1961 hood changes?
tylergeddis
tylergeddis is offline
PostPosted: Sat Aug 23, 2008 2:18 pm    Post subject: 1961 hood changes? Reply with quote
Can some one please list the changes in hoods by the year. Is a 1961 hood 4 tab?
50ate
50ate is offline
PostPosted: Sat Aug 23, 2008 2:51 pm    Post subject: Reply with quote
the 4 tab stoped mid 61 so yes your car could be correct with a 4 tab
NOTAHONDA
Vegas Don
NOTAHONDA is offline
PostPosted: Sat Aug 23, 2008 3:03 pm    Post subject: Reply with quote
The last 61 to get a 4 tab was #3 551 045
downtoearth
downtoearth is offline
PostPosted: Sun Aug 24, 2008 10:54 am    Post subject: Reply with quote
i have a 61 rag with the early s.n. so I think I have a "4 tab" could you explain thanks Embarassed
HerrrKafer
HerrrKafer is offline
PostPosted: Sun Aug 24, 2008 11:01 am    Post subject: Reply with quote
There's 4 slots for the VW emblem to mount to the hood. Also it's flat in that area, later hoods had a raised circle where the emblem mounts.
Evan H.
In a perfect world, anyone running chromies would be shot.
RareAir
RareAir is offline
PostPosted: Sun Aug 24, 2008 12:12 pm    Post subject: Reply with quote
Late 1961-early '63 hoods still featured the flat plinth area, but the hood emblem was now a 3-pin style.
HerrrKafer
PostPosted: Sun Aug 24, 2008 12:14 pm    Post subject: Reply with quote
D'oh. Sorry.
Evan H.
Steve Sheffield
Steve Sheffield is offline
PostPosted: Sun Aug 24, 2008 12:26 pm    Post subject: Reply with quote
Is it possible to have a 62 3 tab hood that has a raised area for the emblem?
HerrrKafer
PostPosted: Sun Aug 24, 2008 1:11 pm    Post subject: Reply with quote
No, what RareAir posted is the correct info. You should have a three-hole hood without the raised section. The emblem that goes on it is actually the 4-tab style emblem but with a plastic insert with the three pins.
Evan H.
veedubs61
veedubs61 is offline
PostPosted: Mon Sep 15, 2008 7:44 am    Post subject: Reply with quote
WOW i never knew this, i have a 61 and can not find an emblem to save my life, and just today i saw an add for one that was a 4 tab with a plastic insert, then i came across this, its like a sign from above ha a vw sign!! do they sell the insert seperate?
Slow and Low
"use the search" does not answer my question
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Mon Sep 15, 2008 7:52 am    Post subject: Reply with quote
No they don't sell the insert separately, not that I've ever seen at least.
Actually someone makes, or at least,used to make, at mid 61-early 63 smaller emblem in a "solid" style, I bought one at a swap meet a few years ago:
(Also, in a pinch, if you modify one of the three mounting holes, you can make a type 3 emblem work on there.)
-Andy
bill may
bill may is offline
PostPosted: Mon Sep 15, 2008 8:53 am    Post subject: Reply with quote
no- but a 63 (after oct1962)-66 hood could have been fitted.
Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617
