Sodo Samba Member
Joined: July 06, 2007 Posts: 10916 Location: Western WA
Posted: Thu Apr 27, 2023 12:43 pm Post subject: CV Clocking (if axles easily slide left-right) |
This quote harvested from another recent thread: Excess Axle Play - '90 Westy
| RBEmerson wrote: |
| Both of my axles slide easily along the central axis of the axle. That is, I can slide the axle away from the transmission, toward the wheel, or vice versa, easily. |
This axle movement mentioned above (which is normal) is the only genuine physical reason I've ever heard -
---->to 'clock' CVs during assembly.
I've been listening for many years now, not hearing any physical reason to clock CVs.
Everyone does it because some buggy race feller made a video.
And he doesn't even state the reason, he just shows how.
That's like religion. Which is OK. But it's not a truth because it includes no reason.
The theory I've heard (from longtime Vanagon guru Tom Lengyel) which makes some sense, is....
if, by chance, loosey-goosey CVs, with soft springy boots, and etc? etc? etc?, one (or two) axles get flung back and forth, they could knock against the stub axle or spline seal cap, making a bothersome noise.
He said once a van was doing this "axle clunking", with newly serviced axles.
And he found the axles were very loosey-goosey, he could fling them against the ends.
So he tried clocking the CVs on that offending axle and the noise went away.
It makes some sense that 'clocking' could disrupt a resonant condition.
I have seen pics on TheSamba where the spline cap seal has been destroyed from the axle hitting it repeatedly.
But this problem is very seldom seen.
So if you just simply clock your CVs during assembly, you are perhaps safer from that loosey-goosey axle knocking condition.
And it's easy enough.
But I would not take axles apart to clock them,
nor chastise yourself for forgetting.
You MAY have un-knowingly 'clocked' the CVs.
Or maybe they're clocked enough,
or maybe your axles just aren't loosey-goosey
and now you're just wasting effort.
So, in the interest of Vanagon Science (or Vanagon Religion)
.....whichever is your preference )
If you have axles that slide EASILY left right, can you fling them hard and clunk against the stub axle (outboard)?
Or against the spline seal (inboard?)
(go easy flinging them inboard, don't hit too hard.... !! )
OK......... so now you know you have loose-goosey axles.
Do you ever hear your axles clunking against the wheel stub or spline seals?
Do you wanna try clocking your CVs and report back? _________________
'87 Tintop, EJ25, cooled filtered (original) gearbox
....KTMs, GasGas, SPOT mtb
All Vanagons should do this:
Add direct starter-to-chassis cable THEN delete ground strap at front transaxle mount.
The best time to do this mod was in 2010. The second best time is TODAY.
If your starter is slow, this is MORE important. |
RBEmerson Samba Member
Joined: November 05, 2011 Posts: 2221 Location: SE PA
Posted: Thu Apr 27, 2023 12:58 pm Post subject: Re: CV Clocking (if axles easily slide left-right) |
Remember what happened to Martin Luther when he nailed his 95 Thesis to the church door. The life of an iconoclast is not an easy one. ;D _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 7319 Location: Honolulu,Hawaii and France
Posted: Thu Apr 27, 2023 1:25 pm Post subject: Re: CV Clocking (if axles easily slide left-right) |
Hi Tom!
Clocking is more spread out than you make it sound. It's to get the best articulation benefit of the whole assembly. You don't need it on stock applications, but when rebuilding, why not? I do it, it doesn't cost me anything.
The axle movement left to right depends also of your van ride height. Stock height allows axle movement left to right, it's the design plunge to accomodate travel suspension, and it is normal. The axle self centers thanks to the boots and physics, thanks to-I think- the ramps in the cv ball races, it's just gonna find its happy median place naturally.
The play to watch for is against the clock, and up and down from the flange into the differential, and also from the cv body itself. When you can feel these, it's beyond worn anyway, doesn't mean it's noisy yet though.
I've replaced my share of cv joints, a lot of them beyond worn, pitted to death, starting to be pitted within 20K miles from factory + 30 something years (which I attribute to the transmission ground strap now), loose cv's, original VW's cv's, replacement Löbros like OE VW (but without the VW logo), replacement GKN's ( recent ones with 3 lines, Löbro/GKN now), garbage brands too like Dansk (Roulex), Empi, Meyle, some 3 letter name shit I forgot too.
I've documented for myself a lot of models, different stars, cages, ball sizes even within the Löbro/GKN. Differences in early Vanagons using T2 211 part numbered CV's. Later T3 Vanagons with 251 part numbers.
I have driven 6 months as a daily with no cv boots as an experiment on old CV's with sticky Swepco 164 open gear grease. I have yet to see a loose axle hitting the flanges from a worn ass cv joint.
When that happens, it's most likely something is not right (anymore) in the equation from factory.
I listed on the forum here all the axle lengths and part numbers that ever existed for the Vanagon. Shit gets mixed up in 3 decades of poor maintenance, aftermarket crappy parts that fit 1979-1992 Vanagons ( ), suspension modified, engine swaps with angle change on the drivetrain, who knows. A worn CV joint alone doesn't send and leave the axle in the flanges in stock configuration while driving, that's BS in my opinion. _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Sodo Samba Member
Posted: Thu Apr 27, 2023 6:03 pm Post subject: Re: CV Clocking (if axles easily slide left-right) |
| ALIKA T3 wrote: |
| Clocking is more spread out than you make it sound. It's to get the best articulation benefit of the whole assembly. |
I'm not sure how this can be.
Lets say you remove the other CV.
So you have JUST one CV and the axle.
There is a max CV angle, right?
If you now install the other CV, there can be an increase or decrease in max angle dependent upon the clocking?? _________________
Posted: Thu Apr 27, 2023 7:17 pm Post subject: Re: CV Clocking (if axles easily slide left-right) |
| Sodo wrote: |
| ALIKA T3 wrote: |
There is a max CV angle, right?.
Are you saying that if you now install the other CV, there can be an increase or decrease in max angle? |
There's 2 cv joints working together on the same shaft, you get both at their best behavior complimentary to each other when clocking them. _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Posted: Thu Apr 27, 2023 7:29 pm Post subject: Re: CV Clocking (if axles easily slide left-right) |
| Sodo wrote: |
| ALIKA T3 wrote: |
While I do have more investigating to do, one thing I did experiment with a little is the binding of the CVs at certain angles. The greater the angle, the greater the binding.
Binding starts are zero (or near zero) when the inner star of the CV is in the same plane as the body of the CV. As the angle of the inner star starts to move from zero, binding increases from being barely perceptible to incredibly pronounced. The angle at which the binding is very pronounced depends on the type of CV, but for a 944 CV, the binding starts to be distinctly perceptible at about 20 degrees. By 25 degrees, it's incredibly pronounced, almost to the point be being locked up.
Interestingly, binding occurs every 90 degrees of a 360 degree rotation. I'm thinking that the theory of the clocking of the CVs is to prevent the two CVs from reaching pronounced binding at the same time, therefore possibly decreasing the stress on both CVs. By clocking the CVs, the overall binding is spread to every 45 degrees.
Again, I'm just guessing at the theory as to why the practice of clocking the CVs was related to articulation.
My personal opinion is that clocking the CVs does not allow more articulation of the CV. Rather, if anything, it reduces the overall stress on the CV/axle assembly at maximum articulation, therefore potentially increasing the life of the components. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
T3Technique.com or contact me at [email protected]
Last edited by Christopher Schimke on Thu Apr 27, 2023 7:39 pm; edited 1 time in total |
Posted: Thu Apr 27, 2023 7:39 pm Post subject: Re: CV Clocking (if axles easily slide left-right) |
I would say it's 360°/6 balls=60° by itself, and again maybe divided by 2 one more time for being at the exact possible opposite of the opposed CV's position (clocking).
So every 60° is the possibility of having one CV in the opposite behavior as the one of the other side of the shaft, when perfectly "unclocked". The splines on the shaft make variants of in-between "perfectly clocked" and "perfectly unclocked".
So now, what off the counter headache medicine do we ask for bc of Sodo's insomniac thoughts?  _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Posted: Thu Apr 27, 2023 8:33 pm Post subject: Re: CV Clocking (if axles easily slide left-right) |
| I would suspect that clocking the CV's gives a quieter and longer lasting drive train. What it allow is for the outer races of the two joints to turn at exact same speed throughout the entire 360° of rotation. If you have ever driven a 4 wheel drive pickup with yoke style joints in the front end you have felt the effects of the two jokes of the joints not turning at the same speed throughout the rotation. CV joints are not actually constant as far as relative velocity between the outer race and the inner race, but the slight variation in velocity can be cancelled out entirely by clocking the two joints to each other. |
Posted: Thu Apr 27, 2023 8:43 pm Post subject: Re: CV Clocking (if axles easily slide left-right) |
| Wildthings wrote: |
That is well written!
My prose is shit  _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Sodo Samba Member
Posted: Thu Apr 27, 2023 10:58 pm Post subject: Re: CV Clocking (if axles easily slide left-right) |
| Christopher Schimke wrote: |
| Interestingly, binding occurs every 90 degrees of a 360 degree rotation. |
OK that is interesting. With 6 balls/60°, you have tested them and found binding at 90°?
OK now THAT is either very interesting or an oops?
Can you clarify 60° or 90°?
I'm thinking that the theory of the clocking of the CVs is to prevent the two CVs from reaching pronounced binding at the same time, therefore possibly decreasing the stress on both CVs. By clocking the CVs, the overall binding is spread to every 45 degrees. |
OK I'm proceeding with "60°" for now.
"Clocking" is half of 60° (30°)
So you're proposing that clocking evenly spreads out the binding/frictional events that happen at steep CV angles.
So totally wrong-clocked you have 6 bigger frictional binds on the axle.
And clocked you have 12 smaller, evenly spaced frictional binds on the axle.
(it could be 3 friction events un-clocked vs 6 events clocked)
OK that has feasibility.
But I'd like to see it for myself or at least read about it or see it on a youTube etc.
I have studied this for some years now - and have never seen mention of that.
If it's true you could be a pioneer of sorts.
Were these NEW CVs that were binding?
Or used, bedded-in, free-running CVs?
| Again, I'm just guessing at the theory as to why the practice of clocking the CVs was related to articulation. |
At least you are trying to put a physical meaning to the 'custom'.
And the connection to 'articulation'.
I don't see it as increasing articulation, but you're saying the axle could run smoother, free-er at high angles.
I am thankful folks are interested enough to look for answers.
| ALIKA T3 wrote: |
So now, what off the counter headache medicine do we ask for bc of Sodo's insomniac thoughts?  |
The only off the counter medicine that would apply to this condition is from the "21+" store.
Side bonus allows you to forget what you went there for.
| Wildthings wrote: |
To entertain this requires disbelief that that CV joints are actually "Constant Velocity".
I've searched for and never seen ANY info that suggests CV joints are NOT "constant".
That CVs are NOT constant could be a "dirty little secret" but I doubt it.
But if it's a secret ...... I'm glad to expose it.
But lets not go off all half-cocked like some young feller.
Need some proof that CVs are not C.
Maybe they're constant "to the rated angle", and not constant "beyond that angle".
Again, I have not seen that, but it's feasible that clocking is to mitigate running a CV near the end or beyond max rated angle.
But I do wanna know more than "Clocking because some guy at a buggy shop in Las Vegas made a Youtube". _________________
Posted: Thu Apr 27, 2023 11:22 pm Post subject: Re: CV Clocking (if axles easily slide left-right) |
| Sodo wrote: |
| Wildthings wrote: |
Again, I have not seen that, but it's feasible that clocking is to mitigate running a CV near the end or beyond max rated angle. |
They are constant at a zero angle but the variations in angular velocity increase with the angle just the same as what happens with a yoke style joint, but to a much lesser extent. |
Sodo Samba Member
Posted: Thu Apr 27, 2023 11:35 pm Post subject: Re: CV Clocking (if axles easily slide left-right) |
Wildthings how do you know CVs are not constant?
Can you point me to this information on the web somewhere?
Proof of this is central to the discussion. _________________
Posted: Fri Apr 28, 2023 1:22 am Post subject: Re: CV Clocking (if axles easily slide left-right) |
| Sodo wrote: |
Proof of this is central to the discussion. |
Look at the CV's, they are constant by themselves, but there's a wide and a narrow spot, you want the inner load of the balls on both ends of the axles to happen at the same time in the same relative angle into the same position in their tracks
Theorically speaking the flanges are parallel, so the inner cv joint angle is cancelled out (or complimentary) with the outer cv joint. They are happier with symmetry, it's more harmonic, it doesn't mean they are not constant.
And in the end, besides, what are you gonna do anyway? Rebuild your axles without clocking to prove a point? Well, do it!
You can also clock them, if it doesn't matter, so be it. You can't loose either way then!
You have too much time to waste thinking man  _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Posted: Fri Apr 28, 2023 4:48 am Post subject: Re: CV Clocking (if axles easily slide left-right) |
| Sodo wrote: |
I saw the engineering info on these joints 50 years ago that they do not actually have a constant output velocity, just a mildly varying angular viscosity that is suitable for most automotive use. I have seen the information occasionally since when reading about clocking CV joints. I am not going to spend hours trying to find it again though, but will add there would be zero reason to clock the CVs if this wasn't so as clocking does not change the way a single joint operates, but does change how a pair of joints operate together. Clocking a CV adds maybe two minutes to the assembly time for a CV half shaft, so just learn what to do and do it. |
Posted: Fri Apr 28, 2023 5:33 am Post subject: Re: CV Clocking (if axles easily slide left-right) |
| Sodo wrote: |
Nope, not 60 degrees (laptop won't let me apply the degree symbol), definitely 90 degrees. I was surprised too, so I checked it several times. My method for checking was a little rudimentary but was easy to get repeatable results.
I simply chucked a dry CV (with the axle attached, but no CV on the other end) into my lathe. The axle end rested on a block of wood that was clamped to the lathe bed. This allowed the axle to run parallel to the lathe bed, but also allowed me to move the axle horizontally to check the operation of the CV at various angles. It was easy to feel when the CV would bind. I marked one jaw of the chuck so I could easily and consistently monitor the points in rotation where the CV was binding. If I get a minute this weekend, I will try to set that up again to prove that the binding is every 90 degrees. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Sodo Samba Member
Posted: Fri Apr 28, 2023 9:08 am Post subject: Re: CV Clocking (if axles easily slide left-right) |
| ALIKA T3 wrote: |
For all we know.... it could be smoother to be ANTI-clocked (aligned).
We don't know the physical principle.....
consequently we cannot say one way or the other..
I've been doing that (random) for ~30 years (along with most mechanics) and have nothing to take a stand upon.
TheSamba thrives when its members choose typing over actually working on the van.
It's symbiotic.
I have a couple cracked boots that I'm avoiding.
| Wildthings wrote: |
| Sodo wrote: |
40 years ago they said GL5 corrodes your brass in the gearbox.
GL5 formulation was changed ~39 years ago and that ended, but the legend remains strong.
No photos of corroded brass can be found.
Maybe that one 40-year old synchronizer photo.
Which wasn't very convincing either (that it was a running gearbox).
It is kind of funny how the lack of Google can be "telling".
It does take hours to search for null-data, that's the only way to find it.
Anyway, the point is, info on the internet that says CVs produce a pulsed output... is not "open and notorious".
Certainly not as notorious as GL5 problems which are described on forums, but never with photos.
I don't know yet about zero reason.
But agreed zero reason to think its smoother (on that subject)
It's feasible that changes how the assembly operates, perhaps friction-wise at the angle extremes.
Which may or may not make a sh*t of differnce.
it's so easy, why NOT do it?
Well I DO clock (whenever I don't forget to).
It's aesthetically pleasing.
The question is..... if you were in a hurry, and "forgot" to check the clock, should you waste the time to disassemble and clock it?
I've been there.
If the CV simply slides off by hand, that doesn't add up to much effort.
But if you have to press or tap or hammer it out, it's likely a waste of time.
Certainly a waste if you've already taken off the gloves.
I could clock and re-clock, anti-clock, doubleclock and half-clock in the time spent typing on theSamba.
This is 100% car-hobby talk. I'm interested in the physical principal.
If by chance the physical principal DOES surface, I still don't' believe it makes the slightest difference.
I think everyone is in general agreement that benefit is unlikely either way....
Aside from the anecdotal event where the axle clacking went away.
(laptop won't let me apply the degree symbol) on mine its shift+option+8 (like the *)
Nope, not 60 degrees, definitely 90 degrees. I was surprised too, so I checked it several times.
this suggests "finding the 45° and clocking at 45° to even out the frictional pulsation at steep angles.
The thing is.... steep angles are at significant articulation events.
Off-road events don't account for a lot of miles or build up heat --->'cuz it's slow.
But anyway, all these little details help lead us to "the principle behind CV clocking".
If it exists 'beyond legend'.
Thankfully this is one we don't really "need".
Replacement CVs aren't going NLA. _________________
Posted: Fri Apr 28, 2023 11:24 am Post subject: Re: CV Clocking (if axles easily slide left-right) |
| Sodo wrote: |
[color=red]40 years ago they said GL5 corrodes your brass in the gearbox.
GL5 formulation was changed ~39 years ago and that ended, but the legend remains strong. |
The math associated with the geometry of a CV joint hasn't changed one iota over the years, and won't change in 10,000 years more. |
teej Samba Member
Joined: November 26, 2010 Posts: 908 Location: Seattle
Posted: Sat Apr 29, 2023 11:49 am Post subject: Re: CV Clocking (if axles easily slide left-right) |
| Sodo wrote: |
Do you wanna try clocking your CVs and report back? |
Well now. I have been chasing a rear end occasional knock for quite a while. Tried everything to resolve but still doing it. When I installed this engine, I serviced the CVs and did not know to clock them. The knock seems to have started after that time. The van is on jackstands now so I just tested and both axles move very easily left-right. So I now have something else to try--if it fixes the occasional knock I will have this thread to thank. _________________ 1986+ Wolfsburg Weekender Pop-Top 2.3 WBX Manual Trans |
Posted: Sat Apr 29, 2023 11:55 am Post subject: Re: CV Clocking (if axles easily slide left-right) |
Has the CV grease turned p*** yellow? ;D _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
Posted: Sun Apr 30, 2023 11:21 am Post subject: Re: CV Clocking (if axles easily slide left-right) |
Okay, I was able to set this test up again to check my previous words about the binding. In doing so, I discovered that I was incorrect about the 90 degree rotation, but I also discovered something I did not realize last time.
First, I was incorrect about the binding being at 90 degrees. It was a long time ago that I did the last test, so my memory failed me. The binding is actually occurring every 120 degrees. Obviously, this makes more sense, given the number of bearings in the joint. Sorry for the incorrect information in the previous posts.
The test shown in the video below is with the axle set at a 20 degree angle to the joint. The noise in the video is the splines of the axle riding on the clamp, not the CV making noise.
With 944 CVs, and the axle at 20 degrees, the CV is in a pretty significant bind every 120 degrees. So much so, that it's a little hard to decipher what exactly is going on. As result, I switched the CV to one of our Hi-Angle CVs. The results were pretty dramatic.
With the Hi-Angle CV in place and the axle remaining at the exact same 20 degree angle, there is absolutely ZERO binding in the CV. And as a result of zero binding, I was able to observe the action that the inner star (and therefore, the axle) takes as the CV reaches the same location in the rotation that was causing binding in the 944 CV (every 120 degrees).
In the video below, watch the end of the axle shaft. See how it moves in and out (left - right)? This is showing how the inner star (and therefore, the axle) has a natural tendency to be pulled inward toward the CV body every 120 degrees of rotation. Obviously, as the inner star is pulled inward toward the CV body, the axle follows. (My hand on the axle is only putting light tension toward my right to ensure the axle is following the inner star perfectly, and to prevent the axle from "climbing" the clamp)
Keeping that in mind, think about what is happening to a CV mounted on the other end of the axle and installed on the flanges. If the CVs are NOT properly clocked (clocked 180 degrees from being in phase), both inner stars will be trying to move away from each other every 120 degrees of rotation. In essence, they are fighting each other trying to pull the axle, or themselves, apart.
However, when the CVs are properly clocked, they are actually complimenting each other during every rotation, like a dance. In other words, when one inner star wants to move inward toward the CV body, the opposite CV is loosening up and allowing that movement to happen.
Of course, there are the states in between fully tight and fully loose, but this seems to play very well into Tom's theory of the possibility of the axle making contact with the flange if the CVs are not clocked properly. It also makes one think about what is going on when the CVs are partially clocked too.
And then, of course, there are the states where the CVs are only partially clocked (partially out of phase) to consider.
VERY interesting.
And for those who are interested, below are two photos showing the 944 CV in the portion of rotation that causes the binding to occur.
On the 20 degree side (first photo), you can see the narrow part of the inner star is located at the wide part of the CV body. On the opposite side (second photo), it's the wide part of the inner star and the narrow part of the CV body.
