Early bus found in the weeds
Page: Previous  1, 2, 3
DanM
DanM is offline
PostPosted: Wed May 17, 2023 12:39 pm    Post subject: Re: Early bus found in the weeds Reply with quote
Lawd have MRSA!
the.fordhams
the.fordhams is offline
PostPosted: Thu May 18, 2023 9:35 am    Post subject: Re: Early bus found in the weeds Reply with quote
You may get lucky and they removed the front brake internals but if they're stuck then maybe take a big brake drum puller to remove the drums and release the brake internals up front (and maybe on the Stude rear drums too?)
You have a steering wheel which is really good but did the arms underneath look all connected? If not plan bring some track rods to keep the front somewhat pointed the same way.
Do you think that big tree limb will allow enough vertical movement to get wheels under? Maybe you could skid it on the plywood with a tractor pull and then put the wheels on?
Awesome rescue
63 OG Turkis Bug Patina air ride
65 OG Safari Beige Notch project
65 OG Pearl White SO42 Patina
67 SO42 project
03 Eurovan Weekender
08 Touareg 2 V6
WANTED :
Bob King VW dealer Wilmington NC dealer tag surround and any Literature for 03 Weekender
OTO X58
OTO X58 is offline
PostPosted: Thu May 18, 2023 11:00 am    Post subject: Re: Early bus found in the weeds Reply with quote
KevinAlbrecht wrote:
I am not sure if a come-along would be the thing to use, but some sort of winch would be helpful I think.
Good call! Thanks I'll add it to the list.
DanM wrote:
Lawd have MRSA!
Dude, I am so excited about this bus. I have way too many projects already, but this is once in a lifetime.
Awesome rescue
We turned the steering wheel and it wiggled the drums, so we should be good there. I would be shocked if the drums are empty- most likely they're seized solid. Good call on the puller, thanks!
Yeah that limb is a problem. I'd rather not cut that limb off and leave a hole in the tree, but we may have to. After we get the bus out, I'll spend some time cleaning that area up of course.
RIP HBB 10.10.84 - 12.25.09
Autocrossing the 58 Rag - Subaru Swap!
1957 Gazelle Beige Ghia
1957 Dove Blue Kombi field find
schnidlee
schnidlee is offline
PostPosted: Tue May 23, 2023 4:31 pm    Post subject: Re: Early bus found in the weeds Reply with quote
Rule #1- Don't post pictures of a find online until it is in your driveway. Get yourself back out there ASAP and get this home before someone snakes you.
Looks like a great find, congratulations. Once you jack it up and put wheels on it, it will drag out easy even if the wheels aren't turning.
Alan Brase
Alan Brase is offline
PostPosted: Wed May 24, 2023 9:09 pm    Post subject: Re: Early bus found in the weeds Reply with quote
So true.
Just get it under your roof soon.
Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home
scrivyscriv
Samba Electrician
scrivyscriv is offline
PostPosted: Wed May 24, 2023 11:29 pm    Post subject: Re: Early bus found in the weeds Reply with quote
OTO X58 wrote:
that's a lot of turds
Robert in Memphis
Engine rebuild thread
Abscate Premium Member
Abscate is offline
PostPosted: Thu May 25, 2023 3:06 am    Post subject: Re: Early bus found in the weeds Reply with quote
Once you break it out of dry dirt, it will slide out with a good tow strap. No chains please. You won’t do any more damage pulling it out, if the frame folds from that, it was past economical repair already
hitest
hitest is offline
PostPosted: Sat May 27, 2023 7:39 am    Post subject: Re: Early bus found in the weeds Reply with quote
Find out what the county charges to dump all those scrap tires and offer that labor to do it. It may be a better offer than cash Think
FU#5
OTO X58
OTO X58 is offline
PostPosted: Thu Jun 08, 2023 2:30 pm    Post subject: Re: Early bus found in the weeds Reply with quote
So true.
Duly noted. I've heard wild stories in the bus community about folks getting swooped on their finds. I'm lucky it's still there, no joke. It's been over 10 years since I first posted about it. Shocked
ALL OVER the whole bus. I can't wait to get it all pressure washed. I had one rat basically jump over my back while I was cleaning out the cargo area. There was a whole coffee can full of turds in the engine compartment. Why would the rats climb into a coffee can to poop?
That's an excellent point. If this bus proves to have too much rot in the frame rails, it will be beyond my capabilities. Do you think it'll make a big difference to use straps instead of chains? Is that just for safety in case a chain breaks, or is it more about the straps being a bit softer on the metal?
We actually talked about that! There are so many tires around there- I think the property owner was taking them from people to dispose of for money for decades, and stacking them on that hillside. It's near a cliff with a beautiful river below. There's probably hundreds of tires all along the hillside and river bed. It'd be a major undertaking to remove them all. But the property would be so much better for it.
Eric&Barb
Eric&Barb is offline
PostPosted: Thu Jun 08, 2023 5:13 pm    Post subject: Re: Early bus found in the weeds Reply with quote
You can reach thru the lug bolt holes in the drums to reach the spines of the brake shoes with a long punch or other rod and hammer a few times to get the shoes to easily pop loose.
In Stereo, Where Available!
OTO X58
OTO X58 is offline
PostPosted: Thu Jun 08, 2023 6:05 pm    Post subject: Re: Early bus found in the weeds Reply with quote
Ah! nice. That's priceless advice, thanks!!
Eric&Barb
PostPosted: Thu Jun 08, 2023 7:15 pm    Post subject: Re: Early bus found in the weeds Reply with quote
Glad to help! Looking forward to more on your bus saga!!
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Thu Jun 08, 2023 7:47 pm    Post subject: Re: Early bus found in the weeds Reply with quote
However, that doesn’t always work. After 45+ years sitting in the same spot, the brakes on mine were fused.
And finally extracted the left rear drum.
Yeah, that’s ugly.
Dewayne Premium Member
Dewayne is offline
PostPosted: Thu Jun 08, 2023 8:37 pm    Post subject: Re: Early bus found in the weeds Reply with quote
GEEZE, That's some serious wear on that drum! The shoe must have been grabbing that lip something fierce... I'm surprised you got it off!
"My ex-wife had a hint of a beard and she looked like a manly-girl... that made no difference..."
Drive 'em if ya got 'em, and don't brag if you didn't do the work yourself...
'64 SO34
'60 SO23
Page 3 of 3
