SPLITV Samba Member
Posted: Tue Feb 21, 2023 5:38 pm Post subject: Light Improvements, Front and Rear. |
Has anyone got any suggests to improve the lights on a 58 Van (Small Rear Lights).
Running 12V already.
How would you split the wiring to stop a new set indicating.
Front lights are terrible at night unless on main beam.
Also how many settings should there be for the fronts?
I only seem to have two, lights and main beam.
Would love to see some pictures please.
Cheers. |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 4237 Location: San Diego
Lind Samba Member
Joined: November 06, 2000 Posts: 10273 Location: idaho
Posted: Tue Feb 21, 2023 10:20 pm Post subject: Re: Light Improvements, Front and Rear. |
run separate turn signals mounted on the bumper and add a center brakelight. _________________ .
Wanted:
Clara  Samba Member
Posted: Tue Feb 21, 2023 11:18 pm Post subject: Re: Light Improvements, Front and Rear. |
Yes headlights are low or high beam. That is two settings. Also have running lights, which are not enough to see your way
Without volt drop, six volt headlights are good to see by
Old wires can have volt drop.
Check voltage at lights!
Good ground cable?
Good headlight switch. Does switch get warm? If so it loses voltage
You can run halogen bulbs
Or h4
They are not as bright as modern headlights. Fwiw
You can add reflectors in back to be more visible.
Maybe an Smv magnet _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9831 Location: Exit 7, New Jersey
crofty Judas of the North
Joined: August 09, 2000 Posts: 19915 Location: Land of Whine and Phonies
Posted: Wed Feb 22, 2023 1:03 pm Post subject: Re: Light Improvements, Front and Rear. |
I run H4's on my buses.
Tailight buckets with good reflective insides are a must.
As has been mentioned, good grounds, (i run a ground wire on my tailights), good headlight switch are a must. _________________ Your Vanagon sucks, Stop waving at me.
| HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
SPLITV Samba Member
Posted: Wed Feb 22, 2023 5:04 pm Post subject: Re: Light Improvements, Front and Rear. |
thank you everyone, interesting ideas.
Crofty, how did you install the H4 bulbs?
I like the idea of the light bar, maybe on the bumper. |
dgsaz Samba Member
Joined: November 04, 2008 Posts: 584 Location: Phoenix / San Diego
Posted: Wed Mar 01, 2023 11:50 am Post subject: Re: Light Improvements, Front and Rear. |
I found a great way to add lights to the front bumper. If you go to an industrial hardware store, in the prefab metal tabs for welding. Pick part 181, one per light.
Layout where you want the lights.
Remove the four bolts that hold the overrider. Just a bit of grinding and off to the welder, from there off to the powder coater.
Wait for call, go pick up.
When you get home, take Dremel and expose a quarter sized patch on the bottom of the tab to insure a good ground.
Re-install the override with the same 4 bolts and mount your lights.
img]https://www.thesamba.com/vw/gallery/pix/2371637.jpg[/img]
This can be done even cheaper if you can do your own welding and simply paint the overrider.
The welding tabs are great for what they do. Lots of sizes and shapes.That's what I did.
dgsaz |
Daddybus Samba Member
Posted: Wed Mar 01, 2023 12:13 pm Post subject: Re: Light Improvements, Front and Rear. |
Here are my LED head lights and the "mount" for my driving and fog lights
dgsaz Samba Member
Posted: Wed Mar 01, 2023 12:43 pm Post subject: Re: Light Improvements, Front and Rear. |
Some random dude: Wow, why do have so many lights on the front?
Me: yes. |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12570 Location: Over 2002 posts deleted!
Posted: Wed Mar 01, 2023 5:23 pm Post subject: Re: Light Improvements, Front and Rear. |
| dgsaz wrote: |
Me: yes. |
 _________________ Some people are so busy being clever they don't have time enough to be wise. |
MrPolak Samba Member
Joined: June 20, 2004 Posts: 1385 Location: AG ,atnaltA
Posted: Thu Mar 02, 2023 8:44 am Post subject: Re: Light Improvements, Front and Rear. |
Modern LED tail light bulbs are drop-in, bright and cheap enough. No need for above.
You don't mention what type of front lights you have. Is it an H4 bulb with a fluted lens? There are decent LED options for just about any incandescent application.
Don't run DOT sealed beams, they suck. |
Posted: Thu Mar 02, 2023 9:08 am Post subject: Re: Light Improvements, Front and Rear. |
All my lights are LED.
Parking lights
Driving lights
PatJr Samba Member
Posted: Thu Mar 02, 2023 9:11 am Post subject: Re: Light Improvements, Front and Rear. |
why do you need this?
does it work 4 lead > 5 lead ? _________________ #############################################
1970 Transporter a orange one
Posted: Thu Mar 02, 2023 9:58 am Post subject: Re: Light Improvements, Front and Rear. |
| SPLITV wrote: |
You have to replace the sealed beams with H4 units.
https://www.amazon.com/HELLA-002395991-Type-Single-Headlamp/dp/B0002M9QJM _________________ Your Vanagon sucks, Stop waving at me.
VWAdam Samba Member
Joined: February 14, 2002 Posts: 3351 Location: Birmingham, Alabama
Posted: Thu Mar 02, 2023 4:49 pm Post subject: Re: Light Improvements, Front and Rear. |
| crofty wrote: |
As has been mentioned, good grounds, (i run a ground wire on my tailights), good headlight switch are a must. |
I concur with the H4s. I love them on my Bus. _________________ All he needed was a wheel in his hand and four on the road.
'59 Euro Beetle ragtop
'63 Standard Microbus
Come to my show! www.volksjam.com
Looking for badge/sticker/frame from Western Motors in Great Falls, Montana |
