Clutch pedal no pressure! FIXED!
boogerweld
boogerweld is offline
PostPosted: Fri Sep 07, 2012 9:10 pm    Post subject: Clutch pedal no pressure! FIXED! Reply with quote
When leaving a local parking lot, pressed clutch pedal. Heard a snap and lost pedal pressure. Wouldn't come out of gear. Assumed snapped cable or broken clevis. Upon inspection found cable and clevis intact. Pedal pulls shift arm all the way back. Proceeded to pull engine back a little to check throwout bearing or fork, both are good. Now it is dark out and not enough time to pull engine out rest of the way. Is it probable that the pressure plate took a dump just like that? It's a '75 with a 215mm clutch.
Green70
Green70 is offline
PostPosted: Fri Sep 07, 2012 9:18 pm    Post subject: Reply with quote
I had a similar thing happen and it was the throw-out bearing popping off the fork. The fork then wore a grove in the pressure plate fingers, but not before opening up the notch on the fork so that it had to be replaced too.
Yeah, sounds like the PP might have crapped out on you. Did you double check the spring on the clutch arm is still in place? I think an engine pull is in your future.
boogerweld
PostPosted: Fri Sep 07, 2012 9:56 pm    Post subject: Reply with quote
Yeah, spring is still on the arm. I'll get up good and early and pull the engine to get @ pressure plate. It's funny, we are doing a 4500 mile road trip next week and I got all the extra parts one might need, including clutch cable. I'm stoked that this happened 2 blocks from my driveway versus 25 miles east of Wichita. Now just gotta find a local source for a 215mm clutch kit.
busdaddy
busdaddy is offline
PostPosted: Fri Sep 07, 2012 10:13 pm    Post subject: Reply with quote
I assume you've already changed the cable because just looking at the clevis won't detect a broken strand or 10 somewhere in between the front and back.
Слава Україні!
boogerweld
PostPosted: Fri Sep 07, 2012 10:37 pm    Post subject: Reply with quote
Clutch cable changed about 6 months ago.
Wildthings
Wildthings is offline
PostPosted: Sat Sep 08, 2012 9:59 am    Post subject: Reply with quote
I would certainly pull the cable out and inspect it carefully before I did an engine pull. A cable with 1/4" of stretch will still make the throwout arm move a fair amount but will not cause the clutch to release.
busdaddy
busdaddy is offline
PostPosted: Sat Sep 08, 2012 11:13 am    Post subject: Reply with quote
And not all new parts can be trusted, I'd try another cable as well before an engine pull, if it doesn't make a difference you've got a spare.
Слава Україні!
germansupplyscott
germansupplyscott is offline
PostPosted: Sat Sep 08, 2012 12:23 pm    Post subject: Reply with quote
do remove the cable before you go any farther, they can and often do fray apart inside the bowden tube and you don't see the damage.
i had a broken clutch lever that sounded like your problem. i actually pulled the engine before finding the issue.
the clutch lever can split and you lose all your clutch, and it seems like it's something inside, but the it's just the lever that can be repaired without pulling anything.
http://www.thesamba.com/vw/forum/viewtopic.php?p=4965810&highlight=clutch#4965810
SL
boogerweld
PostPosted: Sat Sep 08, 2012 3:17 pm    Post subject: Reply with quote
I'm an idiot. Ya' know I looked @ both cable ends and also verified cable was engaging arm. Dropped engine @ 6 am this morning only to see that pressure plate was perfectly fine. Pulled damn cable out and just as you guys said...........fraid and hangin' by a thread. So......replaced cable, put the engine back in, took a shower, got online and noticed all you guys telling me to pull the cable out. I'm going back to bed. Have a nice day.
Millennium Falcon
Millennium Falcon is offline
PostPosted: Sat Nov 02, 2013 4:27 pm    Post subject: Reply with quote
Glad I found this post. I am having the same issue, so now I will definitely, definitely pull the cable first and check it with my new one before jumping into an engine/tranny drop. Thanks.
"Don't worry, she'll hold together . . . You hear me, baby? Hold together!" -Han to the Falcon
1972 White Campmobile
1700 cc Type IV
Dual Solex 34 PDSIT2/3
Tom Powell
Tom Powell is offline
PostPosted: Sat Nov 02, 2013 5:31 pm    Post subject: Reply with quote
Clutch cables break in cold weather, but can be replaced even when lying on ice under the camper. Driving the leftside wheels onto a curb makes the job easier. Clutch cables come in many lengths, some of which are very close to being correct.
Aloha
tp
udidwht
udidwht is offline
PostPosted: Sun Nov 03, 2013 5:18 am    Post subject: Reply with quote
Did you remember to use some vise grips to hold the cable in place while threading on the wing nut? If not you'll be under the bus again soon enough.
1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires
69vwcarl
69vwcarl is offline
PostPosted: Sat Apr 02, 2016 11:20 pm    Post subject: Re: Clutch pedal no pressure! FIXED! Reply with quote
Hey guys Figured I would post up some pictures and info that might help a new guy or someone who has never had to do a clutch cable swap in a bay window. Very Happy I know this site was a huge help back when i first got into VWs. Anyways here goes.
Picked up this 70 Westy a few weeks ago. Been working out a few small issues one was a VERY stiff feeling clutch...
I picked up a cable and decided to see what was going on. Unhooked the wing nut at the rear on transaxle. Took off "boden" tube and removed the pedal assembly up front removing the 13mm bolts. Pulled cable and sure enough it was FRAYED OUT!!!!!
after tearing everything apart and cleaning it all up with a wire wheel i sprayed a little back paint on the major items and got prepped for re assembly
the "clevis pin" holder was wore very thin on the outer edge from years of use. Because it was Saturday evening and I have to drive to work in this Bus on Monday i decided to try to fix the issue i carefully welded both sides and the top to add material and then cleaned it up with a flap disc.
everything was lubricated and re assembled
new cable was put on and remember the cotter pin on the "clevis pin"
I used some tape on the threaded ends of the new clutch cable so it didn't get all nasty and pushed the cable through the tube from the front of the bus wiggled the pedal assembly back into place and tightened the (2) 13mm bolts and washers.
moving to the rear slide cable back through "boden" tube remove tape and put back up into the clutch arm replace wing nut and tighten till the clutch pedal has around an inch of free play when pushed by hand from its resting point. All bolts were cleaned and coated with "never seize" so if you have to get back in there some time its easier.
That was about it.. took the bus for a drive and instantly noticed the pedal feels much better.. hope this can help someone out down the road.
LOVE splits more than Jean-Claude Van Damme
