter for a 1600 manifold. A 34 pict 3 is correct and a bolt on. |
A 30/31 fits directly on 1600ccsingle port manifold, but needs the adapter for a 1600cc dual port manifold.
I run a 30/31 on with an adapter on my own 1600cc DP engine, and it works fine. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Mon Jun 14, 2021 3:37 am Post subject: Re: Best buy 30/31 PICT1 carburettor |
Cusser wrote: |
I run a 30/31 on with an adapter on my own 1600cc DP engine, and it works fine. |
That's correct I have a 1600cc industrial engine single port and the 30/31 fits directly. _________________ Buy the best. Cry once.
Posted: Mon Jun 14, 2021 3:48 am Post subject: Re: Best buy 30/31 PICT1 carburetor |
Has anyone links to an original GERMAN 30/31 PICT carburator?
(The brand Brosol itself sounds brazilian to me)
Confusing: the german ebay searching for Brosol 30/31 I get brazilian made carburators.
Thanks for all tips: which is the best buy if I need an original german 30/31 PICT carburator.
Also how to tell if it is og german or copy (my mechanic saw it after a 1 second glance)
This is from the german ebay, a brazilian Brosol 30/31
https://www.ebay.de/sch/i.html?_from=R40&_trks...p;_sacat=0
This Brosol states clearly Made in Brazil:
https://www.ebay.de/itm/153963576031?epid=20021303570&hash=item23d8f1badf:g:gFIAAOSwAbBe3Sjr _________________ Buy the best. Cry once.
Posted: Tue Jun 15, 2021 1:19 am Post subject: Re: Best buy 30/31 PICT1 carburetor |
I wonder now that I am searching an og carb:
Mine is PICT with no number after. What's the difference between:
PICT
PICT 1
PICT 2
PICT 3
can any of them substitute my PICT ? _________________ Buy the best. Cry once.
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 4109 Location: Seattle, WA
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3999 Location: Antioch, California, a block from the hood
Posted: Wed Jun 16, 2021 12:31 am Post subject: Re: Best buy 30/31 PICT1 carburetor |
Lingwendil wrote: |
There was never a German production 30/31. Only 28, 30, 31, and 34. The Brosol H30/31 is a new world thing and never shipped on a German volkswagen engine.
A single port industrial 1600 should have had a 30PICT on it, exact variants vary by engine number and original application. It has 200 hours as pump and 2 summers on the bus and very few miles |
Cool information! Thanks
The 1968 industrial 1600 engine hails from the swiss army and I bought it with the complete fire brigade water pump. It had a magneto + distributor in one piece for constant rpm and a Solex 32 PCI carb.
They were replaced with the non og Euromax Solex 30/31 PICT (no number) and a Bosch distributor JUR 4 - 0 231 137 020 - VW 111 905 205 T (all brand new)
The combo worked perfectly for 2 years until it no longer did. I mean, it works, but requires frequent carb adjustment.
Is it possible with this information to know which exact carb the engine shoiuld have or is the engine number necessary? _________________ Buy the best. Cry once.
Posted: Wed Jun 16, 2021 6:16 am Post subject: Re: Best buy 30/31 PICT1 carburetor |
Was there something wrong with the 32pci? If not I would personally keep using it
Also, I like the H30/31 a lot, personally. If it worked before it probably just needs a rebuild and a good cleaning.
I know some industrial engines had some oddball carbs but I'm not terribly familiar with all the variants.
What's the current application for the engine? If it's a simple setup in a beetle or similar a good used 30pict3 should be a good carb. _________________ 73 super beetle thread http://www.thesamba.com/vw/forum/viewtopic.php?t=649622 Back on the Road!
Modify your Kadrons for SVDA http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
Cast iron VJU4BR8 SVDA reference thread- https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Need replacement filters for original Kadron aircleaners? WIX #42087 is a perfect fit, as is Napa Gold #2087! |
Posted: Wed Jun 16, 2021 6:25 am Post subject: Re: Best buy 30/31 PICT1 carburetor |
Lingwendil wrote: |
What's the current application for the engine? If it's a simple setup in a beetle or similar a good used 30pict3 should be a good carb. |
Exactly, simple setup however in a 64 split bus.
Thanks, will try the 30pict3
PS: still don't understand the difference pict/pict1/pict2/pict3 _________________ Buy the best. Cry once.
Posted: Thu Jun 17, 2021 6:39 am Post subject: Re: Best buy 30/31 PICT1 carburetor |
Lingwendil wrote: |
I have found in my shelfs a 30pict2 would it fly?
I can see that:
30PICT/1, /2 a single adjusting screw in the left side
30PICT/3 and H30/31 two adjusting screws in the left side _________________ Buy the best. Cry once.
Posted: Sat Jul 03, 2021 1:43 am Post subject: Re: Best buy 30/31 PICT1 carburetor |
OK.
I have changed the carb and here is how it went:
OLD CARB BROSOL SOLEX 30/31 PICT
bought brand new for 2 years ago
When tuned took 5-6 turns of the start motor for the engine to start
Otherwise worked very well, powerful, cold or warm.
When warm engine took a little longer to start 7-8 turns
Had to tune it every 2-3 months the tunings didn't last long
My mechanic says it couldn't regulate the air flow very well
no play or wear on this carb
2 tuning screws on left side
NEW CARB ORIGINAL GERMAN 30 PICT 2
50 years old carb that was laying on a shelf for 10 years
very good condition
cleaned it and installed, the difference is huge!
nothing else changed or tuned in the engine
starts with a light touch of the starting key, cold or warm
it seems to be a little more economic and thus gives a little less power
thus when engine is cold, gears must be changed carefully until warm
after 10-12 minutes driving it flows like a dream
very nice quiet idling almost impossible to hear
one tuning screw on left side _________________ Buy the best. Cry once.
