The 1959 Franken Project
Matt_H
Matt_H is offline
PostPosted: Mon Mar 20, 2023 7:36 am    Post subject: Re: The 1959 Franken Project Reply with quote
Looking great ! Smile
What made you choose that bumper style - it's a 58 or earlier one I reckon..
Shoyrtt
Shoyrtt is offline
PostPosted: Mon Mar 20, 2023 2:11 pm    Post subject: Re: The 1959 Franken Project Reply with quote
I really like the look of a pressed bumper (up to 1958) on a dove blue bus with the bullet turn signals. I know they are not correct for a 59, but aesthetically they just complete the look to me. This 1960 was recently freshened up with a set of pressed bumpers and one of my favorite buses is this dove blue Kombi that is here in SoCal for inspiration.
http://www.cookersvdubs.com/tims-og-paint-60-kombi.html
Shoyrtt
Shoyrtt is offline
PostPosted: Wed Apr 05, 2023 1:35 pm    Post subject: Re: The 1959 Franken Project Reply with quote
Running both hard and soft radiator lines and brake lines on the bus. We tried to use an off the shelf air tank for the bags but they were all too big. Fabbed up an old piece of tubing to serve as the tank that sits outboard of the frame rail and is tucked up and out of the way. Cool
Shoyrtt
Shoyrtt is offline
PostPosted: Sat Apr 08, 2023 2:28 pm    Post subject: Re: The 1959 Franken Project Reply with quote
Cut the steering shaft down for the wheel placement. Also a picture of Jim’s brake booster with some plumbing.
Shoyrtt
Shoyrtt is offline
PostPosted: Sat Jul 15, 2023 6:41 am    Post subject: Re: The 1959 Franken Project Reply with quote
Again something different on the Frankenbus. Here is the clutch cable made by Control Cables. No bowden tube and it avoids any interference with the air bags.
ddutch
ddutch is offline
PostPosted: Sun Jul 16, 2023 4:20 pm    Post subject: Re: The 1959 Franken Project Reply with quote
Shoyrtt wrote:
Being an engineer, I want to mention that the holes you've cut out of the frame for the cooling tubes, have severly weaken this part of the chassis. It now has probably not even 50% of its original strength. The original heatertube was positioned in the middle of the height of the frame beam and left the upper and lower part of this rectangular beam intact, and has very little effect on it's strenght. Structurally it's comparable with a so called ''Castellated steel beam''. https://cmqconsulting.com/construct_material/castellated-beams/
If you close the holes in the beam under the pipes by welding in some metal plates of sufficient thickness, you'll probably be fine. The underside of the beam needs to be in one piece to be able to function as a beam. Wink
Shoyrtt
Shoyrtt is offline
PostPosted: Mon Jul 17, 2023 12:43 pm    Post subject: Re: The 1959 Franken Project Reply with quote
ddutch wrote:
Being an engineer, I want to mention that the holes you've cut out of the frame for the cooling tubes, have severly weaken this part of the chassis. It now has probably not even 50% of its original strength. The original heatertube was positioned in the middle of the height of the frame beam and left the upper and lower part of this rectangular beam intact, and has very little effect on its strenght. Structurally it's comparable with a so called ''Castellated steel beam''. https://cmqconsulting.com/construct_material/castellated-beams/
Thanks for that input. Yes we capped that lower beam, I just don’t have a picture of the final product. Here is a picture from the front looking rearward with the heater plumbing.
ddutch
ddutch is offline
PostPosted: Mon Jul 17, 2023 6:00 pm    Post subject: Re: The 1959 Franken Project Reply with quote
Good to hear that you've fixed it. Keep on going with the work on this nice project.
Shoyrtt
Shoyrtt is offline
PostPosted: Tue Jul 18, 2023 5:14 pm    Post subject: Re: The 1959 Franken Project Reply with quote
Thank you again for the advise! My youngest daughter just graduated with her masters degree last month and sent me this picture from her phone. She wanted to remind me that the bus was supposed to be driving by the time she finished school (apparently I said that at some point). I'm making a trip to Idaho to work on it in 10 days, so hopefully it is on the road soon. Very Happy
Her picture from 2019:
Shoyrtt
Shoyrtt is offline
PostPosted: Wed Jul 19, 2023 11:25 am    Post subject: Re: The 1959 Franken Project Reply with quote
I found these old pictures from when I picked up the nose. Hopefully there is a date on the back of the OG speedometer that will tell me what year it was built. My guess was 62-63 and that it was once converted into a "snail" camper with the bracing around the base of the B pillars.
PostPosted: Wed Jul 19, 2023 12:46 pm    Post subject: Re: The 1959 Franken Project Reply with quote
Probably early 63 (built in 62) since it has a spot for an emergency light switch but no emergency light on the dash.
Culito
11010101
Culito is offline
PostPosted: Sat Jul 22, 2023 10:01 pm    Post subject: Re: The 1959 Franken Project Reply with quote
Shoyrtt wrote:
The stainless exhaust is finished. Lots of cutting and tig welds to get it nice and tucked in.
Nice, I need to figure out something like this for my type 4.
© CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote:
Shoyrtt
Shoyrtt is offline
PostPosted: Sat Jul 29, 2023 11:17 pm    Post subject: Re: The 1959 Franken Project Reply with quote
I took a non-stop flight from John Wayne to Idaho Falls on Friday and worked on the bus today. Pulled the engine and trans and all of the accessories on the underside and then pressure washed and cleaned everything.
Beautiful part of the country.
brettsvw
brettsvw is offline
PostPosted: Sun Jul 30, 2023 7:48 am    Post subject: Re: The 1959 Franken Project Reply with quote
I think pressed bumpers compliment my early 59 kombi.
My 59 kombi build.
http://www.thesamba.com/vw/forum/viewtopic.php?t=635003&highlight=
My buggy build.
http://www.thesamba.com/vw/forum/viewtopic.php?t=558601&highlight=
http://www.thesamba.com/vw/forum/viewtopic.php?t=289807
Shoyrtt
Shoyrtt is offline
PostPosted: Wed Aug 02, 2023 6:39 pm    Post subject: Re: The 1959 Franken Project Reply with quote
That is a great looking bus Brett!
Shoyrtt
Shoyrtt is offline
PostPosted: Wed Aug 02, 2023 6:53 pm    Post subject: Re: The 1959 Franken Project Reply with quote
Lots of work completed on the bus this past weekend, but not a lot of pictures. Confused After pulling the engine and trans and spending a few hours cleaning, I painted and did some work to tidy up the frankenbus. We were then able to reinstall everything and did a little dimple die work in the engine bay, installed the wiring harness from AV Subaru Conversions and did the final routing of all of the plumbing, air lines, heater lines and brake lines. New shocks all around and I had some fun putting on the bullets and a set of headlights. We also installed the new bench seat and brackets. As you can see, we still need to work on adjusting the cargo doors, but it was a great time in Idaho. I need to do a big window purchase soon and plan another trip maybe in the fall.
https://avsubaruconversions.com/
Shoyrtt
Shoyrtt is offline
PostPosted: Tue Aug 22, 2023 1:39 pm    Post subject: Re: The 1959 Franken Project Reply with quote
Working on all of the details in the engine bay, new hoses, spark plug wires, air cleaner etc. Picked up an alternator relocation bracket from Outfront Motorsports. Still some hose clamps and other minor items to button up. Next up is wiring with a fuse block I got from Torque Resto Parts.
https://outfrontmotorsports.com/products/subaru-ej-offset-alternator-bracket-kit
https://www.torquerestoparts.com/product-page/bus-box
Shoyrtt
Shoyrtt is offline
PostPosted: Wed Sep 06, 2023 1:41 pm    Post subject: Re: The 1959 Franken Project Reply with quote
A few more updates on the Frankenbus. Jamar gas pedal from Moore Parts and platform are in up top. Down below we used the Butty Bits linkage to another silky smooth Control Cables set up. Finally, a picture of the fuse block so we can start the wiring.
https://www.mooreparts.com/jamar-performance-black-pro-x-aluminum-gas-pedal-with-round-openings/
https://resto-bus-parts.myshopify.com/products/throttle-pedal-kit-for-60-to-67-buses-by-buttys-bits
https://www.controlcables.com/
Shoyrtt
Shoyrtt is offline
PostPosted: Sun Sep 24, 2023 9:24 pm    Post subject: Re: The 1959 Franken Project Reply with quote
I made the drive this weekend to help with the wiring on the Frankenbus. The goal was to get it running. I sent Jeff at AV Subaru Conversions/AutoVentures the stock Subaru harness and the computer. In the ordering process I had to specify the make and model of VW it was going into along with the transmission. He returned it with everything tagged and labeled to help with the install. On the few items where we had questions, he was available by text message to send pictures etc. I can’t say enough on how easy he made the process. Nice to hear it rumble! Cool
Here are the gauges in test mode:
And I finally pulled the speedometer only to find it was not original to the nose:
Shoyrtt
Shoyrtt is offline
PostPosted: Thu Sep 28, 2023 2:45 pm    Post subject: Re: The 1959 Franken Project Reply with quote
Here is a picture of the Speedhut GPS speedo and tach:
Also prior to the start up of the engine, I mounted this Long Tru-Cool unit that I picked up at Kartek. It has a small fan between the cooler and the nose to serve as the heater. I can control the amount of hot fluid going through the system with the ball valve. We had a set up like this in one of our desert cars and it worked great.
https://www.kartek.com/parts/long-tru-cool-12-plat...-1-12.html
https://www.kartek.com/parts/spal-30103009-low-pro...4-cfm.html
Page 6 of 8
