Off road mirror mounts
Fozz28
Fozz28 is offline
PostPosted: Thu Feb 19, 2009 10:13 am    Post subject: Off road mirror mounts Reply with quote
I am looking for some mirror mounts for my baja bug. Below is a picture of what I am looking for. However I can only find this style with the 1.5" tube mounts. Does someone make this style of mirror mount for a bug door? Are there other options out there that are close to this design? I am not opposed to customizing this part to work or even making my own mount all together. Just thought I would see if there is a bolt on option out there looking for a home.
Whaaahoooo!!!!
GhiaBateman
GhiaBateman is offline
PostPosted: Thu Feb 19, 2009 10:50 am    Post subject: Reply with quote
look in the off-road gallery and get out your welder...
I just did a quick search and you're gonna have to be creative with your search words, I've seen pics but can't find them quickly...
(o=|=o) Life before play... Damn! it's gonna be awhile.
dustymojave
dustymojave is offline
PostPosted: Thu Feb 19, 2009 12:42 pm    Post subject: Reply with quote
Modifying that piece to fit a door would be easy. Just cut off the 1/2 tubes and make a plate out of 1/16" steel sheet to weld onto it. The flat piece should be sort of a 'C' shape to wrap around the front of the windwing area. Mounting screws need to go into the door where they wont interfere with the seal. Use a minimum of 3 screws. 1 under the windwing, 1 into the 'A' pillar of the door, and 1 near the front corner of the windwing opening.
Richard
SoCalBajas Member
70BajaVert
70BajaVert is offline
PostPosted: Thu Feb 19, 2009 9:07 pm    Post subject: Reply with quote
Where did you find the mirror mounts in the picture?
2do baja
2do baja is offline
PostPosted: Thu Feb 19, 2009 9:15 pm    Post subject: Reply with quote
kartek,pacific customs,thats two i know of pretty sure moores also
veedub4life
veedub4life is offline
PostPosted: Thu Feb 19, 2009 9:36 pm    Post subject: Reply with quote
moore parts has them for less then 15 bucks i just cut off the end part and welded it to the body.
bajaherbie
Samba Sooner
bajaherbie is offline
PostPosted: Thu Feb 19, 2009 9:50 pm    Post subject: Reply with quote
i bought one of the mirrors and had to modify it a bit so i could see something besides my rear tire.... i had to cut and re-weld the strap a bit. i kept the tube mounts because sooner or later i'll hit a tree branch or something else.
blank
busk
busk is offline
PostPosted: Thu Feb 19, 2009 11:09 pm    Post subject: Reply with quote
i saw these on a baja not to long ago they dont seem to hard to make and they use the same mirror as the clamp on style
GA_Boy
GA_Boy is offline
PostPosted: Fri Feb 20, 2009 7:22 am    Post subject: Reply with quote
I'm not sure if you are interested in fold back mirrors but here a a site that had all kinds.
Marvin
http://search.am-autoparts.com/search?p=Q&lbc=...;view=grid
kbwakesk8
kbwakesk8 is offline
PostPosted: Fri Feb 20, 2009 11:08 am    Post subject: Reply with quote
By kbwakesk8 at 2007-11-15
By kbwakesk8, shot with i533 at 2007-11-15
I built mine in about an hour.
GhiaBateman
PostPosted: Tue Feb 24, 2009 11:06 am    Post subject: Reply with quote
here is another custom mount that i saw, reposting it, don't remember which Sambaian made it, sorry...
Fozz28
Fozz28 is offline
PostPosted: Thu Mar 26, 2009 3:15 pm    Post subject: Reply with quote
Thanks for all the input. I got mine fabricated and when I get them installed I will post up some pics of what I came up with. Gotta love 1 off custom stuff!!
Don't have them installed yet as I am still waiting for my new doors. But this gives ya a good idea of what I came up with. My plan is to pop rivit them to the door.
Whaaahoooo!!!!
Fozz28
Fozz28 is offline
PostPosted: Mon Apr 20, 2009 9:58 am    Post subject: Reply with quote
ok got them on the car finally. Thanks for the ideas.
Whaaahoooo!!!!
sxuxrxf
sxuxrxf is offline
PostPosted: Mon Apr 20, 2009 10:44 am    Post subject: Reply with quote
That looks great!
(ignore the X's )
Robkal
Robkal is offline
PostPosted: Tue Oct 02, 2018 11:06 am    Post subject: Re: Off road mirror mounts Reply with quote
Are those really functional? better or worse than stock?
Cody Loren
Cody Loren is offline
PostPosted: Tue Oct 02, 2018 2:46 pm    Post subject: Re: Off road mirror mounts Reply with quote
https://www.kartek.com/parts/kartek-off-road-baja-...rrors.html
broken too
broken too is offline
PostPosted: Tue Oct 02, 2018 6:11 pm    Post subject: Re: Off road mirror mounts Reply with quote
Just installed a set from kartek , good product;
