Light Improvements, Front and Rear.
SPLITV
SPLITV is offline
PostPosted: Tue Feb 21, 2023 5:38 pm    Post subject: Light Improvements, Front and Rear. Reply with quote
Has anyone got any suggests to improve the lights on a 58 Van (Small Rear Lights).
Running 12V already.
How would you split the wiring to stop a new set indicating.
Front lights are terrible at night unless on main beam.
Also how many settings should there be for the fronts?
I only seem to have two, lights and main beam.
Would love to see some pictures please.
Cheers.
chrisflstf
chrisflstf is offline
PostPosted: Tue Feb 21, 2023 8:57 pm    Post subject: Re: Light Improvements, Front and Rear. Reply with quote
Led tail lights. And a good ground
https://www.thesamba.com/vw/classifieds/detail.php?id=1412740
Lind
Lind is offline
PostPosted: Tue Feb 21, 2023 10:20 pm    Post subject: Re: Light Improvements, Front and Rear. Reply with quote
run separate turn signals mounted on the bumper and add a center brakelight.
Wanted:
Clara Premium Member
Clara is offline
PostPosted: Tue Feb 21, 2023 11:18 pm    Post subject: Re: Light Improvements, Front and Rear. Reply with quote
Yes headlights are low or high beam. That is two settings. Also have running lights, which are not enough to see your way
Without volt drop, six volt headlights are good to see by
Old wires can have volt drop.
Check voltage at lights!
Good ground cable?
Good headlight switch. Does switch get warm? If so it loses voltage
You can run halogen bulbs
Or h4
They are not as bright as modern headlights. Fwiw
You can add reflectors in back to be more visible.
Maybe an Smv magnet
j.pickens
j.pickens is offline
PostPosted: Wed Feb 22, 2023 12:28 pm    Post subject: Re: Light Improvements, Front and Rear. Reply with quote
I rigged up an auxiliary 4 pin trailer connector which I run to a LED light strip made for mounting on the rear of a pickup truck. Bought a bunch of 10mm by 60mm neodymium bar magnets and double sided taped them to the LED strip.
Really bright for being safe at night, and you can just pull it off for stock appearance. It sits between the decklid hinges and the rear hatch.
Light bar, 60":
https://www.amazon.com/LivTee-Tailgate-Reverse-Run...GHVZB?th=1
Turn signal adapter for early bus with separate turn and brake circuit:
https://www.amazon.com/gp/product/B08344TSMB/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Neodymium bar magnets:
https://www.amazon.com/gp/product/B09D3D9T3K/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
BeaterBarndoor wrote:
Red Fau Veh wrote:
crofty
Judas of the North
crofty is offline
PostPosted: Wed Feb 22, 2023 1:03 pm    Post subject: Re: Light Improvements, Front and Rear. Reply with quote
I run H4's on my buses.
Tailight buckets with good reflective insides are a must.
As has been mentioned, good grounds, (i run a ground wire on my tailights), good headlight switch are a must.
HamburgerBrad wrote:
SPLITV
SPLITV is offline
PostPosted: Wed Feb 22, 2023 5:04 pm    Post subject: Re: Light Improvements, Front and Rear. Reply with quote
thank you everyone, interesting ideas.
Crofty, how did you install the H4 bulbs?
I like the idea of the light bar, maybe on the bumper.
dgsaz
dgsaz is offline
PostPosted: Wed Mar 01, 2023 11:50 am    Post subject: Re: Light Improvements, Front and Rear. Reply with quote
I found a great way to add lights to the front bumper. If you go to an industrial hardware store, in the prefab metal tabs for welding. Pick part 181, one per light.
Layout where you want the lights.
Remove the four bolts that hold the overrider. Just a bit of grinding and off to the welder, from there off to the powder coater.
Wait for call, go pick up.
When you get home, take Dremel and expose a quarter sized patch on the bottom of the tab to insure a good ground.
Re-install the override with the same 4 bolts and mount your lights.
img]https://www.thesamba.com/vw/gallery/pix/2371637.jpg[/img]
This can be done even cheaper if you can do your own welding and simply paint the overrider.
The welding tabs are great for what they do. Lots of sizes and shapes.That's what I did.
dgsaz
Daddybus
Daddybus is offline
PostPosted: Wed Mar 01, 2023 12:13 pm    Post subject: Re: Light Improvements, Front and Rear. Reply with quote
Here are my LED head lights and the "mount" for my driving and fog lights
dgsaz
dgsaz is offline
PostPosted: Wed Mar 01, 2023 12:43 pm    Post subject: Re: Light Improvements, Front and Rear. Reply with quote
Some random dude: Wow, why do have so many lights on the front?
Me: yes.
pyrOman
Fire Master
pyrOman is offline
PostPosted: Wed Mar 01, 2023 5:23 pm    Post subject: Re: Light Improvements, Front and Rear. Reply with quote
Me: yes.
Laughing Laughing Laughing
MrPolak
MrPolak is offline
PostPosted: Thu Mar 02, 2023 8:44 am    Post subject: Re: Light Improvements, Front and Rear. Reply with quote
Modern LED tail light bulbs are drop-in, bright and cheap enough. No need for above.
You don't mention what type of front lights you have. Is it an H4 bulb with a fluted lens? There are decent LED options for just about any incandescent application.
Don't run DOT sealed beams, they suck.
MrPolak
MrPolak is offline
PostPosted: Thu Mar 02, 2023 9:08 am    Post subject: Re: Light Improvements, Front and Rear. Reply with quote
All my lights are LED.
Parking lights
Driving lights
PatJr
PatJr is offline
PostPosted: Thu Mar 02, 2023 9:11 am    Post subject: Re: Light Improvements, Front and Rear. Reply with quote
why do you need this?
does it work 4 lead > 5 lead ?
1970 Transporter a orange one
crofty
Judas of the North
crofty is offline
PostPosted: Thu Mar 02, 2023 9:58 am    Post subject: Re: Light Improvements, Front and Rear. Reply with quote
You have to replace the sealed beams with H4 units.
https://www.amazon.com/HELLA-002395991-Type-Single-Headlamp/dp/B0002M9QJM
VWAdam
VWAdam is offline
PostPosted: Thu Mar 02, 2023 4:49 pm    Post subject: Re: Light Improvements, Front and Rear. Reply with quote
I concur with the H4s. I love them on my Bus.
All he needed was a wheel in his hand and four on the road.
'59 Euro Beetle ragtop
'63 Standard Microbus
Come to my show! www.volksjam.com
Looking for badge/sticker/frame from Western Motors in Great Falls, Montana
