offshores Samba Member
Joined: February 08, 2012 Posts: 1085 Location: So Cal
Posted: Sat Mar 09, 2013 6:07 pm Post subject: To Bench Prime Or Not To Bench Prime? |
I’m converting to a dual master cylinder on a ’65 Bug and have been reading up on the bleeding process. I’ve read where I should bench bleed or prime first and then I’ve read where it’s not necessary. I decided I would attempt to bench prime and then noticed my MC didn’t come with any plugs or a “priming kit” that was mentioned in another article. What are my options? Everything is brand new, hard and soft lines, shoes, wheel cyls, master, everything. I’m seriously just going in circles reading all the posts on here (by means of using the search function) and thought it would suit me best to just ask. Thanks!!! |
DuaneL Samba Member
Joined: February 02, 2012 Posts: 511 Location: Spokane WA
Posted: Sat Mar 09, 2013 6:37 pm Post subject: |
you are not going to get a defining answer lots of us don't bench bleed and have no problem others swear that it has to be bench bled. some will just loosen the hard lines at the master while some one presses the brake pedal to achieve the same results as bench bleeding. _________________ ____________
1971 std bug, 1776, ACN Super Stock 34-3, dvda dist, 27x8.50 14 tires |
Helfen Samba Member
Joined: January 19, 2009 Posts: 3481 Location: Vulcania
Posted: Sat Mar 09, 2013 7:22 pm Post subject: |
I find it can be messy and I have not had trouble just doing it on the car. I just had a look at my brake course handbook I got when I was attending VW of America school ( dated 1968 ). It does not mention bench bleeding, however it does say to start with the wheel furthest away from the master cylinder on single circuit brake systems and with dual circuit to start with the front wheels first and the wheel farthest away from the master ( in LH steering would be rt ft.) then the rt rear first then LR, but only after the front is bled. There is instances where it not only helpful, but a necessity to bench bleed. Cars with a proportioning valve, and cars with ABS it is a must to bench bleed or you could be there forever. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 25858 Location: Olympia Wash Rinse & Repeat
Posted: Sat Mar 09, 2013 8:12 pm Post subject: |
If you need to bench bleed, all you need to do is open a bleeder valve and have your helper press down on the pedal. Then you close off the valve and have your helper let up the pedal. Repeat till you get some fluid to burb out.
With dual circuit do the front first and then bleed. Repeat with the rear afterward. _________________ In Stereo, Where Available! |
Posted: Sat Mar 09, 2013 8:38 pm Post subject: |
Okay, so should I open and close the lines at the mc to prime it as per DuaneL’s advice and then open a bleeder valve and have my helper press down on the pedal, etc as per Eric&Barb’s? Or should I just go straight to opening a bleeder and having a helper push on the pedal, etc (E&B’s way)? Helfen, I just read about the different bleeding order yesterday for the first time and would have had no idea. I always thought that the order started with the wheel furthest from the mc. That’s good info to know when converting over to a dual circuit. Body's off so opening the lines at the mc and applying pedal pressure would be very easy. Thanks for the help guys. |
Posted: Sat Mar 09, 2013 8:59 pm Post subject: |
Dual circuit also needs to lock up all the brake shoe adjusting stars till the shoes are fully against the drums. Otherwise it is a lot harder to bleed the system. _________________ In Stereo, Where Available! |
Helfen Samba Member
Posted: Sat Mar 09, 2013 10:23 pm Post subject: |
offshores wrote: |
Well it's good to know VW does it that way on dual circuit , but my 64-& 65 stock beetles and my Nissan's, Pontiac's and Oldsmobile with dual master cylinders get bled the old way per their factory instructions so go figure. I can't see where the difference would be. The Olds is a standard disc ft drum rear with proportioning valve. The Pontiac's (1962 & 1969) are front & rear disc with adjustable driver operated proportioning valve track/street cars and the Nissans are four wheel disc with proportion valves and ABS. They all start at the rear and furthest away from the master first. I looked at the VW dual circuit diagrams/ cutaway drawings especially of the master cylinder and I can't figure out why they are bled that way. |
demon1018 Samba Member
Joined: September 12, 2009 Posts: 931 Location: crystal river, fl
Posted: Sun Mar 10, 2013 5:38 pm Post subject: |
if all the lines and brake cyl are new and empty then it really wont matter if you bench bleed . if your lines are already full of fluid and you dont bench bleed , youll be pumping all that air in the system so it will take longer. they sell the kits to bench bleed at the auto part store. either way youll get it done |
pwmcguire Samba Member
Joined: January 30, 2011 Posts: 1108 Location: Kennesaw GA
Posted: Sun Mar 10, 2013 8:12 pm Post subject: |
I used the harbor freight vacume brake bleeder that you hook to your compressor on a brand new brake system. It worked like a dream. Best pedal I have ever had in my beetles. |
BruceJ Samba Member
Joined: June 16, 2009 Posts: 260 Location: Portland, ME
Posted: Wed Apr 10, 2013 6:09 am Post subject: |
Helfen wrote: |
Just to make sure I'm reading this correctly, for a dual-circuit MC, I want to bleed the front portion of the MC and the front wheel cylinders first, then bleed the rear of the MC, then the rear wheels? In other words, I want to be completely done with bleeding of both the front portion MC and the front wheels before moving on to the rear MC and then rear cylinders?
Or, do I bleed the MC first, front and back; then move on to the wheels, also front and back? |
Posted: Wed Apr 10, 2013 6:31 am Post subject: |
You could do it either way.
If you have problem getting fluid out of the MC then you can "bench bleed" it while in the VW. _________________ In Stereo, Where Available! |
slalombuggy Samba Member
Posted: Wed Apr 10, 2013 6:36 am Post subject: |
I've always started at the back right and worked to the closest wheel to the master.
The problem with bench bleeding a master is it's very messy and the few times i tried it, the fluid all out on the install anyways.
If you're replacing an existing master, there's nothing wrong with pumping a bunch of air and clean fluid through your brake system. It flushes it out and gets rid of all the old water and debris laden fluid.
I've started using DOT 5 silicone based fluids in my ACVWs it doesn't absorb water which is good as my cars sit a lot over the winter. If doing this on an existing system you have to flush the old fluid out completely as it doesn't mix with other DOT brake fluids.
brad |
BruceJ Samba Member
Posted: Mon Apr 15, 2013 6:59 am Post subject: |
Okay, I think round #1 went okay. Before I started, I ran the star adjusters all the way out, so the shoes were tight against the drums, as recommended above. Then, with a helper, I bled both circuits of the MC (front first, then back), then bled the wheel cylinders RF, LF, RR, LR.
I'm going to call it a success (so far) because:
1. The entire system is all new -- dual circuit MC, WC's, drums, shoes, hard/soft lines, etc., and I found no leaks. Good clear fluid at all four. (Yay!); and
2. The brake pedal no longer goes all the way to the floor. Instead, it goes almost to the floor, but is quite firm where is stops.
Obviously, I'm not comfy with this last point, though it's progress. Assuming that the little pin behind the brake pedal, where it runs to the piston, is adjusted properly, what next? I assume another round of bleeding, at least at the wheels, is in order. Should I check to make sure the shoes are still flush, like maybe they "centered" themselves under pressure? Also, am I correct in leaving the parking brake cables slack for now?
Just trying not to waste my "helper's" time, since I'm sleeping with her . |
fluxcap Samba Member
Joined: February 07, 2006 Posts: 1969 Location: Newnan GA
Posted: Mon Apr 15, 2013 7:24 am Post subject: |
Check all your star adjusters again. I know you already adjusted them out before you started bleeding, but since everything was brand new, the shoes may have settled some more during the pedal pumping/bleeding process. A small adjustment of the shoes can sometimes make a huge difference in pedal travel. Not sure that'll fix the pedal issue, but something to try. _________________ Eric - 1966 camper bus
"It's like, how much more black could this be, and the answer is none.......none more black." |
Posted: Mon Apr 15, 2013 5:24 pm Post subject: |
How much play do you have between the pedal push rod and the MC piston??? _________________ In Stereo, Where Available! |
BruceJ Samba Member
Posted: Mon Apr 15, 2013 7:13 pm Post subject: |
As far as I can tell, about 1mm. I noticed it was way off when I swapped the old German single-circuit to the new aftermarket dual-circuit master (or maybe it was out of spec before this). Not having an accurate way to measure 1mm down there, I adjusted as per Muir; i.e., turn rod until it just touches piston, then back off half turn, then tighten lock nut.
At least, I assume that's what I can feel in there -- the pin just touching the piston. It's like, there's no resistance, then after a very small amount of pressure with one finger, it's like -- tink -- then I feel like I'm moving something more than just the pedal. Then it travels almost, but not quite, to the floor before feeling firm.
I will check all of this again -- the adjusting stars, the free play, the bleeding. Mainly, I was wondering if my results after the first go-round was about normal for a newbie with an entirely new brake system.
Thanks |
jzjames Samba Member
Joined: September 27, 2007 Posts: 1921 Location: Windy Point, WA
Posted: Mon Apr 15, 2013 9:51 pm Post subject: |
havent read all the blah blah, but bench bleeding? Yeah, why not. If youve ever done it, its no biggie, and to me, is just an added benefit. |
BruceJ Samba Member
Posted: Sat May 04, 2013 5:11 am Post subject: |
I went ahead and re-adjusted the star nuts so that the shoes are tight against the drums. Pedal play about the same -- firm, but only and inch or so from the floor. Triple-checked MC push rod and looks fine to me. Will do round #2 of the bleeding process tomorrow.
Here's a thought I'm having: Many sources (including the Bug-Me video) show the MC bleed process as having the assistant press and hold the pedal, while you crack open the output line at the MC, let air burble out, tighten nut, and repeat until there are no more bubbles.
Sounds simple, but: supposing the brake lines themselves are still loaded with air, wouldn't you just be sucking all of that air right back into the MC when the helper releases the pedal? Elsewhere in here I read an alternate method where you detach the brake line completely from the MC, and just block the hole with your thumb (carefully, so as not to get a faceful of fluid, not to mention ruined paint!). Air burbles out during compression; upon release, the port is blocked by your thumb thus ensuring you're drawing just fluid from the reservoir and not air from the brake lines. Makes more sense to me, but what do I know?
I know for most of you this isn't rocket science, but this is new territory for me, and I like to know not only what do do, but why. |
Posted: Sat May 04, 2013 7:14 am Post subject: |
If you shut off the bleeder valve before having your helper let up on the pedal, the MC can not suck air back into it from the brake lines. _________________ In Stereo, Where Available! |
johnnypan Samba Member
Joined: October 24, 2007 Posts: 7431 Location: sackamenna
Posted: Sat May 04, 2013 7:56 am Post subject: |
gravity bleed,no helper,no bench bleeding...just follow the method for dual master brake bleeding,crack the bleeder and wait..when fluid runs out its done.. |
