Self cancelling turn signal assembly
mustafakidd
mustafakidd is offline
PostPosted: Fri Jul 31, 2020 2:49 pm    Post subject: Self cancelling turn signal assembly Reply with quote
Hey all
My turn signal on my 66 wasn't working, so I got a replacement (German) and installed it. Works great now but it doesn't self cancel - is the canceling ring something that I can replace or does the entire assembly need to get swapped out? Couldn't tell if it was supposed to be within the assembly housing or something that the housing slides over.
Thanks
-m
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Fri Jul 31, 2020 3:34 pm    Post subject: Re: Self cancelling turn signal assembly Reply with quote
you should be able to trigger the self cancel yourself with a screwdriver before you install the steering wheel.
The cancel ring on the steering wheel almost never goes bad.
Now, you do need to have the switch mounted in such a way that the two mesh, the switch on the column tube and the steering wheel should result in in only a small gap between the two:
Andy T.
MrGoodtunes
MrGoodtunes is offline
PostPosted: Fri Jul 31, 2020 4:13 pm    Post subject: Re: Self cancelling turn signal assembly Reply with quote
My 1965 has a signal canceller that attaches to the steering wheel hub. It has a tab that trips the cancelling mechanism.
The Android
PostPosted: Fri Jul 31, 2020 4:22 pm    Post subject: Re: Self cancelling turn signal assembly Reply with quote
Yeah, that is pretty much on every VW made 1960 to 1970 steering wheel, and while I did link to an image showing it above, it's so common to see I didn't think putting the image in directly was necessary.
However, that begs the question: is this a VW steering wheel or non-stock? Non stock steering wheels may have a couple of dowel pins for this function, or they might not even be there at all.
Andy T.
MrGoodtunes
PostPosted: Fri Jul 31, 2020 5:03 pm    Post subject: Re: Self cancelling turn signal assembly Reply with quote
glutamodo wrote:
... I did link to an image showing it above ...
Oops, indeed you did; totally miss'd it. Embarassed You're pretty thorogh there glutamodo.
The Android
PostPosted: Fri Jul 31, 2020 5:19 pm    Post subject: Re: Self cancelling turn signal assembly Reply with quote
No worries dude. We're both just trying to help after all!
Andy T.
mustafakidd
PostPosted: Sat Aug 01, 2020 1:35 am    Post subject: Re: Self cancelling turn signal assembly Reply with quote
Thanks to you both. It's not a stock steering wheel - I'll pull it again tomorrow and see if it has a canceling ring on it or not.
The Android
PostPosted: Sat Aug 01, 2020 1:49 am    Post subject: Re: Self cancelling turn signal assembly Reply with quote
One of my images above showed what might be construed as a non-stock steering wheel, but it's actually a VW accessory steering wheel from way back. So the horn and self-cancel bits conform to VW specifications.
But non-stock steering wheels are a whole another can of worms.
Andy T.
mustafakidd
PostPosted: Sun Aug 02, 2020 12:35 pm    Post subject: Re: Self cancelling turn signal assembly Reply with quote
Thanks again for the assistance - I took the steering wheel off (it's a repro, similar to this one https://www.jbugs.com/product/113-WHEEL-BLACK.html...gKd2vD_BwE ) and realized it did not have the canceling ring installed!
Thanks again
The Android
PostPosted: Sun Aug 02, 2020 12:42 pm    Post subject: Re: Self cancelling turn signal assembly Reply with quote
Cool, you figured it out. I guess I should have stuck the image of the cancel ring in directly! And if it's equivalent to stock, I assume that the mounting holes for the cancel ring are present.
Andy T.
mustafakidd
PostPosted: Tue Aug 04, 2020 3:29 pm    Post subject: Re: Self cancelling turn signal assembly Reply with quote
Yes the mounting holes (threaded) are in place already, my ring fit on perfectly - just a matter of getting the clearance between the steering wheel and turn signal assembly right so the ring fits into the assembly enough to trigger the canceling springs.
sidtheleaper28
sidtheleaper28 is offline
PostPosted: Thu Aug 06, 2020 6:41 pm    Post subject: Re: Self cancelling turn signal assembly Reply with quote
mustafakidd wrote:
Hey all
Thanks
-m
where did you get the german turn signal from?
