jonat Samba Member
Joined: July 16, 2013 Posts: 86 Location: United Kingdom
Posted: Tue Mar 14, 2023 5:47 pm Post subject: Cigarette Lighter (for padded dash) |
I have a spare hole cut in my padded dash and noticed there is a precut hole in the metal dash behind it. The padded dash hole measures around 22mm and the metal hole around 14mm although that one is difficult to measure.
Will a cigarette lighter fit here?
I noticed there is a high rise and low rise knob available. Which is best for a beetle with padded dash? I've been told the low rise is for the beetle and the high rise for a bus although i've seen a couple photographs on here showing dealer originals with what looks like the high rise one with a metal sleeve to protect the padded dash
high rise:
low rise:
@pogel lighter
padded and metal dash hole:
Frederik Samba Member
Posted: Wed Mar 15, 2023 3:23 am Post subject: Re: Cigarette Lighter (for padded dash) |
Obviously you will need to cut a bigger hole for the lighter socket to fit. Do you want a lighter socket or just fill the hole? Does your car have any signs that a aux heater was installed. I think that hole was originally used for a aux heater switch (eberspächer). |
hopkin  Samba Member
Joined: June 25, 2012 Posts: 2545 Location: Ottawa, Ontario
Posted: Wed Mar 15, 2023 4:48 am Post subject: Re: Cigarette Lighter (for padded dash) |
I installed mine (actually a power plug) under the dash, out of sight:
_________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
1991 Honda Civic (Original Owner)
1996 'Open Air' Mexican Beetle (current)
2015 Golf (past)
2017 Dune Edition (daughter's car) |
Cusser Samba Member
Joined: October 02, 2006 Posts: 32960 Location: Hot Arizona
jonat Samba Member
Posted: Tue Mar 21, 2023 2:28 pm Post subject: Re: Cigarette Lighter (for padded dash) |
Frederik wrote: |
I would be interested in fitting a cigarette lighter for a potential dash cam/phoje charging. Currently i have a cap which covers it.
It is a '72 1302s and my manual didn't mention it although I found an american manual for the '72 bug which does.
It's the first time i've heard of an auxillery heater in a beetle. What would show it had been installed?
hopkin wrote: |
I installed mine (actually a power plug) under the dash, out of sight: |
What did you both use to cut a hole/make a hold bigger in the metal dash/ what is recommended to use? |
jinx758 Samba Member
Joined: October 04, 2014 Posts: 998 Location: half a bubble from plumb
Posted: Tue Mar 21, 2023 3:29 pm Post subject: Re: Cigarette Lighter (for padded dash) |
That'll be a handy upgrade ... !
I use those cone shaped step drills for holes in sheet metal.
They are easy to go too big however.
A Dremel could do it just to enlarge what you have.
A coat of paint & let it fully dry is also a good idea :
"Rust never sleeps"
Good luck ... stay safe
jinx _________________ " It's not valuable unless you learn something from an experience. " Henry Ford
It's not unlike the same difference ...
My Craigslist rescued 100 footer :
1971 Standard Bug
1776cc dual port
034 distributor
38mm EGAS Carburetor |
hopkin  Samba Member
Posted: Tue Mar 21, 2023 7:07 pm Post subject: Re: Cigarette Lighter (for padded dash) |
jonat wrote: |
hopkin wrote: |
The auxiliary heater is a gas heater, there are threads on the subject. Both of my old '71 Supers had them, they were common here in colder climates.
Like Jinx I used one of the dome shaped bits. I guess the bit was large enough as I didn't have to use my dremel to make the hole larger.
The power plug and door are Porsche PN's 95565210700 for the socket and 99765210300 for the 'door' portion. They should be easy to find. I installed mine on a switched circuit (fuse 10) so the key must be on. Later I installed a dual USB port on the same circuit, so I don't really use the power port anymore.
1974 SunBug (past)
1972 914 (past)
2015 Golf (past)
Posted: Wed Mar 22, 2023 5:44 am Post subject: Re: Cigarette Lighter (for padded dash) |
jonat wrote: |
Edit: If you want a lighter socket in the dash, just go for it. I'm not saying you shouldn't, just some other ideas to consider. Is the cut out in the padded material big enough to fit a lighter socket, or does it to have to be enlarged? Its hard to tell by the photo. If it needs to be enlarged I would probably be more carefull not to mess it up, than drilling the metal.
Why I asked is because because if you only wanted to fill the hole you could use it for something like a fog light switch and hide away the lighter/power socket. You could even use the hole for an on/off switch for the power socket. This might have its advantage if you hook it up as an usb charger/power source and want to use it with ignition off and still be able to kill the power drain.
You could probably also look around for a smaller size panel mount usb socket or even USB-C socket that might fit your existing hole. This can then be hooked up to a USB power source/ charger behind the dash. If you want it to look stock, glue a male usb dummy to the back of an original dash knob and plug it it to the socket when it's not used.
I'm not saying this fit, but just as an example:
https://www.amazon.se/USB-panel-inf%C3%A4lld-monte...&psc=1 |
Big Bull Shooter Samba Member
Joined: April 28, 2018 Posts: 526 Location: Canadian Rockies
Posted: Wed Mar 22, 2023 7:47 am Post subject: Re: Cigarette Lighter (for padded dash) |
Here's the gas heater in my 1969 Canadian Beetle. It is turned on and off by a knob under the dash underneath the speaker. The heat is pretty much instant and blows right on your legs. Some other versions were installed above the transmission and connected between the heat exchangers and heater channels. Separate fuel supply lines connected to the fuel tank.
jonat wrote: |
Frederik wrote: |
hopkin wrote: |
_________________ Where would this hobby be if no one shipped parts.
crukab
Feb. 11, 2021
Smokey says.... only you can prevent Bug fires!
zerotofifty
May 16, 2023 |
Root_Werks Samba Member
Joined: December 31, 2007 Posts: 1049 Location: San Juan Islands
Posted: Wed Mar 22, 2023 7:59 am Post subject: Re: Cigarette Lighter (for padded dash) |
Installed a Power Supply (Cig lighter style) under the dash. Be nice to have the ability to charge a phone. _________________ When I set my timing, why do I flush, then take a pee? |
jonat Samba Member
Posted: Tue Mar 28, 2023 6:06 am Post subject: Re: Cigarette Lighter (for padded dash) |
Frederik wrote: |
the dash hole would have to be enlarged foer the lighter accessory. It looks to be 14mm, which would only fit something like a swittch such as headlight, warning lamp, fog etc. I wonder if having a cigarette lighter placed elsewhere other than the dash might work better.
I like your USB-C suggestion and having dummy cover. I might see if i can research any sizes that fit. Do you have an example of a good USB power source for behind the dash?
The fog switch suggestion is also good. I've noticed there are a few different ones. Is Orange for rear and green for front? I've seen quite a few different cap designs and it seems they were shared with Porsche too even if they had VW stamps on the unit.
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13947 Location: White Mountains Arizona
Posted: Tue Mar 28, 2023 5:06 pm Post subject: Re: Cigarette Lighter (for padded dash) |
All those are great ideas while you at it just the home mad partial tray and mount it to that.
_________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Crucje Samba Member
Joined: September 29, 2023 Posts: 1 Location: Gelderland
Posted: Fri Sep 29, 2023 1:55 pm Post subject: Re: Cigarette Lighter (for padded dash) |
jonat wrote: |
high rise:
low rise:
@pogel lighter
Can you give me the site where you found the cigarette lighters? |
