Blinkin` temperature lite
dbear
dbear is offline
PostPosted: Mon Apr 07, 2008 11:27 am    Post subject: Blinkin` temperature lite Reply with quote
Recently my '92 Vanagon has developed a problem. When you start it up the temp LED on the gauge goes off and then about ten seconds later starts flashing.
The gauge reads cold, the coolant tubes are cold and I'm pretty darned sure the engine is not overheating. I pulled the computer sensor and tested with hot and ice water. The results match the diagram in the bentley manual. I also cleaned the contacts on the temp sensor and the computer.Can anybody shed light on what is going on and what other checks can I do. I desperately need to get "Vanna" back on the road for my wife.
Thanks
dbear
McVanagon
McVanagon is offline
PostPosted: Mon Apr 07, 2008 11:37 am    Post subject: Reply with quote
When mine blinks, It has been from a low level of coolant in the expansion tank.
'69 Mike
'85 GL
'87 Wolfsburg Hardtop
View user's profile Send private message Twitter Instagram Gallery Classifieds Feedback
ValleyHappy
ValleyHappy is offline
PostPosted: Mon Apr 07, 2008 11:40 am    Post subject: Reply with quote
me to.
09 Suzuki SX-4 Crossover
larrytrk
larrytrk is offline
PostPosted: Mon Apr 07, 2008 12:51 pm    Post subject: Reply with quote
Check coolant connector, clean, on tight and make sure the level is high enough and no loose coolant around connector. Loose or corroded connector will come on all the time.
No Buzzer just light!
It's all in your mind.
I Hate BAMBI!
87 Westy full camper "Bluie" aka-"busturd"
JUST SOLD HER, WESTYLESS!
Good by cruel world!
Dogpilot
Dogpilot is offline
PostPosted: Mon Apr 07, 2008 12:56 pm    Post subject: Reply with quote
You can also check to see if your sensor is bad by shorting the two wires together, it should not blink then if the sensor is bad, or it may be the controlling circuitry.
Mine will also start blinking if I say the self destruct code.
Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G
dbear
dbear is offline
PostPosted: Mon Apr 07, 2008 1:45 pm    Post subject: The light goes on! In my head! Reply with quote
Ah HA! thats what that blinkin light means.Embarassed
I don't have a users manual and the Bentley manual is very unhelpful on such mundane things. I envisioned the light as being a failure indicator for the cpu temp sensor. I guess I've worked on too many late model computerized vehicles.
Thanks for enlightening me and not laughing too hard at my stupid question.
dbear
Boegrrl
Boegrrl is offline
PostPosted: Mon Apr 07, 2008 10:04 pm    Post subject: Blinkin Temperature Lite Reply with quote
Had same issue, went thru many diagnostic attempts..
Replaced dash elec board, bled coolant sys a couple times. My sys was not overheating, but that blinking eye never slept! Finally mechanic spotted a leak in neck of expansion tank. That leak kept the level low and perhaps the wires wet with fluid. In any case, cleaning the sensor and replacing expansion tank fixed the problem. Good luck, and just keep at it, eventually one thing or another will resolve the issue!
Boogievan
Boogievan is offline
PostPosted: Wed Apr 09, 2008 12:17 am    Post subject: Reply with quote
Mine blinks very randomly...sometimes all the time, sometimes never, and sometimes whenever it feels like it. I've just been kind of ignoring it for the last 6 months, and it hasn't caused a single problem yet.
Funny thing was, when a coolant hose blew up, dumped out the entire system onto the freeway, and the engine temperature got to frighteningly high levels... it never came on. Weird.
dbeierl
dbeierl is offline
PostPosted: Fri Oct 15, 2010 5:33 pm    Post subject: Reply with quote
If you still have the problem, see the thread at http://www.thesamba.com/vw/forum/viewtopic.php?t=3...p;start=42
Yours,
David
