seanj Samba Member
Posted: Sun Oct 08, 2006 9:23 pm Post subject: 85 westy leaky head gasket |
thinking about picking up an 85 westy that leaks a few drops of coolant of coolant only when it's cold outside and the van has been sitting. other than that the engine has be rebuilt about 35k miles ago and runs strong. no rust no dents all camping goodies work fine, canvas is good, interior is good. seems to be a nice van all around except for the slight coolant leak. i've owned several veedubs in the past, mainly aircooled westies so i need to know how big of a deal this is and what else to look for. thanks |
r39o Samba Polizei
Posted: Mon Oct 09, 2006 7:51 am Post subject: |
Find out about the magic Subaru blue leak sealer in a bottle.
Read my signature about SEARCHing.... _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
Terry Kay Banned
Posted: Mon Oct 09, 2006 8:10 am Post subject: |
There is no miracle in a bottle---
With any sealer you take a chance of plugging up two heater core's, plus pluging up what may be left open in an antique, original radiator.
Replacing the head seal would be the right way to go, and if you use GM gasket adhesive ( pt.# 1234 6141 ) on that new head seal, it'll never leak again.
Do the job once--do it right. _________________ T.K. |
Cat and Walter Samba Member
Joined: June 17, 2006 Posts: 244 Location: Soutern Utah
Posted: Mon Oct 09, 2006 8:12 am Post subject: |
Terry Kay wrote: |
Do the job once--do it right. |
No kidding on the gm stuff? is it a proven thing? |
r39o Samba Polizei
Posted: Mon Oct 09, 2006 8:17 am Post subject: |
Terry Kay wrote: |
Please note, I did not say to use it. Just find out about it. If it is truly just a minor leak that happens when it is cold, something other than a total head job on an old (anemic even when new) 1.9 may do the trick. The person should go read about it. They should make up their own mind. It may not even be the head gasket.
I certainly am not suggesting to go drop a can of Bars Leak in. What I am saying is to investigate it. I will not go into the plus and minus points. I will not say of success with the stuff. The reader needs to decide for themselves.
That's all. _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
Terry Kay Banned
Posted: Mon Oct 09, 2006 8:26 am Post subject: |
Honest Injun.
My best buddy is the master mechanic at Roger's Chevrolet in Rantoul IL.
He turned me onto the gasket adhesive 10 years ago--
All of the newer GM engines have no gaskets---none.
They used this product to replace them all.
I've used it on 35 or better head gasket jobs, and haven't had one come back.
It works well--Much better than the VW issue head seal sealer. _________________ T.K. |
Terry Kay Banned
Posted: Mon Oct 09, 2006 8:43 am Post subject: |
<<is truly just a minor leak that happens when it is cold, something other than a total head job on an old (anemic even when new) 1.9 may do the trick.>>
The key words here were " when It gets cold"
You'll find out that when an aluminum water cooled VW flat 4 starts dripping from the head area, when it gets cold outside, your dealing with contraction of the aluminum.
And if the water jacket seal is weak or poor, it's gonna leak at that area.
Investigating the Subaru coolant system sealer is suggesting me to use it if you don't want to do the job right in the first place.
If you wern't thinking about using it--why suggest looking at it?
Whatever--
Wait for the genie in the bottle to appear--she may offer a short term miracle on them head seal's, and in the interm plug up the heater core's and radiator.
Good idea. _________________ T.K. |
r39o Samba Polizei
Posted: Mon Oct 09, 2006 8:59 am Post subject: |
Terry Kay wrote: |
Whatever-- |
Over the decades I have learned to consider new ways of dealing with things. An example is the Timesert. Another is to refresh the coolant in the Vanagon every year or so with a phosphate free one.
Also, I listen to what others have to say about a particular specific thing. One needs then to make up ones own mind about a particular thing or solution.
Terry Kay wrote: |
Good idea. |
Perhaps and perhaps not. I do not know, But doing a SEARCH on the topic might reveal some insights. In this area there may just be a new trick an old dog can learn.
As an aside I do have an old crappy $100 van I may try it on. I may just use it as a donor for spare parts and cores too. I don't know.
My point is, that until you evaluate something and get some real world data, one simply should not dismiss something because of what one thinks might happen. _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
Terry Kay Banned
Posted: Mon Oct 09, 2006 2:10 pm Post subject: |
<<Over the decades I have learned to consider new ways of dealing with things.Another is to refresh the coolant in the Vanagon every year or so with a phosphate free one.>>
Now this is the most intellegent thing I've seen posted on this forum in a long time.
And if you change the coolant regardless what flavor it's in ( the VW phosphate free goo is good for the tree hugger's --that's all--if you don't change it on a regular basis , it'll do the same electroletical damage to aluminum as the green ethyelene glycol coolant)
The head seals and the cooling sytem components will last forever.
How many folks actually take the time & energy to do this?
Not too many.
And this is exactly why the heads get pitted and the seals fail on a regular basis.
<<Also, I listen to what others have to say about a particular specific thing. One needs then to make up ones own mind about a particular thing or solution.>>
Sure--why not?
And much like the paid advertising on the boob tube--thousands of folks use that wax that you can light on fire on the hood of your vehicle--and not damage the paint.
Must be good stuff.
It said so on the internet too---
Thousands of folks gave live testimonies on the benifits of Prolong & Extend oil treatment's in their engines oil.
Hell, Al Unser Jr. told me on the TV that I could drain my oil and take my car out for hot laps without causing any damage to my engine--he's a pretty smart guy--he must be telling the truth.
I gotta get me some of that stuff.
Did you know that almost every item in the Warshawsky's ( aka JC Whitney ) catalog , be it a curb feeler's , to the dancing Hula Girls on your dash board will give you 15% better fuel economy?
They must be telling the truth--it's a national publihed catalog--and they most certainly woud lie about anything like this--
I wonder what the blue dot's for my tail lights will give me for extended fuel mileage?
So, read all the hype you can--especially from the manufacture of the product--they'll tell you the straight and narrow truth about the Blue coolant sealer.
What they won't tell ya is what else is going to get sealed up solid besides the head gasket's--
I'm telling you that the right way to do the job is to tear the heads off and replace the gaskets--no quick fix, miracle in ia can, or bottle, be it green, blue, pink, silver, or gold with or without the genie is going to get the job done right, without screwing somnething else up.
And the mfg. isn't going to tell you the whole story--
Read on--get loaded up with all kinds of propaganda & info---
That's good.
Then get out there and do the job right the first time.
There is no pot of gold at the end the rainbow. _________________ T.K. |
seanj Samba Member
Posted: Mon Oct 09, 2006 11:37 pm Post subject: |
use the g.m. sealer on each side of the gasket? |
Terry Kay Banned
Posted: Tue Oct 10, 2006 5:19 am Post subject: |
You can if you want--
I use it only on the head sealing side of the gasket.
Makes no if you use it on both sides.
You can also use the GM stuff on the top side of the valve cover gaskets for a leak free valve cover's.
It's oil proof as well as coolant proof. _________________ T.K. |
alnvilma Samba Member
Posted: Tue Oct 10, 2006 8:20 am Post subject: |
I had the same issue on the same age rebuild and the Suby "Genie in the bottle" worked great! I agree to do the job right and maintain it correctly but this short term fix works w/o clooging things up. It is a $3.00 fix that will buy you many happy miles. |
hoggs vw repair Samba Member
Joined: March 08, 2006 Posts: 11 Location: Malahat, BC, Canada
Posted: Tue Oct 10, 2006 2:47 pm Post subject: |
terry k is right on track . i have done a lot of waterboxer head replacements and have used a good grade of rtv sealer instead of the vw black goop that costs 25 bucks a tube . i havent had any problems . the magic fix in a bottle will only plug the rad and heater cores . the best way is to do the job right in the first place . its to expensive to pay twice . |
Terry Kay Banned
Posted: Tue Oct 10, 2006 7:59 pm Post subject: |
And this is the exact point I was trying to make.
Let me tell you guys--I am goofier than a 3 dollar bill, and
I'm up for a quick legitimate fix if it's a good one.
I've been down this sealer road many times--and screwed up more than one radiator & heater core--and all not just VW's either.
If the truck / car was junk and just a 50 dollar work beater--who care's ?--
I agree.
Drop the blue sealer,or the Bars' Leak into it--whatever.
BUT---
If you have one iota of feelings for the Van--or it is a nice unit--just has a weak head gasket--
DO NOT DROP THE MIRACLE IN THE BOTTLE IN THE COOLING SYSTEM.
You'll short cut the heater core's and radiator's ( what's left of it ) life down to nothing.
You'll be here asking all kinds of questions next summer--"Why is My engine running hot"
You will screw up the radiator & heater cores--not one doubt in my mind.
Then you'll be spending more of them frugal bucks.
As ole Paul Harvey sez--
"And Now You Know The Rest Of The Story"--: )
Happy Head Gaskets--- _________________ T.K. |
rhythmslave Samba Member
Joined: October 13, 2006 Posts: 3 Location: Pacific NW
Posted: Fri Oct 13, 2006 8:03 pm Post subject: |
Having had to drop the engines for the last 15 some odd aircolled VW's I have grown to know intimately over the years... just to do head related stuff, I was just pleasantly surprised to find that the 84 Vanagon waterboxer did not require such labors. I didn't even have to remove the exhaust as I pulled the exhaust studs (although this did make it a bit dicey to line the headers back up...) While it was off I did my first valve job (had a broken exhaust valve) and am embarrased at how much I have paid for that service over the years. I used no special goop, but the two tubes that came with the gasket set, and have no problems and a smooth running engine once again!
Woo Hoo Vasserboxers!!!!
no garage... done on the side of the road.
mmmmmmmmmmmmmmmmmmmm
BUT---
Then you'll be spending more of them frugal bucks. |
msinabottle Samba Member
Posted: Fri Oct 13, 2006 11:08 pm Post subject: Huzzah! 'Nother New Member! |
You guys all have me frightened enough to suggest bone rattles and dancing in a mask around the rear hatch.
Welcome, rhythmslave!
Best! |
Posted: Fri Oct 13, 2006 11:29 pm Post subject: Re: Huzzah! 'Nother New Member! |
msinabottle wrote: |
Best! |
Thanks! I been an opposed 4 guy since 74. Bought a 65 bug, and the guy next door gave me an old 36 hp engine to play with... looked alot like the continental my dad rebuilt for his homebuilt airplane. I rebuilt engines on the dining room table, used a Tonka truck chassis and scissor jacks to lower and raise engines.... bought a 63 delivery van (cargo doors on BOTH sides) and rebuilt it with 86.5 jugs, would pull that engine out and put it into a dead bug for the winters so's there would be heat... really liked the way you could just roll the engine straight out the rear without dropping it. Been through ...
Bugs;
58, 62, 65, 66 X 3
Bus's
59, 63, 65, 71, 78 ChampaignII (still have... see Bay- swing arm link pin replacement for that saga...)
Vanagon
84 (woo hoo - HEAT!!!)  |
