Busstom Samba Member
Joined: November 23, 2014 Posts: 4585 Location: San Jose, CA
Posted: Tue Aug 22, 2023 9:18 am Post subject: Re: Fuel Pump Failure, Huge Leak, Safety Wire Fix |
| 67conv wrote: |
| Just a graphic reminder of what can, and in my case DID happen last Friday! The bottom photo clearly shows the outlet pipe had popped out of the fuel pump housing, allowing fuel to spew out and ignite! |
Holy Smokes! Your beautiful convertible! I never thought I'd see that either.
You are indeed fortunate  _________________ My name's Steve and it's pronounced "Bust 'em" (cuz people think I'm Tom)
| cory464 wrote: |
| if you aren't perfectly centered in the hole you will have issues when you tap it. |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36324 Location: Conejo Valley, CA
Posted: Tue Aug 22, 2023 9:22 am Post subject: Re: Fuel Pump Failure, Huge Leak, Safety Wire Fix |
| 67conv wrote: |
| I was extremely fortunate that someone who was witnessing the fire ran over with a fire extinguisher, as I foolishly didn't have one on board! Be forewarned! I never thought it would happen to me in 50 years of acvw ownership! |
Glad no one was hurt, and that your car wasn't damaged too severely (nice car!) |
iowegian  Samba Curmudgeon
Joined: February 16, 2005 Posts: 9983 Location: Somewhere between Dubuque and Keokuk
Posted: Tue Aug 22, 2023 9:53 am Post subject: Re: Fuel Pump Failure, Huge Leak, Safety Wire Fix |
| John, that sure sucks. But on the bright side, perhaps this will help in your decision to go back to the original Ruby Red color. (I know you need an excuse to use your N.O.S. fender beading) |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71896 Location: Phoenix 602
Posted: Tue Aug 22, 2023 5:23 pm Post subject: Re: Fuel Pump Failure, Huge Leak, Safety Wire Fix |
| 67conv wrote: |
Arggg, that sucks!
In addition to it popping out, I noticed that aftermarket tube doesn't go into the pump very far.
The original Solex ones have a longer tube that sticks in. _________________ How to Post Photos
Posted: Tue Aug 22, 2023 7:02 pm Post subject: Re: Fuel Pump Failure, Huge Leak, Safety Wire Fix |
Thank gawd the black plate survived! _________________ My name's Steve and it's pronounced "Bust 'em" (cuz people think I'm Tom)
| cory464 wrote: |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33450 Location: Hot Arizona
Posted: Tue Aug 22, 2023 7:06 pm Post subject: Re: Fuel Pump Failure, Huge Leak, Safety Wire Fix |
To be honest - it doesn't take much to safety wire that stuff in. And I worked four decades for a sister company of Loctite, and they - and Permatex - make good quality products. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 3360 Location: Memphis
Posted: Tue Aug 22, 2023 9:08 pm Post subject: Re: Fuel Pump Failure, Huge Leak, Safety Wire Fix |
I will always advocate for a threaded and barbed connection if at all possible. A 1/16" NPT barbed fitting is a good fit for most carburetors and fuel pumps that have the press-in style tubing inlet/outlet.
My charts show using an 'A' letter drill for the 1/16" NPT cut tap if taper reamed, or a 'C' drill if not reamed.
'A' drill size is .2340, which is only .0004" smaller than a standard 15/64" drill. I would not hesitate to use the 15/64" drill here.
The 'C' drill is .2420", with the closest fractional drill being 1/4" at .250", and I would not suggest using it. .080" is quite a lot of thread engagement to lose in soft aluminum.
I'm using 1/16" NPT to 4AN fitings on my parts, but I used a 1/16" NPT to 1/4" barb fitting on my bus carburetor with regular fuel hose and it worked very well.
https://www.amazon.com/MettleAir-Single-Tubing-Fitting-Connector/dp/B007QTZ3NM?th=1
https://www.amazon.com/Hose-Barb-Fitting-Brass-Units/dp/B07DJ5RB6X _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
wdfifteen Samba Member
Posted: Wed Aug 23, 2023 7:06 am Post subject: Re: weber? |
| bluebus86 wrote: |
one problem with a threaded fix is the that the tapered thread can exert tremendous force on the old, weaken, already stretched aluminum carb casting, and that could allow the casting to split. |
I think Solex carburetor bodies are cast from a zinc alloy, not aluminum. I could be wrong. |
67conv Samba Member
Joined: July 10, 2005 Posts: 464 Location: Simi Valley, California
Posted: Wed Aug 23, 2023 7:16 am Post subject: Re: Fuel Pump Failure, Huge Leak, Safety Wire Fix |
| EverettB wrote: |
Arggg, that sucks!
The original Solex ones have a longer tube that sticks in. |
And ironically - I have a rebuilt orig. Pierburg pump (and correct 205K dist., 30 PICT1) for this '67 tucked away for the moment awaiting installation on the early '67 H0 20xxxx long block going back in soon. This was my "driver" engine, and that damn fuel pump was a recent "lifetime guarantee" Auto Zone replacement unit, because their gold top version failed at the drive rod!
iowegian - I've been already working on that Ruby Red re-do this summer, actually! Painted the orig. factory fenders single stage Acrylic Urethane L456. Will do body next, putting that nos beading to work soon!
KTPhil - Thanks for your compliment! Yes, I had just dropped off my gf at a friend's house. Very lucky.
Busstom - I had the same thought on that black plate too! lol The stack of stickers got a little singed around the edges, but it survived pretty well, considering!
Lesson Learned! _________________ 1967 VW Convertible, owned 35 years.
1957 DKW 3=6, owned 21 years.
PREVIOUS: 1972 "Baja Champion SE" Spec. Edition Beetle bought NEW @ Pierce VW in Denver; 1979 Super Beetle Convertible bought NEW @ Downtown LA VW; 1967 type 1 savanna beige; 1967 Porsche 2.0 911S; 1973 Porsche 2.4 911T; 1963 356 T6 B Cabriolet; 1964 356 SC sunroof coupe; 1972 Type-3 Squareback; 1968 + 1969 Type-3 Fastbacks; 1987 Vanagon GL Weekender |
Cusser Samba Member
Posted: Wed Aug 23, 2023 7:31 am Post subject: Re: Fuel Pump Failure, Huge Leak, Safety Wire Fix |
| Cusser wrote: |
| To be honest - it doesn't take much to safety wire that stuff in. And I worked four decades for a sister company of Loctite, and they - and Permatex - make good quality products. |
Safety wire in this photo
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7569 Location: Houston, Texas
Posted: Wed Aug 23, 2023 7:34 am Post subject: Re: Fuel Pump Failure, Huge Leak, Safety Wire Fix |
That's a connection I would trust!
| scrivyscriv wrote: |
https://www.amazon.com/Hose-Barb-Fitting-Brass-Units/dp/B07DJ5RB6X |
_________________ www.vwnos.com [email protected]
viiking Samba Member
Joined: May 10, 2013 Posts: 3435 Location: Sydney Australia
Posted: Wed Aug 23, 2023 3:53 pm Post subject: Re: Fuel Pump Failure, Huge Leak, Safety Wire Fix |
| Cusser wrote: |
| .... And I worked four decades for a sister company of Loctite, and they - and Permatex - make good quality products. |
As did I Cusser, but not as long as you.
I agree wholeheartedly. Loctite puts a huge amount of time into research and by searching their database you will find a product that will "glue" that connection into place permanently. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
wcfvw69 Samba Purist
Posted: Thu Aug 24, 2023 5:32 am Post subject: Re: Fuel Pump Failure, Huge Leak, Safety Wire Fix |
| viiking wrote: |
| Cusser wrote: |
I agree wholeheartedly. Loctite puts a huge amount of time into research and by searching their database you will find a product that will "glue" that connection into place permanently. |
At the end of the day, if owners want to safety wire a fuel fitting on their carb or fuel pump, they should do that. If they want to thread in fuel fittings, by all means do that too.
I consulted with Loctite when selecting their product I use to secure those inlet and outlet tubes in both fuel pumps, carbs and other parts.
I then did a bunch of tests after reinstalling the tube in castings to see what it would take to remove the tube from the casting. They simply won't come out unless you get an acetylene torch and heat the casting up to 500° to melt the Loctite. Fuel exposure is not a factor as the connection where the tube is pressed in see's no fuel.
My VW's are running rebuilt carbs and fuel pumps with their tubes pressed in and secured with Loctite. I have zero worries about those connections after my tests before using it. Other qualified rebuilders also use loctite products to secure fittings, tubes and other nuts/bolts.
I tell all my customers that they need to check their carb brass fuel inlet tube for tightness as well. If my friend [email protected] has rebuilt the carb, no need to worry about that inlet tube. He secures them too. Those tubes are often not tight in the casting of unrebuilt carbs. You must Loctite them in. _________________ Contact me at [email protected]
The Samba member since 2004.
KTPhil  Samba Member
Posted: Thu Aug 24, 2023 10:10 am Post subject: Re: Fuel Pump Failure, Huge Leak, Safety Wire Fix |
Years ago I used to roll brass fuel fittings between two coarse files to dimple them, before re-inserting them. I used a little JB Weld, but the proper Loctite would be even better now.
My rebuilt carb (VolkzBitz) had a threaded and barbed fitting into the body; I may ask my fuel pump rebuilder (Sparxwerks?) to do the same when that time comes. |
mr matt Samba Member
Joined: May 26, 2005 Posts: 1018 Location: southeast Pa
Posted: Sat Dec 09, 2023 6:28 pm Post subject: Re: Fuel Pump Failure, Huge Leak, Safety Wire Fix |
JB weld is good enough. _________________ 1955 3-fold semaphore Oval beetle
1971 Convertible beetle
1977 Westfalia, FI, Berlin interior |
