kampalm Samba Member
Posted: Fri Aug 01, 2008 1:16 pm Post subject: No spark problem fixed thanks to a search on Samba! |
This is just a shout out to all members of the Samba forum. My 74 Riviera left me stranded yesterday. After searching the oracles (Muir and Bentley), I discovered that I had no spark coming out of the coil. I then did a couple of searches on the Samba forum found a suggestion to check out the ignition wire. Did a quick inspection and found a couple of spots where the insulation had come off and was causing a short. I replaced that section of wire and vroom!!.
Thanks again to all of you _________________ 74 Riviera, 1800 type IV, Weber Progressive (and proud of it), SVDA |
