Oettinger Short Shifter
Page: 1, 2, 3  Next
Texbug
Texbug is offline
PostPosted: Fri Sep 15, 2006 7:20 pm    Post subject: Oettinger Short Shifter Reply with quote
Does anyone out there know where I can find an Oettinger Sport Shifter for my '54 Rag?
53 0val
Samba Professor
53 0val is offline
PostPosted: Fri Sep 15, 2006 7:36 pm    Post subject: Re: Oettinger Short Shifter Reply with quote
No.........I've been looking for that for a couple years myself. Confused
thai56oval
thai56oval is offline
PostPosted: Fri Sep 15, 2006 8:10 pm    Post subject: Reply with quote
Anyone got pic of this sport shifter ? Thanks.
Texbug
Texbug is offline
PostPosted: Sat Sep 16, 2006 6:02 am    Post subject: Reply with quote
David Orozco's '53 Zwitter has one in it. Check out page 62 in the July 2006 issue of Hot VWs.
RareAir
RareAir is offline
PostPosted: Sat Sep 16, 2006 7:25 am    Post subject: Reply with quote
Looks just like the Empi sport shifter for 1968-later beetles. But the shaft cover is solid (no holes) and is designed for use on the 1950-55 thinner shafted shifters. Basically, it has a round washer just under the shift knob to act as a handle when you depress the shifter to select reverse gear.
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
pbaptist
pbaptist is offline
PostPosted: Thu Jan 15, 2009 3:13 pm    Post subject: Reply with quote
Any pictures for this?
Somebody offered me this "thing" that he called Oettinger shifter.
Is this a oettinger sport shifter???
If not, what is it?!
Dutch Karmann-Ghia and coachbuild lover.
1* Karmann Ghia Coupe (1966 Teak)
2* Karmann Ghia Convertible (1958, 1971)
4* Rometsch Lawrence (nr 534, 555, 558 and 561)
Karmann-Ghia Lowlight page and registry
Karmann-Ghia Collectibles database
53 0val
Samba Professor
53 0val is offline
PostPosted: Thu Jan 15, 2009 4:22 pm    Post subject: Reply with quote
I haven't seen that particular "model" before. It is not the one referred to in the previous posts.
RareAir
RareAir is offline
PostPosted: Thu Jan 15, 2009 11:38 pm    Post subject: Reply with quote
That looks like it to me. Want to sell it?
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
53 0val
Samba Professor
53 0val is offline
PostPosted: Fri Jan 16, 2009 12:02 am    Post subject: Reply with quote
Is it missing the top (knob)?
pbaptist
pbaptist is offline
PostPosted: Fri Jan 16, 2009 12:30 am    Post subject: Reply with quote
It is not mine, It was offered to me for sale.
Yesterday, I bought some ghia parts from a local guy here and he offered me this shifter as well as some other rare (oval) parts. (double mirror, empi bumperbars, a mirror that you can clamb on your door, VDO tachometer for oval, oval convertible deck lid). I didn't bought any of it, since I am only interested in ghia parts.
I have a lowlight ghia with Okrasa engine and he said the shifter was an period correct option from Okrasa. I told him that I first wanted to find out if this shifter was indeed what he said it was and if it was a period correct option in 1958 for a ghia
I found this picture on page four of this topic http://www.thesamba.com/vw/forum/viewtopic.php?t=292110&start=60
So now I know it is a Oettinger reverse lock out.
But than the usual question, What is it worth? and was this shifter also offered for the ghia
Patrick
joe h.
joe h. is offline
PostPosted: Fri Jan 16, 2009 7:42 am    Post subject: Reply with quote
Those are VERY rare. I have seen three......well, four with this one. It's missing the plate, but you could make one. What it's worth is a good question. Hard to say being they never go up for sale.
What is the RPM range on that tach?
53 0val
Samba Professor
53 0val is offline
PostPosted: Fri Jan 16, 2009 3:31 pm    Post subject: Reply with quote
I think it's missing more than the plate. Confused
RareAir
RareAir is offline
PostPosted: Fri Jan 16, 2009 4:10 pm    Post subject: Reply with quote
You remove the shifter off the center tunnel.
Remove the knob on the stock shifter.
Slide the Oettinger over the stock shifter shaft
Replace the base of the shifter
Reinstall the knob
Bolt down the complete assembly to the tunnel
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
53 0val
Samba Professor
53 0val is offline
PostPosted: Fri Jan 16, 2009 5:18 pm    Post subject: Reply with quote
Thanks Glenn Wink
joe h.
joe h. is offline
PostPosted: Fri Jan 16, 2009 9:05 pm    Post subject: Reply with quote
Reinstall the knob
Not bad Glenn, but not quite right.
"Reverse lock out Schaltfix
1. Take off shift knob (1).
2. Take off bolts (9).
3. Pull shift lever (5) out of rubber boot (6) and collar (7).
4. Insert shift lever (5) in “Schaltfix”-tube (4)
5. Insert shift lever (5) and tube (4) in shift collar (7).
6. Put washer (10) on top of lockout plate (12) and base (11). Spring (8 ) MUST clear the hole of washer (10) and NOT be on top of the washer.
7. Attach shift collar (7) using bolts (9).
8. Screw knob (2) onto on to tube (4). Felt ring (3) must not get damaged by threads of shift lever (5).
9. Screw on shift knob (1)."
It is missing the plate, nothing else. Wink
53 0val
Samba Professor
53 0val is offline
PostPosted: Fri Jan 16, 2009 11:30 pm    Post subject: Reply with quote
Reinstall the knob
Thanks..................now I want one again. Sad
pbaptist
pbaptist is offline
PostPosted: Wed Jan 28, 2009 1:49 pm    Post subject: Reply with quote
I was intented to buy it for my okrasa powered oldspeed ghia, but the shifter was sold for €220 during my vacation.
Was that a reasonable prize for this??
Patrick
joe h.
joe h. is offline
PostPosted: Wed Jan 28, 2009 4:50 pm    Post subject: Reply with quote
Like the saying goes.......... you snooze ya lose.
I would bet either Bob or Glenn bought it. Wink
You really have two choices for any rare accessory. You could wait for someone who doesn't know the value and hope to be the first to grab it, or you pay top dollar to someone who does know the value. It's a matter of how bad you want it.
BTW, someone would have to give me a ridiculous amount of cash for me to part with mine.
RareAir
RareAir is offline
PostPosted: Wed Jan 28, 2009 8:10 pm    Post subject: Reply with quote
Nope, not me Sad
What's considered "a ridiculous amount of cash" these days?
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
kdf38
kdf38 is offline
PostPosted: Wed Jan 28, 2009 8:28 pm    Post subject: Reply with quote
$100 these days. It's equivalent to what $1000 was 7 months ago.
Nope, not me Sad
Page: 1, 2, 3  Next
