PDX_Hops Samba Member
Joined: March 24, 2006 Posts: 22 Location: Missing PDX in SC
Posted: Fri May 12, 2006 12:53 pm Post subject: Thoughts on replacing Westy water tank? |
I can't put my new Westy's sink to use because the water tank leaks. I'm thinking about getting a replacement, but it seems like it might be a bit of a pain (because of the tight space and hooking up the pump, etc.).
Anybody out there replaced their tanks? How much of a hassle was it? I am lazy and will do without for now if I have to.  _________________ '76 Westy Weekender- "Fran" |
GreenBrick Samba Member
Joined: February 08, 2006 Posts: 967 Location: Salt Lake City, Utah
Posted: Fri May 12, 2006 1:42 pm Post subject: |
I had to remove the cabinet and take the tank out from the back. I tried it out thru the front, without removing the cabinet, but the tank was too long.
Make sure the filler piece that goes thru the cabinet top into the tank can be removed in one piece. Mine was stuck in there tight. _________________ Steve
'78 Westfalia 2.0L FI (Abigail) R.I.P. |
steponmebbbboom Samba Member
Posted: Fri May 12, 2006 2:53 pm Post subject: |
What's the tank look like? You might find one that's close at an RV parts dept. |
BIGTSV Samba Member
Joined: August 03, 2005 Posts: 593 Location: Columbus Ohio
Posted: Fri May 12, 2006 3:10 pm Post subject: |
A lil off topic, but my Dad thought that replacing the water tank with a pony keg and then the sink would be a beer tap. Thought it was a good idea in a way!  _________________ 1989 VW White Star
English made DR Martens |
jberger Samba Member
Posted: Fri May 12, 2006 3:16 pm Post subject: |
The tank is removable from the front, the pump and drain valve thread out and the cabinet panels in front of it are removable. Take it out and inspect it, you may be able to repair it with a PVC epoxy. |
Posted: Fri May 12, 2006 3:17 pm Post subject: |
as long as it fits in the space,
I would remove the icebox while Im at it and just insulate the area to keep things cold. You could pack dry ice pellets around the keg to keep it chilled, they last awhile. Id be down for soing something like this if I found another combo cabinet for cheap. |
WestyPop Samba Member
Joined: February 08, 2005 Posts: 1734 Location: SoCal
Posted: Fri May 12, 2006 7:13 pm Post subject: |
Seriously looking at an underbelly tank (about 18 gallons) to replace the (5 gallon?) factory unit, and possibly even an 'on board' grey water tank, also 'basement' mounted.
Main reasons (personally) to go below (mounted between frame rails) are to lower the Westy's center of gravity (for less sway in corners) and to make more camping room inside. Will work up an outside water tank input port, also more convenient than running a hose inside to fill the factory tank. The RV industry has a wide variety of sizes & shapes available. Most are baffled to prevent water from rapidly shifting from back & forth inside the tank.
Just seems like it will make improvements to our unit. YMMV
J.R.
68 Westy
(+ others) |
Bob D. Samba Member
Joined: September 11, 2003 Posts: 613 Location: Chicago, IL
Posted: Fri May 12, 2006 10:12 pm Post subject: |
WestyPop wrote: |
Seriously looking at an underbelly tank (about 18 gallons) to replace the (5 gallon?) factory unit, and possibly even an 'on board' grey water tank, also 'basement' mounted. |
Very cool idea IMHO. Please keep us posted and show some pics, if you decide to go ahead with this. _________________ 1978 7-Passenger, 37K miles
Proud Member #1, SBS (Stock Bus Society)
*Enjoy and appreciate your good health*
We used to play for silver
Now we play for life |
Tim Samba Member
Joined: September 04, 2003 Posts: 170 Location: Texas
Posted: Sat May 13, 2006 1:40 pm Post subject: |
I am not sure about later model Westies but Inca Plastics made the original plastic tanks for VW"s. Here is the thread about the replacement for my '67. I bet they have the later tanks as well.
http://www.thesamba.com/vw/forum/viewtopic.php?t=103460&highlight=water+tank _________________ How we spend our days is, of course, how we spend our lives.
Annie Dillard
55 Rag Top
67 Westy |
renobdarb Samba Member
Joined: September 13, 2005 Posts: 878 Location: Eastern Idaho
Posted: Sat May 13, 2006 2:23 pm Post subject: |
WestyPop wrote: |
Seriously looking at an underbelly tank (about 18 gallons) to replace the (5 gallon?) factory unit ... |
Wouldn't that be really heavy? A gallon of water weighs 8.35 pounds, so you're looking at more than 150 pounds just for water. That's like hauling around an extra person. Besides, filling up the factory tank (7 gallons) every day or two isn't really that big of a chore. Just my $.02. _________________ ----------
1978 Campmobile, 2000cc w/hydro lifters, dual Weber 44 IDF carbs (50 idle jets, 115 main jets), SVDA distributor w/Compufire. |
Posted: Sun May 14, 2006 11:24 am Post subject: |
renobdarb wrote: |
WestyPop wrote: |
Wouldn't that be really heavy? A gallon of water weighs 8.35 pounds, so you're looking at more than 150 pounds just for water. That's like hauling around an extra person. Besides, filling up the factory tank (7 gallons) every day or two isn't really that big of a chore. Just my $.02. |
There have been a few trips where having an extra 10 gallons of known potable water was helpful or even necessary. The tank doesn't have to be filled all the time, and not needing to have separate 5 gallon storage containers to pack would be nice. Many of us put those jerry cans up in the roof-mounted storage racks(BTDT), and that adds to the sway of the bay. IMHO the handling characteristics just aren't as big an issue for some folks as for others. It IS a personal trade-off thing, like most modifications, or even the decision to leave a vehicle bone stock OG.
J.R.
68 Westy
(+ others) |
Posted: Sun May 14, 2006 9:30 pm Post subject: |
Thanks for the all the input and options, everybody. This definitely helps me out. _________________ '76 Westy Weekender- "Fran" |
pawesty Samba Medic
Joined: June 28, 2003 Posts: 1545 Location: Northern Vermont
Posted: Sun May 14, 2006 10:07 pm Post subject: Re: Thoughts on replacing Westy water tank? |
PDX_Hops wrote: |
Anybody out there replaced their tanks? How much of a hassle was it? I am lazy and will do without for now if I have to.  |
are you certain it's the tank leaking and not where the pump screws into tank? did you try rewrapping the pump with some teflon and snugging it back in? in 15 years i've never seen one of these tanks leak.
dave _________________ "Go smell the wind, go far. Hear the marvelous strange chime of midnight" Kerouac
79 westy
78 westy
purveyor of refurbed westies and parts!!! inquire within!
pawesty Samba Medic
Posted: Tue May 16, 2006 4:50 pm Post subject: |
where are you at with this? _________________ "Go smell the wind, go far. Hear the marvelous strange chime of midnight" Kerouac
79 westy
78 westy
Posted: Wed May 17, 2006 1:00 pm Post subject: |
pawesty wrote: |
where are you at with this? |
I'm actually travelling right now (via plane, not bus), so I'm just gathering info. I think I will be replacing the tank no matter what, as I'd forgotten I found lots of "stuff" in the tank- assorted debris and garbage with who knows what sorts of cooties attached. What are things like plastic forks doing in the tank??? Beats me, but I'm gonna start with a clean slate. _________________ '76 Westy Weekender- "Fran" |
Posted: Wed May 17, 2006 1:06 pm Post subject: |
PDX_Hops wrote: |
pawesty wrote: |
I'm actually travelling right now (via plane, not bus), so I'm just gathering info. I think I will be replacing the tank no matter what, as I'd forgotten I found lots of "stuff" in the tank- assorted debris and garbage with who knows what sorts of cooties attached. What are things like plastic forks doing in the tank??? Beats me, but I'm gonna start with a clean slate. |
If you are worried about cooties, you may want to drive something other than a former hippie's mobile, screw, sleep, smoke, eat, live, surf den.
Just a thought. |
