Tachy install...
VWBusMan1
VWBusMan1 is offline
PostPosted: Thu Apr 22, 2004 8:23 am    Post subject: Tachy install... Reply with quote
Am just returning to VW dubs after a 20 year hiatus. How does one install an electronic tachometer to VWee without running a wire all the way to the back? Have a 79 westy and too many wires under the dash to figure out which one up front might give me a signal. I know this is probably a really stupid question yet when I search for a thread I get hundreds of hits.
Thanks much, Mark
Grvlguy
Grvlguy is offline
PostPosted: Thu Apr 22, 2004 11:49 am    Post subject: Reply with quote
I have never found one. Always had to run a wire to the rear.
It's Grvlguy!
Ragman
The Sambinator
Ragman is offline
PostPosted: Fri Apr 23, 2004 6:41 am    Post subject: Reply with quote
Yeap, must run a wire. I suggest getting a strip of 4 wires together from a car supply store for a trailer harness. They usually have a roll of it, and they'll charge you by the foot.
Then, wire that 4 wire pack back to the engine compartment. Now, you'll all the wires you'll need to run: tach, oil temp, oil pressure, plus one more gauge.
breadloafdeluxe
breadloafdeluxe is offline
PostPosted: Sat Apr 24, 2004 11:33 am    Post subject: Reply with quote
My question is in the same line, in my 71 type2 I changed out the guages for a set from a 72/914.All the guages work fine with all the bells and whistles working as they should, then after a time 1yr or there bouts the tach needle started bouncing around when I go through the gears, though nice and steady at idle. Went to the VDO site tech support and did the in line 1N4005 Diode thing and that made it worse. Checked the connects,wires guage to coil looks good w/ direct switched 12v from fuse holder and private ground. Will settle down after driving for a time. Help anyone? Regards,David K,69S/Cab 71Deluxe, 03Passat sportwagon http://thesamba.com/vw/forum/album_page.php?pic_id=29325
Give a man a fish and he knows where to get fish.Teach a man to fish and you loose a customer.
Ragman
The Sambinator
Ragman is offline
PostPosted: Mon Apr 26, 2004 5:55 pm    Post subject: Reply with quote
I don't know what would cause that, but my guess is either the coil or the tach itself. I would try to test those two items, and go from there.
isenegger
isenegger is offline
PostPosted: Sun Apr 26, 2009 6:59 pm    Post subject: Reply with quote
where would i tap in on my 73 for the tach at the engine?
69 Jim
69 Jim is offline
PostPosted: Sun Apr 26, 2009 9:03 pm    Post subject: Reply with quote
Negative side of the coil. Same side as the points connect to.
