bobbylardo Samba Member
Posted: Wed Mar 30, 2005 3:42 pm Post subject: Ball joints |
I have a 71 type I. I was wondering what the best method for replacing Ball joints. Is that something you can do at home, or does it require a machine to press them in? |
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Wed Mar 30, 2005 3:56 pm Post subject: |
Glenn has a pic of a tool that does it on the car... specifically made for Bugs, but there is a generic type out that you can rent from some parts stores and get it done, just the "cups" don't come pre sized for VW only ball joints so you have to use what comes in the kit until you get the right configuration.
Other option is to remove the arms from the car and have a shop press them out and new ones in on a hydraulic press, or send off for arms that have new ones pressed in and exchange yours. |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79445 Location: Sneaking up behind you
Posted: Wed Mar 30, 2005 4:22 pm Post subject: |
If you don't have the correct tool, it's a bitch to replace. You can also get rebuilt trailing arms with new ball joints alreay installed if you can get tehm replaced.
This one was sold by OTC. Matco also made a tool.
_________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Wed Mar 30, 2005 5:26 pm Post subject: |
Thanks guy for replying. I am going to rent the tool from the automotive place down the road. I'll test out the different configurations on the rent-a-tool and if it doesn't work I'll bring it to a machine shop. |
Posted: Wed Mar 30, 2005 5:37 pm Post subject: |
If you look at Glenn's pic you can see the cups and ram are specific to the application... you may find that you can get the "cups" out of the one you rent to work just fine but you may have to improvise and use some strong pipe or even 1/2 " impact sockets or ? you come up with for the more slender looking bits in his tool kit.
and be aware that the joints press in one way and have 2 "tangs" on them that need to line up correct so the joint can move in the right direction.
If you take them to a shop be sure to point that out too as many a set has been ruined by being pressed in by someone unfamiliar with the orientation of the joints. |
Posted: Wed Mar 30, 2005 6:04 pm Post subject: |
Thanks keif, I was not aware of the "tangs". I think i would be very angry if the set was ruined. It takes to long to gets parts. |
Posted: Wed Mar 30, 2005 8:52 pm Post subject: |
Tang's/ "notches" different terms for some folks, just look and you will see what I am referring to. Also another tip... sometimes it is best to remove the "sprial ring" that holds the boot on an press the joints in then re -install the boot and ring. It can keep you from damaging the boot and you can pack the joint with a finger full of grease... they come with surprisingly little lube in them. |
Spanky Samba Member
Joined: June 24, 2005 Posts: 82 Location: Martha's Vineyard MA and Cincinnati OH
Posted: Sun Jul 29, 2007 10:01 am Post subject: |
keifernet wrote: |
Hey Keifer!
My Bentley shows a tapered CONE used to cover the rubber boot as you slide the ring up the cone it slips off the end of the cone onto the neck of the boot. Do you have a tip on mounting that ring on the boot without damaging it (or do you have one of those CONES?
Spanky _________________ 1959 Renault Caravelle
1973 Citroen Maseratti SM
1974 Chevy Malibu Wagon
1979 Vespa Scooters (2), 1981 BMW R65
'73 Thingy. |
uberautowerks Samba Member
Joined: October 17, 2005 Posts: 1600 Location: Longmont Co
Posted: Sun Jul 29, 2007 10:07 am Post subject: |
Take the boots off, reinstall after! No worries about damage during installation. _________________ --- The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at and repair.
- Douglas Adams -
'74 Thing (White)
'71 Single cab (White too)
'70 Weekender (White three)
'05 Evolution VIII (White also!!!)
'68 F-250 (White over black) |
Posted: Sun Jul 29, 2007 10:52 am Post subject: |
Spanky wrote: |
keifernet wrote: |
Hey Keifer!
Spanky |
I have used the plastic cone that comes on most ball joints to aid in reinstalling the wire spring... but they are not that hard to get back on if your careful with just two small thin flat blade screwdrivers or scribe type tool... |
