candyman Samba Trout Slayer
Joined: December 20, 2003 Posts: 2717 Location: Missoula MT
Posted: Fri Mar 24, 2023 8:26 am Post subject: Re: Stock Spring Replacements |
| syncrodoka wrote: |
| candyman wrote: |
| teej wrote: |
I went with the Schwenk springs all around a few years ago when replacing the rear perches. If I were to do it again, I wouldn't. The height did not change much, ride became a little harsher in my opinion, and based on further research the 86 weekender stock springs would have been fine to keep running.
I may try some different shocks. |
X2 on the schwenk springs. Added them to my syncro westy and wow so harsh I hate it. |
Which version, stock height or lifted? |
Stock height |
Posted: Fri Mar 24, 2023 9:07 am Post subject: Re: Stock Spring Replacements |
| Schuylersister wrote: |
| Really don’t want adjustable shocks. |
I completely respect your opinion here, but I am curious as to your reason for this. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Schuylersister Samba Member
Posted: Fri Mar 24, 2023 10:07 am Post subject: Re: Stock Spring Replacements |
| Christopher Schimke wrote: |
I completely respect your opinion here, but I am curious as to your reason for this. |
Hi Christopher-Appreciate your question! I really can’t see myself adjusting shocks. I don’t fiddle around that much under the van.
Thought about reaching out to you to help me dial in some new shocks though and to level up the van. Only the rear shocks “need” replacement and I have GW no-lift springs from about ten years ago. Any thoughts?
I have a great mechanic here to do the work. He likes me to supply the parts.
See you are no longer carrying Schwenk springs. What happened? |
tjet Samba Member
Posted: Fri Mar 24, 2023 1:34 pm Post subject: Re: Stock Spring Replacements |
Have you considered new replacement Carat springs? I say this because you are height restricted. I installed a used set in my '85 tintop & liked them a lot, but I'm not sure if they are ok to use in a heavier Westy.
https://www.thesamba.com/vw/classifieds/detail.php?id=2542952 |
Posted: Sat Mar 25, 2023 8:37 am Post subject: Re: Stock Spring Replacements |
| jimf909 wrote: |
| Something has changed recently with ride quality and leaning. Thoughts? |
Twice in the past 10 years 'something changed' with the handling of my Vanagon with noticeable leaning where before it felt much more solid. Both times the end link on the anti-sway bar failed (once OE, once aftermarket). You may already have checked, but if something changed causing it to lean more it could be a failed anti-sway bar or end links. |
Yes, thank you! This did happen before with my aftermarket end links but not this time. Something else is happening! I really think upgrading shocks all around is the way to go. Just measured height from all four wheels and it’s reasonable considering my GW no-lift progressive springs are at least ten years old:
DF-17” DR-16 3/4” PF-17 1/8” PR 16 7/8”
Last edited by Schuylersister on Sat Mar 25, 2023 4:27 pm; edited 1 time in total |
Posted: Sat Mar 25, 2023 3:10 pm Post subject: Re: Stock Spring Replacements |
Totally understandable. I will say though, that the shocks work REALLY well right out of the box, so it's not uncommon for people to simply install them and move on. Also, if you do decide to adjust them, once you have them like you want, you never have to adjust them again.
| Quote: |
| Thought about reaching out to you to help me dial in some new shocks though and to level up the van. Only the rear shocks “need” replacement and I have GW no-lift springs from about ten years ago. Any thoughts? |
Yeah, shoot me an email. I'd be happy to help you out with this. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
jimf909 Samba Member
Posted: Sat Mar 25, 2023 4:20 pm Post subject: Re: Stock Spring Replacements |
Totally understandable. I will say though, that the shocks work REALLY well right out of the box, so it's not uncommon for people to simply install them and move on. Also, if you do decide to adjust them, once you have them like you want, you never have to adjust them again. |
This is my experience with adjustable shocks. The idea isn't that I'm adjusting the shocks all the time, rather, it's adjust a few times to dial it in to my preference and then it's set and forget. _________________ - Jim
| Butcher wrote: |
| This is the main fault with DIY'ers, they get together on these forums and pat themselves on their backs spreading bad information. |
Guilty as charged.
paulcolorado21 Samba Member
Posted: Wed May 21, 2025 10:13 am Post subject: Re: Stock Spring Replacements |
Hey all I thought this was a good place to ask about some spring/suspension issues
So I have the Van Cafe lifting springs but on the driver side the spring looks over compressed and actually isnt seated in the top as you can see the spring pad kinda off kilter in there. I originally thought a new shock would boost it up and replaced that but learned there is something else going on. I am in Baja at the moment but have a friend coming down so I could order two new 1.5" lift springs but also curious if just the spring pad will sure things up.
Below is a picture of the passenger side and how it should look and then the driver side showing how the spring is sitting over compressed and then also a picture of the top of the spring not seater correctly into the upper control arm.
this is passenger side and seems to be fine
this is the problem driver side compressed at rest
this is photo that shows the top and how its seated above
this is the spring bad kinda off kilter not seated correctly
Please let me know how to proceed as I have a time crunch on ordering parts for my friend to bring down but also dont want to waste money on things I dont need  |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 19121 Location: Retired South Florida
Posted: Wed May 21, 2025 10:21 am Post subject: Re: Stock Spring Replacements |
When you’ve had the front springs out, I believe the manual recommends using electrical tape in a few spots to hold the upper perch in position during assembly.
I can’t comment more than that, but your swaybar link bushings look pretty worn. |
Posted: Wed May 21, 2025 10:40 am Post subject: Re: Stock Spring Replacements |
Your camera angle is looking sides of the spring. On the passenger side (right side of the vehicle), you need to be looking at the spring from the back side and looking toward the front of the vehicle in order to see the coil windings from the same perspective. If you do that, I think you will see that the coil windings will look nearly identical.
It's hard to tell from the photos, but it does look like the upper rubber isolator is cocked in there crooked. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Wed May 21, 2025 11:17 am Post subject: Re: Stock Spring Replacements |
Hey I actually didnt touch the springs I just put a new shock on that side hoping that was the problem and then when I had the wheel off and everything that is when I noticed the spring looking wonky in there.
I guess the biggest question is the compression from it not being seated correctly or is it a worn out spring? These are about 5 year old aftermarket 1.5 inch higher springs I believer from the Van Cafe ones.
I added the sway bar bushings to the repair list those have been glaring at me for a while
What about upper control arm bushings and bearings if we decide the springs are good just out of place?
Obviously at least one new spring pad rubber
Here is a photo of the driver (problem side)
Here is the passenger (good or better side)
Posted: Wed May 21, 2025 12:28 pm Post subject: Re: Stock Spring Replacements |
In general, a shock is not going to change ride height. It is a spring dampener to control spring oscillations. A gas charged shock does add maybe 50 pounds of compression rate, but in pairs isn’t noticeable in ride height.
The ride height is determined by the spring and the spring pads top or bottom. Trouble can occur when the tails of the springs end in different end spots. This can affect how the spring seats. The pads etc are built around original springs and there are many folks successfully running aftermarket springs. Like anything, there are probably some that are better than others.
Our 82 camper has original springs over 40 years old. No issues I could identify to cause me to do something else. Christopher from T3 is who I’d have conversations with if I wanted to replace springs and shocks. |
Posted: Wed May 21, 2025 1:05 pm Post subject: Re: Stock Spring Replacements |
| Thanks Mark, but in the picture do you see something funny of how the spring is orientated that would cause it to sit more compressed like it is in the picture? |
Posted: Wed May 21, 2025 1:39 pm Post subject: Re: Stock Spring Replacements |
My phone just isn’t clear enough. The last photo shows the bottom spring end is not against the stop. I understand you are traveling and likely taking the springs out to compare them is not practical nor would I suggest you attempt that without a spring compressor, a safe place to work, and all the tools you’d need.
And you mentioned a front suspension rebuild. I would do it all at once. You could order in advance from T3 what he recommends or take it completely apart and see what you need.
Less quality springs can sag over time and decrease ride height, but to really compare you’d need them on a bench. |
Posted: Wed May 21, 2025 1:46 pm Post subject: Re: Stock Spring Replacements |
Ideally, you should simply measure your ride heights at all four corners (with the van on flat ground, measured from the center of the hub to the fender lip). All four corners will likely be a bit different (that's common), but it will give us an indicator of what we're dealing with in terms of ride heights.
As Mark said, springs do generally sag over time, but that in itself does not indicate a problem.
Also, as Mark said, the right side spring should ideally be rotated so that the end of the open coil is right near the notch in the control arm.
And I agree with Mark that attempting to install new springs while "on the road" may not be wise, or even necessary. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Wed May 21, 2025 3:59 pm Post subject: Re: Stock Spring Replacements |
Just measured from center hub to fender around the van and it was
Passenger Front 17.25 in
Driver Front 16.25 in.
Driver Rear 17.5 in
Passenger Rear 17.75 in |
Posted: Wed May 21, 2025 6:18 pm Post subject: Re: Stock Spring Replacements |
| If I were traveling, I wouldn’t sweat the difference. It’s not worth worrying about. Keep an eye on it if you want. |
Posted: Wed May 21, 2025 7:38 pm Post subject: Re: Stock Spring Replacements |
| Im actually living down here and in a good spot to get things fixed its just I have this opportunity to have a friend bring good parts down but just not sure what I should spend money on to tighten this suspension up. Could it be just reseating it properly with a fresh rubber pad? I'll even use a mechanic for this one as its very reasonable and I have someone good but getting good parts is the challenge... |
Posted: Thu May 22, 2025 3:59 am Post subject: Re: Stock Spring Replacements |
The only way to really know is to start by removing the springs. Their overall condition visually is not something I’d be trying to get more life out of. As I said earlier, my 40 year old stock springs are still doing fine. If the upper perch has shifted and has been carrying the weight of the van, it’s likely permanently deformed. So at a minimum a good set of used stock springs and upper perches would be a good start. Otherwise go all new and replace all the wear bushings with new. Basically rebuild the front end. Again T3 can provide what you need including new hardware. He even posted a DIY front alignment thread for getting everything adjusted close to spec.
I’ve installed taller aftermarket springs for other owners and it’s one of my least favorite jobs. There is a lot of stored energy in a compressed spring and if something slips, you can get hurt. Good luck with your project. |
Posted: Thu May 22, 2025 9:05 am Post subject: Re: Stock Spring Replacements |
You can see from the image below that the driver's side front spring has lost load height (sagged). Notice the height discrepancy between the coils. This lines up with your ride height discrepancies. If I were in your shoes, I would simply install a 0.75" spring shim on the driver's side front and call it a day. It's cheaper than replacing all of the springs, and since that spring still has the same rate (stiffness) as it did when new, it's still a viable part. You would need to take the driver's side front apart to fix the rubber isolator issue anyway, so tossing in a spring shim is a piece of cake at that point.
