Industrial Tins and Pushrod Protectors, Difference?
Little Harry
Little Harry is offline
PostPosted: Sun Jul 29, 2012 2:46 pm    Post subject: Industrial Tins and Pushrod Protectors, Difference? Reply with quote
I am working on my sister-in-law's '69 Beetle and I have a question about the engine tin. She doesn't really drive it much in the winter so she is running J-Tubes instead of heater boxes. I am trying to replace/repair all of the tin because most of it is damaged/missing and the motor has been running hot. I have read in other threads about how it isn't enough to just have the sled tins with J-Tubes, that the motor will still run hot because of the air that is being forced up while the car is traveling at highway speeds.
Can I use these pushrod protectors http://www.ebay.com/itm/PUSH-ROD-TUBE-PROTECTORS-C...mp;vxp=mtr
to accomplish the same thing as the industrial tins? If not where can I buy a set of industrial tins? Thanks in advance.
1973 VW Karmann Ghia - 1679cc, Kadrons, MoFoCo 041's, Tri-Mil Euro, Interstate Battery, and a little rust.
Zack1978 wrote:
From my perspective vintage VW's are beyond being used for daily driver purposes. It would be best to have your car parked in a garage, and kept away from the elements on a daily basis. Zack
Uhhh...yeah...I disagree
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Jul 29, 2012 2:53 pm    Post subject: Reply with quote
Those are for off road vehicles and not the same as OE tin with industrial shields.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Little Harry
PostPosted: Sun Jul 29, 2012 4:34 pm    Post subject: Reply with quote
Alright so I guess I just need to find some industrial tins then, thanks Glenn.
Mr. 010
Glenn is offline
PostPosted: Sun Jul 29, 2012 5:12 pm    Post subject: Reply with quote
Brand new repors: http://www.awesomepowdercoat.com/Industrial_Shields.html
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
clonebug
clonebug is offline
PostPosted: Sun Jul 29, 2012 5:43 pm    Post subject: Reply with quote
Just build your own...
Get a piece of roofing flashing and with a little cutting and bending you can make them for about $3.00 a piece
Trim one side down to this..
Clamp in between two pieces of wood or something straight and stiff enough...
Use another piece of wood to bend it at a 90 degree angle the distance from the lower sled tin to the bottom of the head minus a 1/4 inch or so.
Trim to fit the curve in front
Make a small 90 out of a scrap to hold the curve in place and then drill the two holes to mount to the sled tins.
Install on the engine and you are set for less than 10 bucks for both sides and maybe a half hour of work if you are quick.
The flashing tin is nice since it has paint already and also is thin enough to easily bend and shape.
richardcraineum wrote:
I'm so ignorant of efi I don't even know the difference between batch, sequential blah blah blah ..
cbeck wrote:
His user name in a previous life was dick head.
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936
Little Harry
PostPosted: Mon Jul 30, 2012 1:30 am    Post subject: Reply with quote
Thanks clonebug! I can. handle that. I appreciate the detailed pics and the time you took to post that.
