gitchesum Samba Member
Joined: November 10, 2003 Posts: 515 Location: North Cali
Posted: Wed Feb 23, 2005 8:24 am Post subject: Flashing semaphores...? |
Can I hook up a flasher in my 55 so the semi's blink when they are on...or will they just go up and down? _________________ Looking for SP Kadron manifolds...please !!
57 SC
61 rag w/356B brakes
61 356B
Honda XLR 250, 69 Z50, Yamaha 100 Enduro...and others.
GMC SLT 4x4 Dmax
Kubota L3710, not enuf attachments.
And various VW's that come and go... |
Wiggy Samba Member
Joined: April 17, 2003 Posts: 6606 Location: Downingtown, PA
Posted: Wed Feb 23, 2005 11:20 am Post subject: Re: Flashing semiphores...? |
gitchesum wrote: |
Can I hook up a flasher in my 55 so the semi's blink when they are on...or will they just go up and down? |
Yes. I did it in my 55 vert. They blink, but stay up. _________________ Kevin "Wiggy"
My 58 Ghia Vert
My 51 Split 11G
My 57 Deluxe
My 56 Oval |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17560 Location: Left coast, Canada
Posted: Wed Feb 23, 2005 11:30 am Post subject: |
I think you would need to run a separate wire for the bulb, then hook it up to a flasher relay.
Two things that may happen when you try to power the whole thing with a flasher relay:
1) the semaphore will drop when the power is cut
2) the relay won't be able to handle the big amps a semaphore draws.
Back in the 50s there was an aftermarket accessory add on that would make the light blink but the semaphore stay up. The bulb holder was replaced with a specially made one that had a bimetalic strip and a set of contacts. The bimetalic strip would heat up and break the contacts. Once the cct was broken, the bimetalic strip would cool and close the cct turning the bulb on. Designed right, it would flash at the right frequency.
Anyone know where to get such a device? Is this repro'd? |
Dave Samba Elder
Joined: July 11, 2002 Posts: 2715 Location: The Forest Moon of Endor, in the Redwoods
Posted: Wed Feb 23, 2005 11:54 am Post subject: |
I have seen semaphores that do that, my friend Jason has a '50 Split that has some of those, I think they are called "Klacker" or "Clacker" or something like that. I know he paid a pretty penny for them- they are flashing, and the are the correct Split "grooved" semaphores. _________________ 2003 Samba Chummie Winner- Best Story
"Those that matter, don't mind,
and those that mind, don't matter" |
Wiggy Samba Member
Posted: Wed Feb 23, 2005 7:41 pm Post subject: |
Dave wrote: |
I have seen semaphores that do that, my friend Jason has a '50 Split that has some of those, I think they are called "Klacker" or "Clacker" or something like that. I know he paid a pretty penny for them- they are flashing, and the are the correct Split "grooved" semaphores. |
Yeah, by buddy has a pair of clackers on his 50 split. They cost $2k and were NOS. _________________ Kevin "Wiggy"
My 58 Ghia Vert
My 51 Split 11G
My 57 Deluxe
My 56 Oval |
johan_l Samba Member
Posted: Sat Feb 26, 2005 9:02 am Post subject: |
I'd like to add flasher relay to let the rear light flash, just as they do on (europe) 1960 beetles. Guess You had that kind of rear lights and turn-signal-switch on all beetles from 55 on. We had semaphores up to 1959 and one year only rear/break/turn-lights.
Get the rear lights to flash would help avoid idiots who try to overtake me cause they think I slow down my old car for some other reason - not seeing my semaphore, when I'm just going to turn to the left... If the rear light would 'flash' then they would understand it, they'r just not looking in the semaphore area for a turn signal.
I like the solid light from the semaphore - why should they flash? To get them to flash by using a normal relay - yes you'll need to add an extra cable to the light bulb - otherwise the semafore would flip up and down an probably break after a while. _________________ Johan, Sweden
1960 Karmann-Ghia coupé
1957 Oval window
Bastard Split window <-- Translate |
Bruce Samba Member
Posted: Sun Feb 27, 2005 2:38 am Post subject: |
johan_l wrote: |
I like the solid light from the semaphore - why should they flash? |
So that people recognise them as a turn signal and not a side marker light. Believe it or not, if you show the average person today a semaphore, they don't know its a turn signal. |
Posted: Sun Feb 27, 2005 8:52 am Post subject: |
I agree with Bruce...it seems like you just need to run an extra wire hooked up ,to a flasher....is it harder than that ? _________________ Looking for SP Kadron manifolds...please !!
57 SC
61 356B
GMC SLT 4x4 Dmax
Posted: Sun Feb 27, 2005 2:40 pm Post subject: |
But still they will look at the rear light, where most people expect to se the turn signal on a beetle. Beeltles are still that common so people know were they have their turn signals (ie on the rear light). Nicest would of cource be to have BOTH semaphore AND rear light to be able to flash - but also to be able to turn it off so it appears more authentic when not driving in dense traffic...  _________________ Johan, Sweden
1957 Oval window
Wiggy Samba Member
Posted: Sun Feb 27, 2005 3:43 pm Post subject: |
johan_l wrote: |
But still they will look at the rear light, where most people expect to se the turn signal on a beetle. Beeltles are still that common so people know were they have their turn signals (ie on the rear light). Nicest would of cource be to have BOTH semaphore AND rear light to be able to flash - but also to be able to turn it off so it appears more authentic when not driving in dense traffic...  |
I have the parking light in the front, the semaphore and the rear taillight hooked up for flashing. The semaphore does not flop up and down. _________________ Kevin "Wiggy"
My 58 Ghia Vert
My 51 Split 11G
My 57 Deluxe
My 56 Oval |
Posted: Mon Feb 28, 2005 8:29 am Post subject: |
Quote: |
I have the parking light in the front, the semaphore and the rear taillight hooked up for flashing. The semaphore does not flop up and down. |
Would you mind a small wiring diagram?? _________________ Looking for SP Kadron manifolds...please !!
57 SC
61 356B
GMC SLT 4x4 Dmax
Richard Roth Samba Member
Posted: Thu Mar 03, 2005 8:06 am Post subject: |
There is a factory part to make semaphores blink.
the box says "SWF-BLINKMOTOR".
MOTEURS DE CLIGNOTEURS-FLASHER MOTOR
It mounts behind the dash.
I can send pics of mine. |
restojohnny Samba Member
Joined: February 13, 2004 Posts: 2835 Location: SPLITSVILLE , SON !!!!
Posted: Thu Mar 03, 2005 8:24 am Post subject: SWF blink motor |
Hi Richard,
Remember me ??I sold you BUG IN Plaques # 1 & # 2. Could you send me a picture of that motor?? I am building a 43 Split that's why I sold my collection awhile back to fund it. I would like to look for that motor but would like to see what I am looking for incase I find one out of the box. My email is restohouse@aol.com Thanks Johnny
____________
1943 KDF Split
1954 Lambretta LD 150
Wanted: front banana bumper w/ guards
another Jim Dandy Rack???? |
adictvw Samba Member
Posted: Sun Mar 06, 2005 1:54 pm Post subject: |
i have a 1954 bug it has working semaphores and heart tail lights.
i have disconected the semaphores due the the fact that mordern drivers dont see them.
but the back lights of my car i have rigged up like this
extra fog lamp in the rear vents the wake up tailgaters.
the hearts light is my turn signal.throu a flasher .
the rear lamp i have modified to take a twin fillament bulb thet has 2 wires soldered on to give stop and tail light
sorted |
57vwrag Samba Member
Posted: Mon Apr 11, 2005 2:10 am Post subject: |
2splits wrote: |
Someone asked you how you have this wired. Did you provide that info or could you? I'm pretty sure I know how to do it, but I'd like to know how others have wired them.  |
Posted: Mon Apr 11, 2005 6:37 am Post subject: |
Same here....I can figure it out...but I would like to see if others have done done it... _________________ Looking for SP Kadron manifolds...please !!
57 SC
61 356B
GMC SLT 4x4 Dmax
John Moxon  Samba Moderator
Joined: March 07, 2004 Posts: 14184 Location: Southampton U.K.
Posted: Mon Apr 11, 2005 9:25 am Post subject: |
I have semaphores on my '59 Euro Spec Beetle that run in tandem with later front and rear flashing indicators, added to the car in 1962.
The previous owner made a wiring diagram and I've tidied up his notes and have a good clear copy so if any of you would like a copy just PM me and I'll send you a .jpeg. I haven't uploaded the diagram to the gallery because of the 300KB limit.
The system uses 2 flasher units...one for each side...why? probably because it works better with the 6v system. The semaphores stay up and the semaphore light flashes the same as the indicators.
What you will get from me is the wiring diagram without the technical back-up...sadly I'm no auto electrician, but the system works well and has been for the last 10 years. _________________ John.
Carl-Erik Samba Member
Joined: December 19, 2002 Posts: 54 Location: Stockholm - Sweden
Posted: Tue Apr 12, 2005 8:00 am Post subject: |
Just a cool 50's ad from a german magazine... it's just what you are looking for, and real cheap too!
_________________ VW: -63 Cal-Look, Others: Citroen CX 2400 Pallas 1978
Minds are like parachutes - they only function when open. |
Posted: Sat Apr 16, 2005 9:23 am Post subject: |
Seems like nobody out there has a diagrahm....so for now, I hooked the semaphores to an extra 6V battery, and they will work fine 'till I go to the blinkers...
Thank all....... _________________ Looking for SP Kadron manifolds...please !!
57 SC
61 356B
GMC SLT 4x4 Dmax
