brainsboy Samba Member
Posted: Wed Nov 12, 2008 6:32 pm Post subject: EMPI 44's tuning |
http://www.youtube.com/watch?v=j1ZIIVsUV3U
Hi guys, Im new here. I dont have a VW but I have a 91 miata with a V12. I'm having some problems getting these crappy empi's tuned in, wish I never bought them but I have to live with it since I have 6 of them now. The motor is 441CC per cylinder and I'm running 200air 135jets, .57 idles stock vents (36mm I think havent checked). I was getting a horrible mid stumble also crusing just off idle I get constant backfiring from too lean. I kept moving up to larger jets several times, now Im at 165jets which helped 85% of the mid stumble but now feels like its running to rich at 3000rpm cruising. The richness is liveable but I still have something that doesnt feel right during cruise. I also get a big bog when I jump on the throttle.. For some reason accelerator pumps work perfect when the carbs are cold, but after everything heats up and I look down the carb the accelerator pumps arent working for whatever reason. Carb pulls harder at 50% throttle than full throttle. Im wondering if I need to start all over with maybe 32mm vents.
Thanks in advance.
mharney Samba Member
Posted: Wed Nov 12, 2008 7:20 pm Post subject: |
We talked in email, I believe.
Those carbs are too big for that engine, unless the cam and heads are crazy.
32 vents oughta help some. The floats are the most important thing before you do much else.
As far as the accelerator pumps not working well when warm, it may be the crummy diaphragms or bad pump exhaust valves. I have also seen these carbs have the bleed plugs in the housings just out and laying in the pump housing. The plug closes a hole that is between the pump chamber and the float bowl.
6 HPMXs on one engine, you're bound to have a challenge. Check the floats and make sure they're set right for starters.. if they're wrong you're bound to get a flat spot. Lazy pumps will surely cause it to nose dive when you put your foot in it quickly as well. |
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7543 Location: Whittier,CA
Posted: Wed Nov 12, 2008 7:28 pm Post subject: |
A Miata with a V12?? I'd love to see that, can you post some pics? I've seen a Miata with a 5.0 liter Mustang engine but never a V12. |
Posted: Thu Nov 13, 2008 6:08 am Post subject: |
How do you set the float height on an empi? The floats have a ball that compesses when the float rises, so what do I set the height to and do I compress the ball and spring when I check height or just as the float touches it?
[/img]
Posted: Thu Nov 13, 2008 6:34 am Post subject: |
Just as the float touches it. 10mm. |
Art Thraen Samba Member
Posted: Thu Nov 13, 2008 7:24 am Post subject: |
Im not sure if I want to post on this, but I will.
The carbs are in need of set up prior to installation. They all need to be calibrated together and the vents MAY need changed.
If you had WEBER, Dellorto, solex you might just have the same problems. Approach this with a detailed list of events, like fuel pressure, float height, Check the size of ea Jet, timing, Advance curve, ETC Make a check list and go step by step.
HECK, I had a 914 in the shop this year that had the same tuning Problems you have, The owner was blaming the carbs, (Because the engine was just rebuilt) by a shop in the area, but the other shop was "NOT A CARB GUY" they brought it to me, They had the timing off 20 degree, the floats were off and they had the wrong spark plugs in the engine.
After 4 hours of tuning the car ran better then it had in 10 years!
APPROACH this slow, and hold back the blame, The HPMXs will work.
Posted: Thu Nov 13, 2008 1:34 pm Post subject: |
Art Thraen wrote: |
HECK, I had a 914 in the shop.... They had the timing off 20 degree, the floats were off and they had the wrong spark plugs in the engine.
Timing is set perfect, plugs are right. I havent checked the float levels because the carbs are new. I thought they would be perfect from the factory. But sometimes after driving I noticed that when I shut the motor off (no FUEl PRESSURE) the carbs keep dumping fuel down through the vents. It only happens sometimes and not sure where the fuel is coming from since the fuel pressure is 0. It only happens sometimes and usually only on 2 or 3 carbs.
So should I keep tuning the carbs in the way they are or try switching to some 32vents? |
pdub Samba Member
Posted: Fri Nov 14, 2008 12:29 am Post subject: |
Well, Mark, are you going to enlighten this gentleman to EMPI and what you found when you took a couple of these carbs apart? Nothing from China works right out of the box and that is especially true if it is an EMPI product. Buena seurte con estos...oh wait thats Spanish, not Italian, close enough. Chao for now. |
Scott Novak Samba Member
Joined: October 12, 2004 Posts: 1586 Location: Minneapolis, Minnesota
Posted: Fri Nov 14, 2008 5:15 am Post subject: |
Even Webers made back in the 70's needed to be cleaned and setup by someone before using them.
There is also the possibility of incorrectly marked jets, or jets that have been drilled.
You can also test your jets by running water or some fluid through them and measuring what kind of volume will flow in a given time period to make sure the jets are all matched.
Scott Novak |
junior55 Samba Member
Posted: Fri Nov 14, 2008 5:35 am Post subject: |
Your project is outrageous !
And well worth the time and effort you are putting into it
because its so mind blowing.
Not to be a wet blanket but I would have gone with a simple form of fuel injection and throttle bodies in place of your carbs.
The look would be the same or even better with a hi-pressure fuel rail going around to 12 injectors!
Anyway, good luck with the carb tuning! |
Posted: Fri Nov 14, 2008 6:11 am Post subject: |
pdub wrote: |
We've already talked a little in email, and I said what I think needs to happen. Until that happens nothing else is going to be right. I've been through this whole thing with EMPI so many times it's head spinning. And the float issue.. I have said it again and again and again, and some people choose to do it, some don't. You can't make 'em drink the Koolaid. Not saying he won't, but if he doesn't, no one's gonna be able to jet or adjust them right.
I hate to piss on the parade of anyone that's got something like this project going. It is an awesome project. I bet that thing will flat out sing and haul major ass. Art's right in that EMPIs can be made to work, but to me, saving a little money is not saving much if you spend a ton of time trying to make them work. I keep hearing this argument about "well even Webers need this and that", but it's never nearly what HPMXs need, at least in my experience.
Brainsboy, check the floats, and for informative purposes, check out http://waitresses.servebeer.com/vwpage and go to Tech Articles, and then to "What's with HPMX". This has been my experience more than once, and I have stopped working on them. Then go to www.carburetorclinic.com and read the tech articles and setting up IDFs, same sort of work should be done on the HPMX above and beyond all the issues I have found, plus some others I've heard of.
As far as how much work you should have to go through according to my IDF article, at least removing all jets and blowing everything out is a good starting point. Just do one and see what you find, and then proceed with the others. You can make them work, just don't figure out of the box is going to be right.
And enjoy your project. It's awesome! |
Posted: Fri Nov 14, 2008 6:38 am Post subject: |
OMG! I had heard how poor the quality of HMPX was, but I never knew they were this far off! That is a lot of serious work to get them working.
Scott Novak |
Posted: Fri Nov 14, 2008 6:51 am Post subject: |
Bail on the carbs and call CB., redline.. megasquirt etc for v12??
CB had V8 kits running simple batch injection on their early FI.
Probably just a little more than you've got invested in carbs that may never be too impressive in the fuel management department.
I will bugg-off on the FI as of now. |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5066 Location: Madisonville, La
Posted: Fri Nov 14, 2008 8:15 am Post subject: |
I would bet the 32 vents would make that engine alot more responsive. 130 mains with 52.5 idles would be a good starting point. _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
Posted: Fri Nov 14, 2008 11:52 am Post subject: |
I took 3 of the 6 carbs apart. Main gaskets ripped apart so Im down for the weekend now. Are you sure .390" 10mm is the right setting for empi floats? All the carbs have the same setting which is right at .500". I just set them all to .390" but when fully compresed (ball down) the top of the floats come about .025" from hitting the bottom of the main gasket.
In your notes you show a section of the carb (not sure what its called) that pops loose with a spring behind it. I took mine out with a screw driver and removed the spring, looked inside and it was full of metal. Each carb had 2 of these, I had 3 of the 6 with thrash sitting in the bottom of them.
So Im going to take all the carbs down and start from scratch. Probably buy one of those gallon carb soaker kits unless you plan on letting me know your secret formula for cleaning carbs.
Thanks for the help so far guys. |
Viande Samba Member
Posted: Fri Nov 14, 2008 12:19 pm Post subject: |
Mark's words are as true today as they were when I was working with Italian Webers 20 years ago. Damn I'm getting old. Disassemble, Clean, Inspect and Set before you ever bolt on a carb. All the low grade Chinese parts have added an additional step to the mix. Repair. Good luck with your project.  |
Posted: Fri Nov 14, 2008 1:20 pm Post subject: |
Special thanks to mark too, he spent alot of time prior sending me e-mails on these carbs.
Its kind of funny, I can build holleys all day long even blind folded and with my toes only. These are my first webers and I have 6 of them linked together so its makes for a new experience.
While were on topic of empi 44's. I havent seen anything that really explains what the air-jets do. Can someone explain? Once I get things closer to being correct with jets and all, and I have 200 air jets, what would happen if I put 180's in? or went the other way with 220's?
Alot of these questions are because I dont have one carb. If I had one carb I could do all my own experiments to learn on my own. But It costs me about 65$ just to change the jets once. |
DSF Samba Member
Posted: Fri Nov 14, 2008 3:57 pm Post subject: |
bigger air hole (220) = leaner.
smaller air hole (190) = richer.
Awesome project! |
Posted: Fri Nov 14, 2008 4:59 pm Post subject: |
My throttle shafts are loose as MARK said above. He mentioned that the outside bearing areas can be fixed however the inside portion can not be. I was thinking about putting the throttle shaft in my lathe and cutting two spots to run rubber seals. Any thoughts on this? |
Posted: Fri Nov 14, 2008 5:07 pm Post subject: |
Std Answer: get rid of the boat anchors and get IDFs.
John
Aircooled.Net Inc. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
