Unusual Rear Suspension ? / Need Help
Tee Dub
Location: Probably in the shop,but maybe takin' a nap...
Tee Dub is offline
PostPosted: Wed Sep 07, 2005 7:06 am    Post subject: Unusual Rear Suspension ? / Need Help Reply with quote
My project car is a '56. PO's were building a race car and installed a '61 transmission with what looks like Porsche 356 C disc brakes all around. The bottom rear shock support goes out to the rear of the axle instead of the front and I can't visualize how to get a shock on there. Anyone here have any ideas or seen this setup ?
Teeroy Premium Member
Teeroy is offline
PostPosted: Wed Sep 07, 2005 8:29 am    Post subject: unusual rear suspension / need help Reply with quote
Swap axle tubes from one side to the other . The 356 either has a different upper shock location , or they are installed backwards . If you haven't bent the metal brake lines you might switch the brakes to the other side as well (put the caliper to the rear of wheel , not front as it is now) TROY
Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org
Tee Dub
Tee Dub is offline
PostPosted: Wed Sep 07, 2005 9:24 am    Post subject: Reply with quote
Hi Troy ! Thanx for your interest in my problem. Swapping the tubes was my first inclination. I haven't taken them apart yet, but just visualizing it, it seems that the trio of bolts at the spring plates would no longer line up ?
I too thought the calipers should be at the rear. I hope I can find a way to use this setup. Do you think I should use a dual circuit master cylinder ? Do you know which application ?
sixfootdan
Samba Smartass
Location: \Lo*ca"tion\, n. 1. The act or process of locating.
sixfootdan is offline
PostPosted: Wed Sep 07, 2005 11:55 am    Post subject: Reply with quote
PM camerod perhaps he can help you?
Camrod's pic from the gallery,
http://www.thesamba.com/vw/forum/album_page.php?pic_id=73827
Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!!
74Standard
74Standard is offline
PostPosted: Wed Sep 07, 2005 12:35 pm    Post subject: Reply with quote
Aren't the trio bolts symetrical? I mean it looks like if you just take the bolts out and rotate the whole assembly you should be able to get it to line up... Could be wrong, never put one in wrong just to see if it would line up. Shocked
Tee Dub
Tee Dub is offline
PostPosted: Wed Sep 07, 2005 3:42 pm    Post subject: Reply with quote
I dunno '74...... seems to me if I reverse the tubes, that third bolt would be hanging way out the rear alone non ?
Thanx for the lead Meanirish !
74Standard
PostPosted: Wed Sep 07, 2005 3:58 pm    Post subject: Reply with quote
I didn't say reverse them, I think that was what Teeroy was talking about doing. I said rotate them, take the bolts out, and just rotate the mount towards the front of the pan. The holes should still line up.
Maybe I'm looking at the picture wrong, but that's what it looks like to me. Also, you should be able to rotate the caliper mounts to the rear the same way. Those holes are symetrical also.
Tee Dub
Tee Dub is offline
PostPosted: Wed Sep 07, 2005 4:03 pm    Post subject: Reply with quote
Thanx for sticking with me on this '74, I'll take a closer looksee.....
Tee Dub
Tee Dub is offline
PostPosted: Wed Sep 07, 2005 4:36 pm    Post subject: Reply with quote
Anyone know a guy named Donny Reade ? I hear he used to work for Ralph Meaney VW Repair Shop in Framingham, MA around 1980.
I just got word he is the guy who put this rear end together........ sure would like to hear from him what he had planned. His workmanship is excellent !
camerod
Volksfab
camerod is offline
PostPosted: Thu Sep 08, 2005 1:22 am    Post subject: Reply with quote
you are correct that those are 356C rear brakes and axle tubes, YES the porsche parts are a direct "bolt on" to a swing axle beetle! since 356's have the shock mounted to the rear of the axle you cannot "bolt"
shocks directly in a beetle when using this setup...BUT you can fabricate brackets to replicate the stock type beetle shock mounts then sandwich/bolt them in place using the 3 12mm springplate bolts ! .. you can cut off the un-needed porsche hangers ..or just leave them in place as they wont really be in the way. just remember, IF you decide to cut the no longer needed 356 shock hangers off of your axle tubes you will be making them useless to any potential 356 owner ..IF you ever decide to sell them! 356C brakes are pretty desireable and valuble(porsche guys often use them to "upgrade" earlier drum brake 356 cars)
DON'T SHIT WHERE YOU EAT!
Teeroy is offline
PostPosted: Thu Sep 08, 2005 9:47 am    Post subject: unusual rear suspension need help Reply with quote
Looking at the pics again and reading everones posts , the holes won't line up swaping sides or twisting the tubes (sorry brain fart). If the brake brackets will bolt to beetle tubes fine , you could go that route or build some upper shock mounts like Cameron said . TROY
ARR #3
Tee Dub
Tee Dub is offline
PostPosted: Thu Sep 08, 2005 10:54 am    Post subject: Reply with quote
Hi Teeroy....... I agree that swapping and twisting won't work, but what I got from reading Camerod's post is the fabbed bracket would be the Bottom mount, not the top Question ....... ie: Use the top stock VW mount that's there and Fab a new bottom mount that goes out towards the front like stock, to replicate what's missing. This would allow you to cut off the 356 bottom mount going to the rear if you had a mind ( or no mind ) to do so. ( NOT recommended )
camerod
Volksfab
camerod is offline
PostPosted: Thu Sep 08, 2005 11:35 am    Post subject: Reply with quote
..you got it!
troy, the caliper brackets are cast into the bearing housing so you unfortunatelly cannot bolt them to the beetle tubes..
Teeroy is offline
PostPosted: Thu Sep 08, 2005 3:21 pm    Post subject: unusual rear suspension need help Reply with quote
Wasn't sure , the only 356 tubes I have had were drum brake . TROY
ARR #3
Tee Dub
Tee Dub is offline
PostPosted: Thu Sep 08, 2005 4:40 pm    Post subject: Reply with quote
Camerod, thanx for coming to the rescue with the right answers ! At the risk of of asking too much of your time, what have you got for ideas for said fabrication with support and asthetics in mind ? I don't have the skills for the job, but would like to bring some ideas to the welder....... I do have a stock rear end at hand, can some of that be used ?
For those interested, from another site, here's what a stock 356 C set up looks like.
Tee Dub
Tee Dub is offline
PostPosted: Fri Sep 09, 2005 4:01 pm    Post subject: Reply with quote
Hey....... Just a note to tell everyone THANK YOU for your help and ideas, before this thread dies and is forgotten
