1z conversion, cooling questions
yggdrasil
yggdrasil is offline
PostPosted: Fri Feb 17, 2023 5:31 pm    Post subject: 1z conversion, cooling questions Reply with quote
Hi, a few questions.
I am doing a 1z conversion and the hoses that go to the oil cooler are in the way of the motor mount.
If you have a solution for this let me know.
I have determined based on this awesome diagram that i need to plumb in the oil cooler from a different location.
Also looking at this diagram, does anyone know the part number for the hilighted hose?
I am also curious if there is a way to delete the third, lowest water pump intake. I think the bottom two are returns and the top is the pump outlet.
ALIKA T3
ALIKA T3 is offline
PostPosted: Fri Feb 17, 2023 7:00 pm    Post subject: Re: 1z conversion, cooling questions Reply with quote
Oil cooler hoses are not in the way if you use the late T3 1.6 TD engine code JX hoses.
Do not plug the water pump.
For the thermostat hook up, either use the T3 elbow, which is at 45° to clear the engine mount, if you don't have an AC compressor, or the Tdi 90° elbow up and fabricate something to connect the JX hose, that will prolly have to alter in this case.
The hose you're looking for is found on 4 cylinder AAZ on T4 for example.
028121053N.
Looks like you already have the plastic flange from the Audi 80 with no nipple, that's good!
valvecovergasket
valvecovergasket is offline
PostPosted: Fri Feb 17, 2023 7:55 pm    Post subject: Re: 1z conversion, cooling questions Reply with quote
Hey that looks an awful lot like my motor haha
That hose is off all the non oil cooler equipped early mk1/2 stuff
Don't block off the lower port.
ALIKA T3
ALIKA T3 is offline
PostPosted: Sat Feb 18, 2023 10:14 am    Post subject: Re: 1z conversion, cooling questions Reply with quote
Incorrect. The 1.6L hose may look the same but is shorter. The 1.9L block is a bit taller by about 13mm.
Some aftermarket make one version for both, and you trim it but there's no way to know before you buy and try unless somebody did it and documented it.
The part number starts with 028, that tells you it's specific for the 1.9 and alike.
The older hose would be 068 for 1.6. 068121053M. 121 is for cooling parts group btw.
valvecovergasket
PostPosted: Sat Feb 18, 2023 12:32 pm    Post subject: Re: 1z conversion, cooling questions Reply with quote
Thats a good tip
I remember having to trim the last couple of those I installed, including the one in that picture - so I'm not sure if the aftermarket ones I've been ordering are just too long by design now
When I'm not on my phone I can find the p/n of that one in the picture...
edit - heres the one i ordered
068121053M
https://www.fcpeuro.com/products/vw-audi-engine-coolant-hose-068121053mmy
ALIKA T3
ALIKA T3 is offline
PostPosted: Sun Feb 19, 2023 4:16 pm    Post subject: Re: 1z conversion, cooling questions Reply with quote
Yes that's what I think, they make one that fits both, just print a different part number on them.
