1973 Porsche 911 T suspension upgrade options
jaredlgoldman
jaredlgoldman is offline
PostPosted: Tue Aug 22, 2023 8:12 pm    Post subject: 1973 Porsche 911 T suspension upgrade options Reply with quote
I have a 1973 911 T that I am starting a restoration on. The car is stripped down to the shell and getting sandblasted as we speak
I want to upgrade the suspension to make it a better driving car. This will be a daily driver, no track days for now but I want it to perform well.
I am NOT doing a factory restoration, seeing that I don't have the original motor or trans.
My question for all of you experts out there, I am looking at three options
Option 1:
Stick with the current set, replace bushings, rebuild struts, clean up all the arms, etc. Keep the torsion bars front and back, keep sway bar
Option 2
Keep the control and trailing arms, add Turbo tie rod ends and change out to a coil over set up for shocks, keep sway bar and torsion bars
Option 3
Go all new on the suspension, 935 subframe with new control arms, coil over shocks, re-enforced shock towers, upgrade sway bar, etc. Get rid of torsion bars front and back
I want to add bigger breaks, 3.5" brackets. They will not fit on the stock 73' spindles.
I have been told I can upgrade to new components but am getting mixed opinions. Any assistance would be appreciated
[email protected]
dr914@autoatlanta.com is offline
PostPosted: Thu Aug 31, 2023 8:52 am    Post subject: Re: 1973 Porsche 911 T suspension upgrade options Reply with quote
the suspension is perfectly good as is if everything is up to par. Check the shocks lubricate the a arm bushings check the tie rods and ball joints and you will be all set, (also replace the rubber brake flex lines and repack the wheel bearings. The car has a GREAT front end on it, no reason to change it
Dane Tyler
Dane Tyler is offline
PostPosted: Fri Sep 08, 2023 7:12 am    Post subject: Re: 1973 Porsche 911 T suspension upgrade options Reply with quote
I vote Option 1 with the addition of Turbo tie rods.
Torsion bars are fine. They work well here.
The Turbo tie rod ends are a worthwhile upgrade.
Elephant Racing makes excellent replacement suspension bushings. I would highly recommend.
This is how I setup my 75 911S, along with new Koni struts and shocks and lowering to Euro height. I only went with Koni because the originals were Koni. I typically prefer Bilstein.
Good luck.
Option 1:
Option 2
Option 3
wrxnofx
wrxnofx is offline
PostPosted: Wed Oct 04, 2023 2:00 pm    Post subject: Re: 1973 Porsche 911 T suspension upgrade options Reply with quote
There is WAY more information on these types of topics over on Pelican Parts.
You'll get way more engagement from those folks on this topic:
https://forums.pelicanparts.com/porsche-911-technical-forum/
1977 VW Type 2 Bay Window Westy FI
