EMPI Stub Axle Breaks !!
Iguana
Iguana is offline
PostPosted: Mon Nov 17, 2014 10:34 pm    Post subject: EMPI Stub Axle Breaks !! Reply with quote
Well it seems my opinion of what Empi Parts I can and can't use is growing each time I go out and Play. I went out to the desert on Sunday with a mate for a quick spin. 15 miles in he did a U-turn and had a small issue with his Empi Stub Axle...
Judging by the feedback I have been getting this is becoming a very common occurrence.
At least I know my caliber brackets holds up to side force Shocked
Axle was a clean break just in side the carrier. Until that happened we were having a great time lol. These axles had maybe 300 miles on them and this was their first time in the Desert.
Should have had a spare, oh well live and learn.
Letterman7
Letterman7 is offline
PostPosted: Tue Nov 18, 2014 5:37 am    Post subject: Reply with quote
Well... doesn't that just suck. One would think there would be a US company that could mill decent ones, even if the price were a little higher. Any machine shops in your area?
GS guy
GS guy is offline
PostPosted: Tue Nov 18, 2014 5:49 am    Post subject: Reply with quote
Precision Alloy:
http://precisionalloy.com/
Top quality, USA made. They modified a set of 944 stubs to accept T2 CVs for me some years back, excellent quality work.
Jeff
70's vintage Deserter GS buggy - undergoing transformation to Super GS!
Tom_Kathleen
Tom_Kathleen is offline
PostPosted: Tue Nov 18, 2014 7:24 am    Post subject: Reply with quote
When we 1st converted Kathleen's Manxter to Subaru power and it still had VW IRS rear suspension, I used EMPI 930 stub axles. Every year (or less) I would have to retighten the axle nut because the rotor was slightly loose and making funny noises when you hit the brakes. Ended up finding original VW stub axles that had the type 1 cv flange cut off and a 930 flange welded on. I think the EMPI stub axle was stretching. End of problem. Tom
Manxter #16, 1968 Meyers Manx & Kick-Out SS #16 (WIP)
Manx Club & CVA
joescoolcustoms
joescoolcustoms is offline
PostPosted: Tue Nov 18, 2014 7:50 am    Post subject: Reply with quote
Tom_Kathleen wrote:
When we 1st converted Kathleen's Manxter to Subaru power and it still had VW IRS rear suspension, I used EMPI 930 stub axles. Every year (or less) I would have to retighten the axle nut because the rotor was slightly loose and making funny noises when you hit the brakes. Ended up finding original VW stub axles that had the type 1 cv flange cut off and a 930 flange welded on. End of problem. Tom
Aarrrgghhhh!
That is the setup I have for the Tow'd. Will re-think and re-tool. The EMPI 930 flange for a 091 should be fine would you think?
Bad News Racing 2018 NORRA 1000 3rd in Class
Looks like it was painted with a live chicken,polished with a brick and buffed with a pine cone
herkster
herkster is offline
PostPosted: Tue Nov 18, 2014 7:54 am    Post subject: Reply with quote
I will be running...(on road) the type 2 cvs...not quite as strong as 930 im sure but has to be better than type 1. Bad news is that they are empi build.
subhuman
subhuman is offline
PostPosted: Tue Nov 18, 2014 7:57 am    Post subject: Reply with quote
one word explains your problem, EMPI! Mad
63 restomod build
http://s431.photobucket.com/albums/qq37/johnnysubhuman/?albumview=slideshow
you can have everything you want, just don't want so much!
"the wrong way always seems the more reasonable."
george moore
1963 type1
2002 Subaru Wrx
never argue with an idiot, they will only drag you down to their level and beat you with experience!
Mark Twain
joescoolcustoms
PostPosted: Tue Nov 18, 2014 8:00 am    Post subject: Reply with quote
I have right at 10,000 miles on a full set of EMPI T2's CV's running mostly highway at 16* axle angle and no problems yet, but I will replace all 4 before making the trip to CA and back in 2015. The boots are starting to show wear where they touch their ribs do to the axle angle.
nightmanx11
nightmanx11 is offline
PostPosted: Tue Nov 18, 2014 8:55 am    Post subject: Reply with quote
I am beginning to think that when I managed to pull an EMPI stub axle apart at MOTB 2013, it was not a fluke. Seems like there is a pattern develping with these stub axles.
There is a very good thread on this subject and about the possible cure on another forum.
goto: http://rbcdunebuggy.yuku.com/topic/3801/Bad-Empi-Stub-Axles#.VGtrnvnF-So
Joe
scotth17
scotth17 is offline
PostPosted: Tue Nov 18, 2014 10:18 am    Post subject: Reply with quote
Did you get an engineer to help you tighten the axle nut?
Tom_Kathleen
PostPosted: Tue Nov 18, 2014 12:21 pm    Post subject: Reply with quote
scotth17 - I am only a (retired) Manufacturing Engineer. LOL Since I replaced the EMPI stub axle with OG VW (sort of) parts, no issue, same way tightening the nut. Yes I did read that other thread. Tom
Manx Club & CVA
subhuman
subhuman is offline
PostPosted: Tue Nov 18, 2014 12:29 pm    Post subject: Reply with quote
Help? you mean "tell" you how to tighten the badger, damn i mean nut.
63 restomod build
george moore
1963 type1
2002 Subaru Wrx
Mark Twain
mark tucker
mark tucker is offline
PostPosted: Tue Nov 18, 2014 5:22 pm    Post subject: Reply with quote
might be some not so what it should be stuff coming out of empis drive line line.Ive always heard that stuff was pretty good. might need to look for some old stock. could of been a tool change leaving a sharpe corrner or improper heat treetment or not quite the right aloy of steel...or all 4. Shocked qc sometimes go's to hell when all the chickens are out of the hen house and the usda guard is on vacation.
Iguana
Iguana is offline
PostPosted: Tue Nov 18, 2014 10:54 pm    Post subject: Reply with quote
I think the worse thing about EMPI is that they don't give a toss about it.
I can understand stuff getting out etc but what I can't stomach is when you tell them and they say no we don't have an issue it broke due to abuse.
Dale M.
Dale M. is offline
PostPosted: Wed Nov 19, 2014 8:21 am    Post subject: Reply with quote
Joe
Seems to require a "log in"... Not going to join 'nother forum...
dale
Dale M.
Dale M. is offline
PostPosted: Wed Nov 19, 2014 8:23 am    Post subject: Reply with quote
Have you called EMPI and talked to somebody yet?
Dale
sandhopper
sandhopper is offline
PostPosted: Wed Nov 19, 2014 10:09 am    Post subject: stub axel Reply with quote
My friend builds the ones that are listed in the RBC forum
Not sure what price he gets for them now , but if anyone wants
let me know and I will find out
He needs cores
Tom_Kathleen
PostPosted: Wed Nov 19, 2014 11:50 am    Post subject: Reply with quote
sandhopper - I need 2 of these made up and I can supply cores. Tom
Manx Club & CVA
herkster
herkster is offline
PostPosted: Wed Nov 19, 2014 9:27 pm    Post subject: Reply with quote
I'd take two with type two cv.... Please let me know price
Iguana
Iguana is offline
PostPosted: Wed Mar 04, 2015 9:54 pm    Post subject: Reply with quote
After a less than stellar response from Empi I have continued to follow this up and the results are far from good for Empi.
I have spoken to a number of people who have had issues and got a fresh Empi Stub Axle tested to see what its hardness was like. Short answer was that its consistency is way off and the hardness varies significantly from spline to bell.
I am going to get the one that broke tested now and see if it is the same and they all suck or if it was just a bad bunch but at least we have a bench mark.
