Vanderhiem Samba Member
Posted: Tue Aug 03, 2004 7:08 pm Post subject: cool tin |
I was wondering if I use the cool tin that you put under the cylinders prior to installing the pushrods do you still use the lower tin and deflectors that are secured in between the center head studs. Thanks for any help |
bread Samba Member
Posted: Thu Aug 05, 2004 1:03 pm Post subject: |
You do not use the air deflectors if you are using the type 4 style cooling tin between the cylinders and pushrods. I have those on one of my engines and I have the lower tin on it (the tin that attaches to the heat exchangers). |
Doppelganger Samba Member
Joined: May 30, 2004 Posts: 248 Location: Mid TN, SoCal native.
Posted: Thu Aug 05, 2004 3:02 pm Post subject: |
@juno, are you referring to super cool tins? Are you putting this in a type1 engine setup? _________________ Life starts at drop of the clutch. |
Posted: Thu Aug 05, 2004 4:52 pm Post subject: cool tin |
Yes its the super cool tin sold by scat and bugpack. It installs under the cylinders prior to the push rod tubes. |
ROADKILL Samba Member
Joined: July 22, 2004 Posts: 347 Location: Gilbert, Arizona
Posted: Thu Aug 05, 2004 7:47 pm Post subject: |
I used that setup here in the desert along with a type iv cooler
in my 67 camper fully loaded and it works good even in 110+ heat. |
bugnut68 Samba Member
Joined: June 10, 2003 Posts: 4180 Location: Eugene, OR
Posted: Thu Aug 05, 2004 8:09 pm Post subject: |
Use Type 1 deflectors. Those "cool tin" are designed for Type III engines...different cooling system design. Check with Jake Raby on this one, he's done some testing and can probably offer a bit more insight. |
Jake Raby Samba Member
Joined: August 23, 2003 Posts: 7433 Location: Aircooled Heaven USA
Posted: Thu Aug 05, 2004 10:23 pm Post subject: |
Read the article i wrote on it here
http://www.superbeetles.com/Tech_talk/jan2.htm
It touches on Type IV and Type I....
You can thank "Johnnies speed and chrome" for those tins, and the stories that surround them. _________________ Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell" |
Posted: Fri Aug 06, 2004 2:57 pm Post subject: cool tin |
Thanks Jake I will use the stock deflectors. Good article!!! Thanks again |
