Replaced the clutch, blew up the engine? - NO oil pressure
damagd
damagd is offline
PostPosted: Tue Oct 03, 2023 7:31 am    Post subject: Replaced the clutch, blew up the engine? - NO oil pressure Reply with quote
I highly doubt that they're related, but that's what happened. 1985 1.9. Removed tranny to install new clutch. Engine needed oil after reinstalling, topped up with 10w30 Castrol High Mileage because that's all I had laying around (been laying around my garage for like 10 years if that matters). Engine did have 20w50 in it, so they got mixed together. In short, the oil light came on after about 10 miles. Would go off if I kept the RPM's under around 2500. Not leaking oil. If anything, oil was maybe a little too full. Got stuck in cattle chutes on the highway, had to keep moving. Engine lost some power and is tapping pretty badly. No knocking. Towed home. Tested oil pressure with a tester. No psi at any rpm. Engine does not sound very good because of the tapping. Question is, what damage has definitely been done? I'm willing to rebuild as this engine has a lot of miles on it anyway and I have the time to do it. Just need to know what I'm looking at. Or possibly purchase a good used engine to keep me running. Also open to swapping (Subie, Bostig, etc....but haven't really researched any of that yet.) I just find it REALLY hard to believe that a good running engine all of the sudden lost it's oil pressure at the same time the clutch was replaced.
MarkWard
MarkWard is offline
PostPosted: Tue Oct 03, 2023 7:56 am    Post subject: Re: Replaced the clutch, blew up the engine Reply with quote
The 1.9 is a stout bottom end. It’s really unlikely you caused a problem by mixing oil brand and viscosity.
Did you have the flywheel off? How are you checking the actual oil pressure to determine it’s zero? Even an engine with a spun bearing will have some oil pressure.
Probably time to dump the oil and see how it looks. A clean catch pan. Report back. Sorry.
bobhill8 Premium Member
bobhill8 is offline
PostPosted: Tue Oct 03, 2023 7:59 am    Post subject: Re: Replaced the clutch, blew up the engine Reply with quote
I'm no expert, but it's hard to imagine that there is NO OIL PRESSURE at any RPM. Are you confident that the test was performed correctly? I would start there before making any big decisions.
EDIT: Listen to Mark
1986 Westy
1971 Squareback
Silverghost500
Silverghost500 is offline
PostPosted: Tue Oct 03, 2023 8:07 am    Post subject: Re: Replaced the clutch, blew up the engine Reply with quote
Are you basing it not having oil pressure on the oil light, or an actual oil pressure gauge connected to the engine?
1986 Volkswagen Vanagon Westfalia "Von Westy"
Honda K24A conversion
3-Speed Automatic
Von Westy YouTube Channel
https://www.youtube.com/channel/UCbhyZYxJEQrUuLnMbLleeIA
Sodo
Sodo is offline
PostPosted: Tue Oct 03, 2023 8:22 am    Post subject: Re: Replaced the clutch, blew up the engine Reply with quote
Dang it. Out of the frying pan and into the fire. Hope you can get thru this. I think there are more than a few used take-out engines available, hopefully in your geographical area.
One thing to note is mixing engine oil weights, ages or brands cannot contribute in any way to failure. It makes no difference whatsoever..
(oil pressure light?) Would go off if I kept the RPM's under around 2500. Not leaking oil. If anything, oil was maybe a little too full.
What do you mean by “a little too full?” Do you know how far above the full mark it was?
If the engine had “way too much oil”, there can be “oil foaming” and loss of pressure at higher RPMs. And the oil light may come on, oil light indicating loss of oil pressure at high RPMs almost ensures the engine will “blow” or ruin a rod-bearing shortly. Which would make a terrible noise.
In theory. Not sure how well-studied “way overfilling a WBX” is, or who studies it, how well it’s studied, who reports on it, or how reliable the reports are. I’m currently considering it “plausible”.
Does anyone know how a 1.9 behaves when over-filled with oil? Can it foam the oil (near the pickup) below the camshaft? In general this would NOT be a condition “studied thoroughly”, nor “repeatedly “. Confused
....KTMs, GasGas, SPOT mtb
MayorMcCheese
MayorMcCheese is offline
PostPosted: Tue Oct 03, 2023 8:55 am    Post subject: Re: Replaced the clutch, blew up the engine Reply with quote
MAYBE it's not going to cause a failure, but mixing in a lower weight oil is absolutely going to result in lower oil pressure.
Sodo
Sodo is offline
PostPosted: Tue Oct 03, 2023 9:11 am    Post subject: Re: Replaced the clutch, blew up the engine Reply with quote
Mayor I'll give ya "absolutely" for lower pressure if you give me some conditions
    -old, loose engine
    -engine warm
    -at idle
    -oil filter that has higher filtration & back-pressure
    -mostly "lower weight oil" with just a little of the heavier oil.
But for this thread.......I'll 'hold' on the
    -"MAYBE (failure cause)"
    -2500 RPM oil pressure loss
zerotofifty
zerotofifty is offline
PostPosted: Tue Oct 03, 2023 9:32 am    Post subject: Re: Replaced the clutch, blew up the engine Reply with quote
Cattle chute? what is that? How you get stuck on one? I have driven over plenty of cattle GRATES, never got stuck on it.
You kept moving with low oil pressure warning and tapping noise? Good grief, you beat it to death. When the light comes on, you shut down, dont keep going unless Godzilla is after you, in which case you wont go far.
Sorry About That Chief.
Give Peace a Chance.
Words to live by.
E1
E1 is offline
PostPosted: Tue Oct 03, 2023 10:09 am    Post subject: Re: Replaced the clutch, blew up the engine Reply with quote
Without knowing just what “too much oil” and “tapping” means, it’s hard to know.
I like Sodo’s concept of oil foaming, but pressure has to be WAY LOW to trigger the light. But I think this is your possible issue.
These vans hate even oil at the top mark. Many of us know it burns off to where it wants to be, I run it *below* a quarter-distance up from the low notch.
When overfilled at all above the high notch, it *will* clog the breather, and my personal theory is that’s where excess oil burnoff happens by crankcase pressure forcing tiny amounts of oil from the breather into the hose going to the intake — but so minutely it may not produce blue smoke. Remove and clean that hose, and possibly the intake boot, I’ll bet they’re full of oil.
You might drain the oil and see if it’s metallic. If it is, worries grow. No issues mixing oil grades or even types, but over time or as a habit it’s not recommended. Mobil 1 15/50 synthetic for me, though it might make seal leaks show up that may not show with 20/50 dino oil.
I very much doubt you hurt the engine so quickly. Once when I filled it above the top mark (for only the one time!!!!!), it *did* trigger a weak and flickering pressure light. Was it running really hot when it was loud?
I’m backing Sodo’s foaming oil theory. It makes great sense that could trigger the pressure light. When you drain it, please measure how much was in there as a knowledge base for us all. A compression test is also advised, but ONLY after replacing the oil and to the proper amount.
I pour in barely more than four quarts after a change, including a new filter, idle maybe 30 seconds, check stick after five minutes (it reads lower if done immediately), add about 6 oz. at a time, and redo the process to check again. I like 0.1 to 0.25 on the stick.
I also am totally sold on a quart of Lucas Oil Conditioner per change, the tappet silencing on startup is Uge. I like Marvel Mystery Oil, too, but mostly in the fuel from time to time.
Good Luck and let us know what’s up.
1984 Westfailure/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
AI has spoken to further illiteracy, to steal, to cheat, and to replace humans
— Colin Chapman
Jonathan Weisheit, Race in Peace:
https://www.youtube.com/watch?v=z3dS7xiFn7I&t=500s
zerotofifty
PostPosted: Tue Oct 03, 2023 10:33 am    Post subject: Re: Replaced the clutch, blew up the engine Reply with quote
I note that my van burns off oil between 1/4th and full marks on the dipstick, then stays pretty darn steady at 1/4th mark for the rest of the time.
Words to live by.
mikemtnbike
mikemtnbike is offline
PostPosted: Tue Oct 03, 2023 10:49 am    Post subject: Re: Replaced the clutch, blew up the engine Reply with quote
Assuming this is same as what I call the "corridor of death" on I-26 near me where construction has choked lanes down to two with concrete barriers on both sides and no shoulder or break down lane. When it's bumper to bumper stacked with 18 wheelers, it certainly feels like breaking down or pulling over would be very dangerous.
2020 GTI SE manual
damagd
damagd is offline
PostPosted: Tue Oct 03, 2023 12:27 pm    Post subject: Re: Replaced the clutch, blew up the engine Reply with quote
Thanks for all of the responses...
Yes, I took the flywheel off to replace the pilot bearing and rear main seal. I screwed my pressure gauge where the oil pressure sender is located by the push rod tubes. Maybe I didn't have it screwed in far enough to have it fully seated? I will try again. I did drain about a half a quart the next day and it looked fine.
When I checked it the next day after getting it towed home, it was at the full mark. AFAIK it's only supposd to be halfway between the marks. When I checked it on the highway after running it for a while, it appeared to be well above the full mark.
Forgot to mention...At absolutely NO point did the temperature rise above normal.
Yeah man, pretty much exactly what I was dealing with.
E1
E1 is offline
PostPosted: Tue Oct 03, 2023 12:54 pm    Post subject: Re: Replaced the clutch, blew up the engine Reply with quote
Change oil, clear breather hose, check compression, and I think likely you’ll be good to celebrate.
— Colin Chapman
MarkWard
MarkWard is offline
PostPosted: Tue Oct 03, 2023 12:57 pm    Post subject: Re: Replaced the clutch, blew up the engine Reply with quote
The fitting in the case is open to the oil galley. Worse case, you installed it too deep, but I doubt that.
Is your gauge and hose trustworthy? Maybe something is plugging the hose? Try blowing compressed air and see if you get some gauge movement.
If you had the flywheel off, did you check the endplay before and after? It could be possible to not have the shims seated properly. But that’s a stretch.
Bottom line, if the engine truly has no oil pressure, there is a restriction in the pickup, the oil pickup is not sealed to the case, or the oil pump drive has failed. It’s unlikely not a stuck open pressure piston.
All unrelated to the clutch job or the oil mixing. Assuming your gauge is correct, I’m afraid it’s serious and you should drop the oil into a clean pan as I suggested earlier.
tjet
tjet is offline
PostPosted: Tue Oct 03, 2023 2:48 pm    Post subject: Re: Replaced the clutch, blew up the engine Reply with quote
I've had the oil buzzer come on when mine was too full. Removed some oil (middle dipstick mark) all good.
BTW, I would not use 10 year old oil.
Sodo
Sodo is offline
PostPosted: Tue Oct 03, 2023 8:33 pm    Post subject: Re: Replaced the clutch, blew up the engine Reply with quote
Yes the oil light goes on pretty low. I think something like 3psi. If the oil is foamed, oil pressure goes to zero.
I don’t have the slightest idea if some kind of oil mixing can result in oil foaming.
If XYZ Corp’s oil causes foaming when mixed, the military ain’t buying it, OEMs ain’t gonna recommend it. It would be a pretty big f-up for any company trying to make payroll etc putting engine oil out that causes foaming.
E1
E1 is offline
PostPosted: Wed Oct 04, 2023 3:38 am    Post subject: Re: Replaced the clutch, blew up the engine Reply with quote
No idea if mixing oils can cause foaming, but that running too much oil can.
— Colin Chapman
Wildthings
Wildthings is offline
PostPosted: Wed Oct 04, 2023 4:36 am    Post subject: Re: Replaced the clutch, blew up the engine Reply with quote
Sure we aren't looking at an early 1986 model with a dynamic oil pressure warning system? That would cause the light to come on at higher rpms and not lower ones. If your tapping is the hydraulic lifters bleeding down you may well be fine once your determine what is wrong, but if its the bearings, its likely going to be time for a replacement engine.
It would be hard to mess up the fairly simple thrust bearing shims on the crank of a 1.9L engine while reinstalling the flywheel, whereas with the 2.1L the one shim can fall out of place and cause problems, it needs to be held in place with grease when installing.
Trying to reset loose crank end play on a 1.9 would be a no no and if you did so you might have spun the thrust bearing, just like with a Type 1. Not very likely this would happen though.
damagd
damagd is offline
PostPosted: Wed Oct 04, 2023 11:36 am    Post subject: Re: Replaced the clutch, blew up the engine Reply with quote
Bench tested pressure gauge, and it works. Hooked up to engine and made sure it was in snug. Still zero pressure at idle or 2500 with engine warmed up. Waiting for oil to cool and will empty it to see what I got...
damagd
damagd is offline
PostPosted: Wed Oct 04, 2023 12:48 pm    Post subject: Re: Replaced the clutch, blew up the engine Reply with quote
Drained the oil. Oil looks normal. Oil dripping out of the hose to my pressure gauge was very foamy after I disconnected it. Oil Breather tower hose was clear. I find it hard to believe that the oil pump went out coincidently while changing the clutch. Oil light came on after about 20 miles of driving since the change. I'm starting to lean towards something getting messed up with the rear main seal shim area since that's the only part of the engine that I messed with, replacing the rear main seal. Is this a possible area to cause some sort of clog?
Page 1 of 9
