RocketSurgeon Samba Member
Joined: May 26, 2005 Posts: 442 Location: Roseville, CA
Posted: Fri Jan 06, 2012 10:27 am Post subject: Seat Spring Fix |
Just thought I'd share. Its only been a week but they are holding strong.
No more crunch! |
DesertBob Samba Member
Joined: February 09, 2004 Posts: 1245 Location: Goodlettsville, Tennessee
Posted: Thu Jul 05, 2012 11:13 am Post subject: |
How is this fix holding up 6 months later? _________________ All it takes is a little imagination, some mechanical ability, and neighbors who mind their own business
74 Super Beetle (German Look Project)
Full Flow 1776 with 36 Dells, 4 wheel drilled and slotted disc brakes, Porsche 7x17 Turbo Twists, Topline Maxx Struts, Camber kit, 7/8" Front Sway bar, Rear Sway bar, Urethane bushings all around. |
fourfignewtons Samba Member
Joined: June 25, 2010 Posts: 148 Location: Wilmington, NC
Posted: Thu Jul 05, 2012 11:28 am Post subject: |
Where did you get the hardware? Nice fix but wondering how it's going to hold up as well. I may try that fix too but shoot a little super bonding epoxy in there to give it some extra hold.
It's that or weld it very carefully.  _________________ 78 Westy "Oscar"
76 Westy "Sam" |
jmstu76 Samba Member
Joined: March 01, 2004 Posts: 1280 Location: Edmond Oklahoma
Posted: Thu Jul 05, 2012 1:18 pm Post subject: |
I took a very stiff piece of vinyl hose and connected the two ends. I used a clamp over the piece of hose to hold them. My fix is still working but I like the solution of the OP a little better. _________________ James
'76 Deluxe Sage Green Westy
2258 cc GD case 78mm CW crank, 2.0 H-beam rods 5,325” 22mm pin, JE forged pistons with 15cc dish, JE rings, type 11 clearanced oil pump, CB Eagle 2205 Type-2 “Torque Special” hydraulic cam with matched lifters fed by CB Dual Weber 40 IDF MX with 6” foam air filters, currently 55 idle, 130 main, 200 air correction, 32 mm venturis. 27in General Grabber AT2 All Terrains, Berg Shifter, stock '76 exhaust HPC Ceramic Coated. 11/18/2020 |
Posted: Thu Jul 05, 2012 8:29 pm Post subject: |
It's just as solid as day 1! I lifted the seat to check. Pushed, pulled, and twisted. No movement at all. And it's been about 1500 miles. I'm sure it will last a long time.
I picked up the spacer at home depot. _________________ 69 Westy |
olafwagner Samba Member
Joined: November 11, 2021 Posts: 51 Location: Encinitas, CA
Posted: Fri Mar 24, 2023 5:24 pm Post subject: Re: Seat Spring Fix |
Since I got my bus, the driver's seat has always been sagging a bit. Also, the rails were quite stuck, so yesterday I decided to remove the seats and clean up the rails. Once I had the seats out, i peered into the driver's seat, and saw that I had 4 (FOUR) broken springs.
Following RocketSurgeon's post I saw that my local Home Depot listed 7 spacers in stock, but when I drove there, I found that the spacer draw was in quite a jumble, and none of the 1" length spacers could be found. So I took a look on Amazon, and saw that you can get a bag of 25 for just $8.55 (way cheaper than Home Depot), so I ordered a bag and they arrived today.
Sliding them into place (even before crimping) you can really tell that they are a good fit. Unfortunately I cannot get my swaging tool in between the springs. Not only are the holes are oriented biggest to smallest on my swaging tool (and I needed the 2nd smallest which translates to 'the 2nd deepest in the jaws') but also the place where the springs snapped are in awkward spots (far more awkward than what I can see in RocketSurgeon's pics)
So I went with a 'lets see how it goes' fix, and crimped them with the 'yellow' section of the usual red/blue/yellow terminal crimping tools. Not nearly as much force as swaging, however, let see how it goes....
Anyway, so far so good, gave it a few 'test sits' and it feels great - better than the seat has ever felt.
I will also report back over time to let you know how my 4 repaired springs hold up. If not, the next steps will be to shell out the ~$70 for the same swaging tool as RocketSurgeons  |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 3321 Location: Hamble, Hampshire, UK
Posted: Sat Mar 25, 2023 1:11 am Post subject: Re: Seat Spring Fix |
I wrapped the break in soft iron flower arranging wire (NOT galvanised ) to hold it firmly together then ran a MIG welder on low over it . Lasted 60k miles. Then I sold the seats .
. Better than aluminium that will fatigue and crack _________________ Ancient vehicles and vessels
scottyrocks Samba Member
Joined: August 19, 2016 Posts: 2863 Location: Thornton, CO
Posted: Wed Mar 29, 2023 12:51 pm Post subject: Re: Seat Spring Fix |
As my driver's seat has been a little low on the left side since I've had the car (2016), I decided, after reading this thread, to remove the seat and check for a broken spring.
No broken spring.
Could the springs just be worn out in that particular area due to, say, a left-leaning previous owner of several years/decades? If so, any fixes before resorting to new springs? _________________ “If you care for a thing long enough, it takes on a life of its own, doesn't it? Mending old things, preserving them, looking after them – on some level there's no rational grounds for it.”
– D. Tartt, 'The Goldfinch' |
alaskadan Samba Member
Joined: January 09, 2013 Posts: 1937 Location: anchor pt. alaska
Posted: Wed Mar 29, 2023 7:43 pm Post subject: Re: Seat Spring Fix |
There's another thread about seat springs, might be in the vanagon forum. Anyhow you can buy new coil springs and replace your old ones. Any upholstery supply places should have what you need. |
Posted: Wed Mar 29, 2023 9:54 pm Post subject: Re: Seat Spring Fix |
alaskadan wrote: |
I'll check it out. Thanks! _________________ “If you care for a thing long enough, it takes on a life of its own, doesn't it? Mending old things, preserving them, looking after them – on some level there's no rational grounds for it.”
wrxnofx Samba Member
Joined: July 06, 2022 Posts: 295 Location: Richfield, MN
Posted: Sun Apr 23, 2023 7:34 pm Post subject: Re: Seat Spring Fix |
Were you able to find a link to the thread about purchasing spare springs?
I have 2 broken springs in my driver’s seat (along with a broken frame I will weld). The 2 broken springs are cashed. I tried the aluminum coupling listed above and it sort of works in that it holds the broken ends together (and from ripping my jeans). The spring rate above the coupling and below the coupling is totally different, however. I’m not sure welding the springs back together would fix this. _________________ 1977 VW Type 2 Bay Window Westy FI
Posted: Sun Apr 23, 2023 8:21 pm Post subject: Re: Seat Spring Fix |
If you google furniture springs you will find what you need. Or if you have a decent local upholsterery shop they should have something. Sorry for not posting a link there's just too many suppliers to pick from. |
Posted: Mon Apr 24, 2023 9:05 am Post subject: Re: Seat Spring Fix |
Not really. I can find sort of a similar spring on the inter webs but nothing the same. Looks like the bus springs are double tied, and I’m not sure the length. _________________ 1977 VW Type 2 Bay Window Westy FI |
napat Samba Member
Joined: March 15, 2003 Posts: 252 Location: bkk, thailand
Posted: Thu Sep 28, 2023 9:50 am Post subject: Re: Seat Spring Fix |
I did it
_________________ love double cab |
Scrumblero Samba Member
Joined: September 13, 2023 Posts: 21 Location: contado de contra costa
Posted: Thu Sep 28, 2023 6:06 pm Post subject: Re: Seat Spring Fix |
I've used electrical wire crimps with the plastic cut off. gotta have a good crimper tho.. |
otiswesty Samba Member
Joined: November 21, 2006 Posts: 1768 Location: Portland
Posted: Fri Sep 29, 2023 12:24 pm Post subject: Re: Seat Spring Fix |
I used a spring from a donor seat that wasn't broken. Still holding up 10 years later _________________ 1978 Sage Green P22 Westfalia
1988 T3 Syncro Single cab
Just a regular guy |
4118thing Samba Member
Posted: Fri Sep 29, 2023 2:07 pm Post subject: Re: Seat Spring Fix |
I had exactly the same break on my Single Cab seat. I cut a piece of heavy duty braided fuel line and put it on just like the metal piece was done here. Works great. _________________ ‘73 Thing
‘69 Single cab |
Posted: Sun Oct 01, 2023 12:52 pm Post subject: Re: Seat Spring Fix |
napat wrote: |
I did it
May I ask where you got the springs from and what diameter/height they are? _________________ 1977 VW Type 2 Bay Window Westy FI |
napat Samba Member
Posted: Sun Oct 01, 2023 5:36 pm Post subject: Re: Seat Spring Fix |
wrxnofx wrote: |
napat wrote: |
I did it
May I ask where you got the springs from and what diameter/height they are? |
I repro them here in Bangkok.
exact the same length and constant. _________________ love double cab |
jtauxe  Samba Member
Joined: September 30, 2004 Posts: 5975 Location: Los Alamos, New Mexico, USA
Posted: Thu Jun 12, 2025 6:46 pm Post subject: Re: Seat Spring Fix |
Sawatdee khap!
Have you thought about putting an ad up here on The Samba? I'm sure lots of folks would buy them. Me, for instance.
napat wrote: |
wrxnofx wrote: |
napat wrote: |
I did it
exact the same length and constant. |
_________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
