metoooo Samba Member
Posted: Fri May 11, 2012 3:27 am Post subject: Short KYB rear shocks |
Hi,
It was time for me to replace the rear shocks of my DC.
After alot of research I've decided to go for the KYB gas-a-just (KG-5530)
Today I've installed the new shock and found out that they are too short!
I have to lift the rear wheel for about 3cm in order to install the shocks, and after I've installed them, the rear wheel assembly is resting on the shocks and not on the spring plate stopper when the car is lifted.
My concern is that the shocks will blow out. Am I right????
Should it be this way?
KYB - KG5530
Spring plate not resting on stopper when lifted
Shock too short
ccpalmer Samba Member
Joined: September 17, 2006 Posts: 3851 Location: Ann Arbor, Michigan
Posted: Fri May 11, 2012 4:07 am Post subject: |
I just installed the exact same shocks in my '71 yesterday - no fitment issues. Mine were a different color though... kind of a goldish color... _________________ '71 Westy |
Posted: Fri May 11, 2012 4:16 am Post subject: |
ccpalmer wrote: |
I just installed the exact same shocks in my '71 yesterday - no fitment issues. Mine were a different color though... kind of a goldish color... |
That's strange... I have problem fitting the shocks on both sides.
Could DC have different suspention travel then regular bus ?
I've compared the KYG's to the original Sasch shocks that I've removed, The Sasch shocks are much longer. I'm sure now that I'm going to blow them! |
Posted: Fri May 11, 2012 4:35 am Post subject: |
metoooo wrote: |
Could DC have different suspension travel then regular bus ? |
I don't think so... where did you get your shocks? _________________ '71 Westy |
Posted: Fri May 11, 2012 4:44 am Post subject: |
ccpalmer wrote: |
metoooo wrote: |
I don't think so... where did you get your shocks? |
eBay -> http://www.ebay.com/itm/330651755579
They look original and the part number is the one for the T2 bus's
Posted: Fri May 11, 2012 4:51 am Post subject: |
The box looks the same as mine...
Any custom/strange things going on with your rear suspension? _________________ '71 Westy |
Posted: Fri May 11, 2012 4:54 am Post subject: |
ccpalmer wrote: |
Any custom/strange things going on with your rear suspension? |
No, my DC is all original. No modification at all. The Sachs shocks that I've replace have the VW sign and part number on them |
Posted: Fri May 11, 2012 4:58 am Post subject: |
metoooo wrote: |
ccpalmer wrote: |
Hmmm; maybe measure the shock when it is extended and call KYB? _________________ '71 Westy |
Posted: Fri May 11, 2012 5:15 am Post subject: |
If it's going to help any one solving my problem, here is a picture of the original shock that I've replaced:
Posted: Fri May 11, 2012 5:51 am Post subject: |
Another fact that I've found out:
VW stantard extanded shock length : 585mm
KYB KG5530 extanded shock length: 558mm
The KYB is 27mm short!!!!! Why they sell it everywhere as a direct replacement? |
bugger101 Samba Member
Joined: September 04, 2010 Posts: 1559 Location: orlando
rustbus Samba Member
Posted: Fri May 11, 2012 6:12 am Post subject: |
freakin ebay. i just bought a fuel level sender from there.. "genuine German" only to have the wrong part inside the box and have to argue with the seller cause "it wasn't his fault, his supplier must have packed it wrong"
best of luck getting squared up on your deal. _________________ May of '72 Deluxe. 2.0L L-Jet CS & 091 trans conversion
my Bus thread |
Posted: Fri May 11, 2012 3:07 pm Post subject: |
I lied - the gas-adjusts I put in were gunmetal/aluminum colored.
On the side of the box the label reads KG5530 then on the line below it reads 554060... _________________ '71 Westy |
Posted: Mon May 14, 2012 12:22 am Post subject: |
Well, I did on Saturday a 100KM trip, no shock blow out so far. But I start the hunt for Sachs rear shocks. Nothing beats ORIGINAL ! |
fon Samba Member
Joined: July 23, 2010 Posts: 97 Location: San Juan, Puerto Rico
Posted: Mon May 14, 2012 4:06 am Post subject: |
metoooo wrote: |
Koni is a good choice  |
drober23 Samba Member
Joined: April 01, 2009 Posts: 787 Location: Detroit, MI
Posted: Mon May 14, 2012 5:42 am Post subject: |
Busdepot has BOGE German shocsk, Sachs, and Koni if your are still looking. _________________ DJ
'75 Westfalia, '79 Deluxe, and some others...
(more busses than sense)
In a time of chimpanzees I was a monkey |
The real Curly Samba Member
Posted: Fri Mar 10, 2017 2:42 am Post subject: Re: Short KYB rear shocks |
Does anyone know what color the shocks were from the factory in 1975? _________________ 1975 Baywindow Riviera Camper
1931 Model A truck (Model A folks are smart and handsome) |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5173 Location: California's Hot and Smoggy Central Valley
Posted: Fri Mar 10, 2017 12:53 pm Post subject: Re: Short KYB rear shocks |
The real Curly wrote: |
Does anyone know what color the shocks were from the factory in 1975? |
Not me, but both my '73 and '78 had the green ones like above. |
