Tyvek Pop Top
archemitis
archemitis is offline
PostPosted: Fri Sep 27, 2013 5:52 am    Post subject: Tyvek Pop Top Reply with quote
I had this idea for a while, and I had a roll of Tyvek Layin around, so I thought I would give it a try. It looks pretty good, and I think it will hold up pretty well as long as the edges where the staples and screws are get reinforced.
We cut 35 foot off the 9x100ft roll. I think 30 would have done it. First I folded over the top about 1 inch and started stapling it into the wood on the top. Went all around, then put on the metal that holds the canvas to the roof. Took some scissors and trimmed off the excess(which is plenty enough to make one more top).
Im going camping next week, so I'll get to see how it works.
Sun went down, so I dont have a finished pic yet, if yall are interested I will take one today if its not raining.
Bendejo
Bendejo is offline
PostPosted: Fri Sep 27, 2013 6:30 am    Post subject: Reply with quote
May get a little moist and sweaty in there, looking forward to your test report.
WendyArmbuster
WendyArmbuster is offline
PostPosted: Fri Sep 27, 2013 6:44 am    Post subject: Reply with quote
I am a huge fan of Tyvek, and I'm interested in seeing how this looks complete. You could sew a window or two in the sides and front pretty easy.
Brian Z
1978 Westfalia
archemitis
PostPosted: Fri Sep 27, 2013 8:52 am    Post subject: Reply with quote
yeah, Im experimenting with using a clothes iron to bond it and might put in a vent at the top. It cost about 20 bucks and took all of about 3 hours. I think it will be good for the cool weather camping im about to do. I just hope I dont wake up in the middle of a storm because it rips apart. It is really strong durable stuff, and its all the rage with survivalists, and prepers.
WendyArmbuster
PostPosted: Fri Sep 27, 2013 12:57 pm    Post subject: Reply with quote
I built a tent out of it when I hiked the Appalachian Trail, and it held up wonderfully, even after daily foldings for 3 months.
Brian Z
1978 Westfalia
archemitis
PostPosted: Fri Sep 27, 2013 6:38 pm    Post subject: Reply with quote
Heres about as good as I could get it to look. I think it will work well.
notchboy
notchboy is offline
PostPosted: Fri Sep 27, 2013 7:32 pm    Post subject: Reply with quote
We should see whos experiment will last longer. Your Tyvek or my windshield repair Razz
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
curtis4085
curtis4085 is offline
PostPosted: Sat Sep 28, 2013 3:54 am    Post subject: Reply with quote
The lower aluminum bracket actually goes on the inside of the tent not the out side. I see lots of rain infiltrating those screw heads in that exposed track.
Do over!! Shocked
Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com
archemitis
PostPosted: Sat Sep 28, 2013 7:02 am    Post subject: Reply with quote
hmmm. my 78 is on the outside too, always worked great untill it ripped. must not be original. The doubled up Tyvek combined with the fabric tape I used should compress enough to make a water tight seal.
Ps, I would rather install a new windshield than redo a pop top =]
notchboy
notchboy is offline
PostPosted: Sat Sep 28, 2013 8:48 am    Post subject: Reply with quote
Ive done both a couple of times and they both are kinda arduous tasks with big pay offs Confused
Laughing
1964 1500 S
tristessa
tristessa is offline
PostPosted: Sat Sep 28, 2013 1:00 pm    Post subject: Reply with quote
Pop top doesn't scare me, and yes I've done one. Windshields .. I'll take the old one out, I'll do the repair & prep work, and let the glass guy wrestle with the new one. That way if it breaks going in, not my problem. Laughing
archemitis
PostPosted: Sat Sep 28, 2013 7:51 pm    Post subject: Reply with quote
These windshields are the easiest I have ever installed. All you need is about 14 feet of 16 or so gauge primary wire and a spray bottle full of soapy water. They actually just fall right in!
Grab a new plunger for good measure. Very Happy
archemitis
PostPosted: Sat Oct 05, 2013 12:33 pm    Post subject: Reply with quote
Just got back from a camping trip. 2 guys and 3 dogs. It was the windiest camping conditions I've ever been in and it held up great. It does not breath at all, so the first night I woke up to a few rain drops coming off of the top, so I dried it off with a towel and cracked a smoker window, and a camper window, to get a little flow. It rained the whole three days and nights we were there and didnt spring one leak.
In short, it seems really durable but not one bit breathable. Fun experiment for minimum cost. Plus, nobody makes a white canvas one!
djspn
djspn is offline
PostPosted: Sat Oct 05, 2013 3:00 pm    Post subject: Reply with quote
arch......do you think it would be breathe if the "TYVEK" side was on the exterior, like on a house?
Peace
'71 Bus .....stock running gear [ex SVDA and pertronix]
archemitis
PostPosted: Sat Oct 05, 2013 6:13 pm    Post subject: Reply with quote
I dont think so, It says HDPE (High Density Poly Ethylene), and Water/Air barrier. I'm pretty sure it breathes just like clear plastic sheeting, its just alot more durable.
Lionhart94010
Lionhart94010 is offline
PostPosted: Sat Oct 05, 2013 10:14 pm    Post subject: Reply with quote
TYVEK can be installed either way, it breaths the same, very little, just enough to let moisture out very slooooooowly :0)
Current VWs 71 T2 Westy SO-72/6(Miami), 71 Crew Cab, 2015 GSW TDI
Other owned VW’s 59, 68 1500s, 69 & 71 Bug’s; 72 & 73 S-Bug’s; 67 Westy, 67 Deluxe, Other 71 DC, 72 KG GT that now lives in Australia, 12 JSW TDI, 2015 GSW TDI, 2023 Tiguan
VW technical information sights
thesamba - www.ratwell.com - www.shoptalkforums.com/ - www.vw-resource.com - http://www.type2.com/
http://bobhooversblog.blogspot.com/ - www.aircooled.net/gnrlsite/resource/articles.htm
