freakyvwfan Samba Member
Posted: Tue Sep 06, 2005 1:54 pm Post subject: '63 KING AND LINK PINS |
I am installing (attempting) CB drop spindles on the front of my '63. I was wondering if anyone has any suggestions to someone who has not attempted to do the CB spindles on a King Pin front end. I have done it before on my '67 'vert (balljoint) and it seemed pretty straight forward. I have disconnected everything from the factory spindle and am attempting to get the spindles off the torsion arms.
Thanks in advance for all the assistance.
FreakyVWFan |
glutamodo  The Android
Joined: July 13, 2004 Posts: 26601 Location: Douglas, WY
Posted: Tue Sep 06, 2005 2:46 pm Post subject: |
from where you are at, it's pretty easy. Unbolt and remove the clamping bolts for the link pins. Then carefully tap outward on the square heads of the link pins (fat punch and hammer) alternating between the upper and lower pin, and the spindle assembly should come out.
andy |
Posted: Tue Sep 06, 2005 3:23 pm Post subject: |
Thanks for the response. Is it difficult to take the king pins apart once they are out of the car?
Thanks again for the advice.
Freakyvwfan |
Bklyn63 Samba Mafioso
Joined: August 24, 2002 Posts: 966 Location: "What am I, a mirage?"
Posted: Tue Sep 06, 2005 5:06 pm Post subject: |
| you need to take the king pin out its the long pin running vertically, I reccomend using a brass piece of pipe and hitting it with a hammer if you cant access a press. |
Jarrett Samba Member
Joined: July 27, 2004 Posts: 20 Location: Knoxville, TN
Posted: Tue Sep 06, 2005 5:23 pm Post subject: |
| I installed mine last week. Everything went well except for the king pins. After beating on them for a couple of hours I went to a machine shop. If you don't have access to a press I would suggest having a machine shop press out the old bushings and pins and install the new ones. $37.18 and 2 hours later they were done. Hope this helps. |
Posted: Tue Sep 06, 2005 5:25 pm Post subject: |
yes, I've always had a machine shop do the king pins...
andy |
NorCalLowLife209 Mr. Saran Wrap
Joined: January 23, 2004 Posts: 932 Location: Stockton, CA NOR * CAL
Posted: Tue Sep 06, 2005 8:17 pm Post subject: |
Im getting dropped spindals, do i have to change my king and link pins? Or its just the safe way to go? _________________ 1967 VW type 1 (sold)
1963 VW type 1 (sold)
2011 VW GTI |
Posted: Wed Sep 07, 2005 6:50 am Post subject: |
Thanks for all the advise and taking the time to respond. It will make the project go alot smoother.
Freakyvwfan |
Posted: Wed Sep 07, 2005 7:32 am Post subject: |
| you can reuse the king pin..I would replace the links with the bushings. |
Mr. Fickits Samba Member
Posted: Wed Sep 07, 2005 12:56 pm Post subject: |
| I just installed the same drop spindles on a 64. 6-ton hydraulic was not enough to get king pins out. I tried propane in conjuction with the press and that still did not do it. I had to heat with acetylene while applying pressure then the king pin finally came out. micrometer indicated there was a .010" press . Someone should design a splined spinlde/knuckle. |
Posted: Thu Sep 08, 2005 11:52 am Post subject: |
I want to thank everyone for the responses. I took the spindles to a local VW Speed ahop and they rebuilt the king and links with the lowered spindles and I just need to install them.
Thanks Again!! |
Posted: Fri Sep 09, 2005 1:53 pm Post subject: |
I have another question. When installing the spindles, are there any "tricks" or suggestions to re-setting the camber?
Any help would be appreciated.
Thanks! |
glandnut 40 horses of Fury
Joined: February 26, 2003 Posts: 1432 Location: J-ville, FL
Posted: Fri Sep 09, 2005 3:09 pm Post subject: |
Camber is set with the shims that should have come in the rebuild kit, check a Bentley or the Idiot's Guide for simple, easy instructions. Once you set it, forget it. Toe in will need to be done at an alignment shop, or you can get it real close using the yardstick trick, also found in the Idiot's Manual. _________________ Looking for aluminum single port Kadron manifolds. |
