can't remove torsion leaves from upper beam HELP!
lightspeed
lightspeed is offline
PostPosted: Mon Aug 28, 2023 8:35 pm    Post subject: can't remove torsion leaves from upper beam HELP! Reply with quote
Hi...
I am tearing down my beam in my 64 splitty.
I took everything apart easily enough including the grub screws in center.
The lower leaves slid out with a little persuasion and the upper ones are stuck.
I could only move them about an inch back and forth with a lot of pounding. I had to walk away before I completely destroyed the leaves with a sledge.
Any ideas on why they would be so difficult? Just crap in there? Is there a method to removing stuck leaves? Am I just an idiot?
I would have tried heat but I only have a homeowner torch with mapp gas.
Help!!!
chrisflstf
chrisflstf is offline
PostPosted: Tue Aug 29, 2023 7:14 am    Post subject: Re: can't remove torsion leaves from upper beam HELP! Reply with quote
Can you tap out one of the smaller leaves by itself from the pack? That would give room for the rest. Maybe they are welded though?
Lind
Lind is offline
PostPosted: Tue Aug 29, 2023 7:43 am    Post subject: Re: can't remove torsion leaves from upper beam HELP! Reply with quote
Try pushing them to the other side. The might have some rust on them making them not want to slide through the center block. I recently removed some from a beam that were bent on one side, so they would only come through one way.
Wanted:
lightspeed
PostPosted: Tue Aug 29, 2023 2:20 pm    Post subject: Re: can't remove torsion leaves from upper beam HELP! Reply with quote
Thanks for the reply.
Soaked in PB all night and put a socket over the end. With a large sledge they finally freed up and came out. Amazing how they came out undamaged. They are stronger than they look!
