Correct way to vent the crank case
Page: Previous  1, 2, 3, 4, 5, 6, 7  Next
BFB
BFB is offline
PostPosted: Sun Aug 20, 2023 10:13 am    Post subject: Re: Correct way to vent the crank case Reply with quote
It’s funny how big of a debate this subject is and its funny how most of you will all agree that no two engines are the same yet will make a blanket statement for or against extra case venting.
Also think ya’ll are trying to discuss case venting pro / con for two different reasons whether it needs it for windage or blow by and one guy will say he’s doing it for windage and the next guy says first guy has blow by issues. Heh heh. Just an observation…
Far as a 1/4” line not being big enough to do anything and that the alt stand should be sufficient, think of that this way. Ever pour something out of a container with just a spout vs. a similar container with a small vent tube ? Even a small vent helps the container breathe and circulate so it flows better without “gulping”.
Ive never had an engine have issues from being over vented, i have had them have issues from not enough.
Most experts aren't.
raygreenwood
raygreenwood is offline
PostPosted: Sun Aug 20, 2023 11:07 am    Post subject: Re: Correct way to vent the crank case Reply with quote
Well said....which is why my point is from a different "viewpoint".
A 1/4" tube may be not SEEM to be worth very much for case venting if its only looked at as venting the case just by its own pressure or just into ambient air pressure (venting to open air) or to very low/anemic vacuum (into the air cleaner of a carb).
But when you couple it with sizable manifold vacuum (the plenum of a fuel injection system) or connect it to an exhaust venturi pump.....that little 1/4" orifice can pull more case gas than almost any engine can deliver without a hole in the piston.
Ray
chrisflstf
chrisflstf is offline
PostPosted: Sun Aug 20, 2023 11:55 am    Post subject: Re: Correct way to vent the crank case Reply with quote
More opinions are always helpful, even if you dont agree with all of them.
I particularly like jim martins simple test of a glove on the breather stand as a simple way to measure blowby. Thanks for that info
Alstrup
Alstrup is offline
PostPosted: Sun Aug 20, 2023 3:02 pm    Post subject: Re: Correct way to vent the crank case Reply with quote
Next problem is, that that glove will be blown to pieces on anything off the shelf. In the last 4-5 years I have not seen one full set of cylinders being perfectly round. Sometimes 1, maayybe 2, but never a set. Which is why I hone everything before assembly.
https://www.thesamba.com/vw/forum/viewtopic.php?t=435993
chrisflstf
PostPosted: Sun Aug 20, 2023 4:27 pm    Post subject: Re: Correct way to vent the crank case Reply with quote
Dont know what your defination of perfectly round cylinders are, but this is mine:
https://ace-engines.com/product/aircooled-vw-cylinder-honing-services/
motomwo
motomwo is online now
PostPosted: Mon Aug 21, 2023 9:05 am    Post subject: Re: Correct way to vent the crank case Reply with quote
I noticed the alternator and generator stands spout filler passage tapers from 1" diameter at the top to 3/4" diameter at the lower end. There is enough material/casting to bore the hole straight through to 1" diameter. Boring it out 1" all the way through would allow for more breathing/venting capacity. Not sure why vw designed it that way... Just something I was thinking about.
Marty
1961 Bug, 2276 cb wedge ports 44x37 11.1 comp fk10 1.5 rockers 48idf's 1 3/4" header Rancho pro street trans SAW axles Airkewld 4# narrowed beam, Koni shocks, Airkewld dis brake all around. 5.5/4.5 BRMs
1966 Bug, 2127, panchito heads, fk8, 1.3 rockers, dual 44idfs, 1 5/8 merge header, Rancho pro strt flyer, empi axles, Airkewld's 4" beam and discs all around and adjustable shocks. 4.5 & 5.5 BRMs
modok
modok is offline
PostPosted: Mon Aug 21, 2023 5:25 pm    Post subject: Re: Correct way to vent the crank case Reply with quote
YEP, there are at least five different kinds of stands, actually a lot more than that. And the size of the cavity and passages is not all the same.
Most of the new builds I see people using alternators, but a surprising number of us are still using a generator.
Should do a poll
67rustavenger
67rustavenger is offline
PostPosted: Mon Aug 21, 2023 5:49 pm    Post subject: Re: Correct way to vent the crank case Reply with quote
Should do a poll
I do! Wink
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
oprn
oprn is offline
PostPosted: Tue Aug 22, 2023 6:16 am    Post subject: Re: Correct way to vent the crank case Reply with quote
Me too! The generator on my sand rail does everything I need to do. My Manx copy came with a type 1 engine and generator too and it worked perfectly fine. The ONLY reason it has an alternator now is because the type 4 engine I have in it now came with one.
slayer61
slayer61 is offline
PostPosted: Tue Aug 22, 2023 6:54 am    Post subject: Re: Correct way to vent the crank case Reply with quote
Love my 2 wire alternator. An idiot could hook it up and make it work... wait a minute... an idiot DID hook it up and make it work! Shocked Rolling Eyes Very Happy
Cusser wrote:
... Most folks are idiots when it deals with electrical !!!
67rustavenger wrote:
3/4 race cam? What's missing, one of the lobes? Shocked
Paul
'68 Manx clone... Sears??
RLR/Strange brakes
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
EMPI GTV 2 STG II wedge ports
MSD Box and distributor
1 5/8 merged collector w/ hater stinger
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger Facebook Twitter Instagram Gallery Classifieds Feedback
greenmachinemike
greenmachinemike is offline
PostPosted: Wed Aug 23, 2023 1:25 am    Post subject: Re: Correct way to vent the crank case Reply with quote
So after reading all six pages of this, I came to the conclusion that it’s probably best to experiment with different venting to figure out what works with my engine and driving habits. I’ve had a pretty bad spray all over my engine compartment since installing a rebuilt engine, which I recall having the same issue during the last couple years of its previous incarnation as an 1835 that I built from a new as41 braziian case last century. It’s now a 2021. I only had the oil line from the alternator stand to the street on the old engine, this time I transferred the breather box from the engine I used a couple years in between, a 1968. I only connected the 1-2 side valve cover, the fuel pump block off and the alternator stand to the box, cheapo Empi, and it would cover my engine and back of my bus and leave a puddle under the crank pulley every time I make the trip from Oakland to Santa Cruz, about twice a week. If you’ve seen my green and black bus on the 880/17 you would probably guess I have crankcase pressure issues, because I’m going 75-80 mph! So today I connected the fourth outlet of the breather box to one of my stupid expensive CSP air cleaners, I didn’t enjoy drilling and tapping such a beautiful piece of art, changed the oil, wiped down every bit of oil I could see and drag raced it up and down the 24 going through the Caldecott a couple times. I’m sure I looked insane. But I am happy to report a complete lack of macro-lubricating! Time will tell if sucking in all that Penn grade I used to wipe off with paper towels will reak havoc on the unlucky IDF who’s only crime was being closest to the unused port on the breather box, but for now, problem solved. If it’s only temporarily successful, I’ll try something else since many of the builders I respect in this community can’t seem to reach a consensus.
59’ Kombi, 64 Manx
slalombuggy
slalombuggy is offline
PostPosted: Wed Aug 23, 2023 5:24 am    Post subject: Re: Correct way to vent the crank case Reply with quote
slayer61 wrote:
Love my 2 wire alternator. An idiot could hook it up and make it work... Shocked Rolling Eyes Very Happy
You would think that, but twice week on fb dunebuggy pages someone asks why their alternator won't charge after they hooked it up wrong......
slayer61
slayer61 is offline
PostPosted: Wed Aug 23, 2023 6:51 am    Post subject: Re: Correct way to vent the crank case Reply with quote
Shame on you for going on the farcebook! Shame on you Applause Very Happy
Paul
RLR/Strange brakes
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
slalombuggy
PostPosted: Thu Aug 24, 2023 4:27 pm    Post subject: Re: Correct way to vent the crank case Reply with quote
But I like fb, I feel super smart when I'm on it. When you're only of mediocre intelligence, it's nice to be surrounded by idiots sometimes.....🤣
If it wasn't for that it's the only place I can keep up with my lsr buddies I would avoid it like the plague.
onehappykombi
onehappykombi is offline
PostPosted: Thu Jul 10, 2025 8:26 am    Post subject: Re: Correct way to vent the crank case Reply with quote
Hello all!
My engine is a 1679, very close to stock but with a sand seal pulley. It’s having occasional crank case pressure problems. I think I just need a small bit of additional ventilation with the following restrictions:
- mechanical pump so can’t vent there
- don’t want to vent valve covers
- as simple solution as possible
Would it make sense to just add a venting port at either of the locations I marked below with red circles?
Thank you!
'56 Early Split & '69 Early Bay
Overlanding the USA
Camper special engine build
raygreenwood
PostPosted: Thu Jul 10, 2025 8:40 am    Post subject: Re: Correct way to vent the crank case Reply with quote
Um....what is that fat hose doing right next to the smaller red circle? Isn't that a vent port?
Man that is like a 12mm ID hose. If you are still having venting problems with that....drilling another hole next to it will likely be of no help.
Describe what is happening in detail and I would bet that someone here has a better answer.....like oil slinger issue or too much oil at the sand seal point etc.
Ray
EVfun Premium Member
EVfun is offline
PostPosted: Thu Jul 10, 2025 9:44 am    Post subject: Re: Correct way to vent the crank case Reply with quote
6 pages and I still don't know the correct way to vent the crank case.
I do know THIS is the incorrect way!
(image by fastorange72)
Wildthings wrote:
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu Jul 10, 2025 9:54 am    Post subject: Re: Correct way to vent the crank case Reply with quote
Maybe bad rings are causing the internal pressure.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
motomwo
PostPosted: Thu Jul 10, 2025 11:11 am    Post subject: Re: Correct way to vent the crank case Reply with quote
Where or what is the hose connected to on the end that is not shown in the picture? Maybe a fitting/hose nipple that has a much smaller inside diameter than the hose?
Marty
ZEKE65
ZEKE65 is offline
PostPosted: Sun Jul 13, 2025 7:40 am    Post subject: Re: Correct way to vent the crank case Reply with quote
I added a 3/4" filter to the bottom of the stock filler drain for a vent.
1965 VW Sedan, 1968 C10 Step BB, 99 C5
Page 6 of 7
