Stuck Clutch
bbrockett
bbrockett is offline
PostPosted: Tue Aug 10, 2010 1:00 pm    Post subject: Stuck Clutch Reply with quote
Last year I had the engine in my 1977 Westy rebuilt and while I had it out I decided to put in a new clutch. Got her back together and she drove her several weeks. She drove great. Life is good! Put her in the unheated garage for the winter and when I got back from wintering in Florida I started her up only to find the clutch would not disengage! Life is not as good! Yesterday I pulled the engine and found the clutch disk stuck to the flywheel and pressure plate with a very light coat of rust. How do I keep this from happening again? Before I pulled the engine, I tried to pop it loose with no luck. Thanks for your help.
Bruce in Ohio
RocketRod
RocketRod is offline
PostPosted: Tue Aug 10, 2010 1:25 pm    Post subject: Reply with quote
I would start it periodically throughout the winter and move it an inch or two. You should do that anyway.
Why Yes it is a Magic bus!
Common Sense isn't so common.
VDubTech
VDubTech is offline
PostPosted: Tue Aug 10, 2010 1:39 pm    Post subject: Reply with quote
No you shouldn't. Starting it like that is actually worse for a vehicle in storage than leaving it be for the duration of storage, unless you take it out on a good long ride and get it up to temp, you're doing morre damage than good.
First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote:
a measurement of your rod would be extremely useful.
notchboy wrote:
my dad wasnt a belittling cock when he tought me how to wrench on cars.
One photo = good for reference.
10 photos = douchebaggery
RocketRod
PostPosted: Tue Aug 10, 2010 1:42 pm    Post subject: Reply with quote
I hear what you are saying but his problem was a stuck clutch and moisture. so what the hell do you recommend he do instead of just throwing out a what not to do?
busdaddy
busdaddy is offline
PostPosted: Tue Aug 10, 2010 2:35 pm    Post subject: Reply with quote
Well it's a pretty rare occurance, usually fairly easy to fix too, start the bus in gear and drive around with the clutch pushed in.
I guess if you're worried you could manufacture a custom 2x2 or 2x4 to keep the clutch depressed while it's stored, but then I'd worry about the pressure plate springs losing thier mojo.
Слава Україні!
Joey
Joey is offline
PostPosted: Tue Aug 10, 2010 5:54 pm    Post subject: Reply with quote
Just get in it every month or so and push the clutch in a few times.
Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle
SGKent Premium Member
SGKent is offline
PostPosted: Tue Aug 10, 2010 7:01 pm    Post subject: Reply with quote
Consider this. Go to your local marine store like west marine and but a dehumidfier so you don't get rust. If the pressure plate and flywheel are rusting then that isn't the only problem you have.
Frankly I am Surprised that BusDaddy's solution to break it free failed. I am thinking that it was wet or damp when you put it away?
George Carlin:
Skills@EuroCarsPlus:
