PghGhia Samba Member
Joined: March 12, 2009 Posts: 5 Location: Pittsburgh, PA
Posted: Thu Mar 12, 2009 2:02 pm Post subject: accelerator tube question |
I installed an accelator cable yesterday complete with new flex tube and hard tube that fits through the fan shroud.
While the flex tube has a boot where it mates to the exit tube from the tunnel, is there a boot where the flex tube meets the hard tube from the shroud? And the hard tube seems to hold in place by a grommet on the motor side of the shroud?
Am I missing any peices or is this the way it is to be? It would seem the hard tube can work its way along the cable towards the carb and the joint between it and the flex tube would open up.
thanks! |
69 Jim Samba Member
Joined: September 27, 2004 Posts: 6264 Location: Chickengeorge's Neighbor
Posted: Thu Mar 12, 2009 2:23 pm Post subject: |
| I install a fuel line size hoseclamp behind the fanshroud on the rigid tube, it seems to work well for me. Good luck. |
glutamodo  The Android
Joined: July 13, 2004 Posts: 26593 Location: Douglas, WY
Posted: Thu Mar 12, 2009 4:07 pm Post subject: |
The hose clamp deal works good, I've never had any problems with doing it that way.
-Andy
redrum71 Samba Member
Joined: August 07, 2006 Posts: 494 Location: No-wheresville KS
Posted: Thu Mar 12, 2009 4:43 pm Post subject: |
Ditto, I had that problem and did the hose clamp trick about a year ago, no problems since _________________
72 FAT chick
71 baywindow -
67 Baja  |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33379 Location: Hot Arizona
Posted: Thu Mar 12, 2009 7:49 pm Post subject: |
| thanks for the replies guys and thanks for the pic glutamodo - I'll do the same! |
DrDarby Samba Member
Joined: May 12, 2004 Posts: 6544 Location: Northern Illinois
Posted: Thu Mar 12, 2009 8:07 pm Post subject: |
Indeed, that hose clamp is a must have part. _________________ Midwest Autosavers, Inc. Crystal Lake, IL |
Posted: Fri Mar 13, 2009 1:08 pm Post subject: |
One more tip, get a 1/4" nutdriver (or whatever the fastener size is on there, usually it's 1/4 for small hose clamps) to tighten the hose clamp. Works a lot better than a screwdriver because you're working blind in there and a nutdriver won't slip off.
-Andy |
VOLKSCARTER71 Samba Member
Joined: October 23, 2004 Posts: 97 Location: Ramona, CA
Posted: Fri Mar 13, 2009 1:44 pm Post subject: |
my hose clamp is still holding strong for 6 years... yay _________________ __________________
71 Beetle Std (Everyday Driver! 1600cc Hydraulic Valves Single port 32 PICT Carb woohoo!) |
