Medic Zero Samba Member
Posted: Tue Apr 28, 2020 9:08 pm Post subject: 1967 door lock woes, replacement? |
Does anyone sell new lock cylinders I can install as replacements? Or new complete door handles that have the same profile cylinders that I can pull out and install in my 1967 door handles?
Any trick to reinstalling the door handles? I'm not seeing anything like a trick to it in the few tutorials online, but could I have messed up by having the door locked or unlocked when I reinstalled the handles or somehow otherwise not lined things up properly?
I picked up a (January) '67 a few months ago, strong mechanically, somewhat rough otherwise, with lots of little issues I'm looking forward to fixing on the way to a full resto-custom rebuild.
From the get-go I had problems with the drivers side door unlocking, the PO said that if you pushed in on the button while turning it that it worked, but I found that only worked off and on and got in the habit of unlocking the passenger side door instead most of the time. Unfortunately, the passenger door failed on me yesterday, it not only doesn't work now, but it acts like it isn't engaging whatsoever. Of course, this happened on a day the drivers side door didn't want to unlock at all either.
Despite advice not to use wet lube inside the cylinders, out of desperation I shot some lock lube that comes in a aerosol can and has a consistency like WD-40 into the drivers side door, and this worked to get it open for the moment, but it obviously wasn't working right, still requiring to be depressed at the same time as turning, feeling "not right" and not opening each time, requiring several attempts to get it to open when I tested it a few more times.
From research, I assumed that the pins had broken off, and I had anticipated this and had bought some 3" Chicago screws to do that repair that way, but when I pulled the handles, both had pins. So, I lubed them up with white lithium grease as much as I could from the outside, and since I had already shot them with the liquid lock lubricant, gave the insides as good a rinse as I could with that.
I then reinstalled them, swapping sides in the hope that part of the problem was wear on the lobe on the cylinder, but the one the one that been on the passenger side still doesn't work, feels like it won't engage, feels almost like it spins freely. The one that had been on the drivers side seems to reliably unlock the door, but only after 4-5 attempts before it does so and I'm nervous about it failing the rest of the way leaving me locked out.
At this point, I'd happily buy an aftermarket set of locking handles, if someone could steer me to a make/model that had a cylinder that would fit inside my 1967 handles. I suspect the cylinders are just worn out. I don't mind having to have a different key from the ignition or things not being original 1967, I just want the locks to reliably open!
I'd welcome other advice though.
Would having a new key cut maybe solve it? Is it possible the key is just worn?
I know the mechanism in the door is also '67 only. How likely is that the problems I describe are in that mechanism rather than the lock cylinder? And how hard is it to modify the 68+ mechanism to fit a 67 door?
Many thanks for your time and assistance!
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4658 Location: Whittier 90602
Posted: Wed Apr 29, 2020 7:31 am Post subject: Re: 1967 door lock woes, replacement? |
I don't believe changing your lock cylinders or door handles will help much with your problem(s).
As long as your key(s) will turn the cylinder(s) within the button(s) and rotates the pawl(s) up and down through full ~120 degree range then more likely the latches themselves are the issue.
You will have to use your powers of observation to better find out the root cause.
Since you know how to remove handles, take them off and look into the openings in the door. You should see the stamped steel U shaped receptacle within the latch that the door handle's lock pawl operates.
With the door closed (with window open so you don't get locked out) put your finger in the receptacle and try to push it up and down.
Pushed down it should lock and pulled up it should unlock.
Since the latch and it's parts are stamped steel they are subject to wear and bending.
I suspect they are bent or lacking lubrication thus causing the handles to do little or nothing.
If you are very observant and patient you may be able to determine if you can bend them back into shape and/or lube them up so they work more reliably.
Wolfsburg West has taken the trouble to modify 68-> latches to work on 67's but trouble is they are currently closed due to an abundance of caution.
Left...
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=151837015A
Right...
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=151837016A
Replacement involves taking out your window regulators so if you have any other issues with those or window channel felt/rubbers best plan would be to do all repairs/replacements at once.
Once repaired lube them every 3 months per VW...
Best of luck, hope this will help, _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
pgslaughter Samba Member
Posted: Wed Apr 29, 2020 7:42 am Post subject: Re: 1967 door lock woes, replacement? |
| I've got a 67 with very similar issues, and I have gone through much the same stuff that 61SNRF suggested. I've not been locked out, but it takes a couple turns up and down on the key to get the pawl to fully push the lock up. I had my cylinders redone by a locksmith who said they were in great condition, and the pawl looks good as well, not worn out in a way that you could see at least. It almost seems like the pawl opening is too big and the catch on the cylinder doesn't have enough leverage by the time it makes contact with the pawl, as I can push them up and down easily without the handle on the door. |
brian rogers Samba Member
Joined: April 14, 2002 Posts: 161 Location: Salt Lake City, Utah
Posted: Wed Apr 29, 2020 8:53 am Post subject: Re: 1967 door lock woes, replacement? |
‘67s are bastard one year only cars. These had 3 different versions of door handles.
A good source of information on ‘67s is
http://1967beetle.com/ |
Posted: Wed Apr 29, 2020 3:53 pm Post subject: Re: 1967 door lock woes, replacement? |
| 61SNRF wrote: |
Left...
Right...
Best of luck, hope this will help, |
Thanks everyone! Appreciate the insight and advice!
I was afraid it wasn't as simple as replacing the lock cylinders. I'll try lubing the mechanism and see if there's anything obvious I can bend a bit to make them work better until WW reopens.
My passenger window only wants to roll halfway down much of the time and takes a lot of force to go down all the way when it will it all, so I've got to tear into that anyway. Having all of that out of the way will probably make it easier to install new scrapers, felt, etc, which I also have to do.
No such thing as an easy fix! Every time I try and fix something it turns into a multi part project!
TheRide Samba Member
Joined: May 06, 2019 Posts: 293 Location: North Carolina
Posted: Wed Apr 29, 2020 5:06 pm Post subject: Re: 1967 door lock woes, replacement? |
This worked great on my ol 150k '67. |
67 Florida Deluxe Samba Purist
Joined: June 21, 2005 Posts: 7990 Location: Gainesville and Tampa, Florida
Posted: Thu Apr 30, 2020 6:27 pm Post subject: Re: 1967 door lock woes, replacement? |
| 67 Florida Deluxe wrote: |
| It's worn from use. The passenger and driver's side handles are the same. Remove the passenger side and swap with the driver's side. Lube before reinstallation and put a dab of grease on the top side of the little oblong "paddle" of the lock cylinder. Eazy, peazy. |
That was the first thing I tried. No dice. |
Posted: Thu Apr 30, 2020 7:35 pm Post subject: Re: 1967 door lock woes, replacement? |
| Medic Zero wrote: |
D'oh! Then someone already did it before you. It's the little oblong paddle that wears down from pushing up the locking mechanism, represented by the square metal piece it pushes up. Apparently, not much tolerance was built into the original design to account for wear. Aside from finagling something to reduce the clearance between the paddle and the square locking mechanism you may just have to resort to wiggling it like I do  _________________ -Kent (BaT "daleallen")
OG member of the '67 Posse
A few of my toys, past and present
'56 Oval, '66 KG Conv't, '67 21-Window, '67 Bug, '79 SuperVert, '55 Pre-A Continental |
AdventureKins Samba Member
Posted: Mon Dec 04, 2023 1:21 pm Post subject: Re: 1967 door lock woes, replacement? |
| OP what did you end up doing? I have a 67, both handles are doing the same thing. Thank you! |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11643 Location: Oregon
Posted: Mon Dec 04, 2023 7:14 pm Post subject: Re: 1967 door lock woes, replacement? |
| AdventureKins wrote: |
Have you tried swapping the door handles side to side?
I did this recently and achieved ZERO good results.
Next I'm gonna try cleaning the door latch mechanism to see if that helps the "No unlock" situation.
It that doesn't fix it. "Hello WW? My CC # is!"  _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
Posted: Mon Dec 04, 2023 7:28 pm Post subject: Re: 1967 door lock woes, replacement? |
| 67rustavenger wrote: |
It that doesn't fix it. "Hello WW? My CC # is!"  |
Unfortunately, both handles are doing the same thing. I've tried all the lubricants recommend on this site. Talking sweetly, threatening, negotiating, still won't cooperate. Bug 1 me 0
I am digging through books now to see if I dare take them apart myself. I'm in Tampa and called a couple of locksmiths. All recommend buying replacements and they can re-key. I sent an email to gabkey to see what he has. I guess even if I can work miracles, I should have a spare set for the next time.
I'm getting ready to replace my scrapers and have the doors all taken apart and was hoping to knock this out via easy (haha) or locksmith. |
Posted: Mon Dec 04, 2023 7:59 pm Post subject: Re: 1967 door lock woes, replacement? |
Swapping the handles side to side is easy.
The upside is. You are using the opposite side of the locking mechanism.
You usually lock the doors with the door button and unlock them with the key.
Swapping them uses the unused portion of the handle that never sees the use do to the lock button being used.
I hope that makes sense. _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Mon Dec 04, 2023 8:05 pm Post subject: Re: 1967 door lock woes, replacement? |
I hope that makes sense. |
I wonder if they've already been swapped and I'm just having operator error!! Especially that both are acting "strange". Oh I so hope that's the issue. Trying the opposite of normal door operations first thing tomorrow. Too many mosquitos out at the moment. |
Posted: Mon Dec 04, 2023 8:18 pm Post subject: Re: 1967 door lock woes, replacement? |
| Quote: |
It's only a little dengue fever. Lol!
Mine have already been swapped on both my 67's so I may have to go about the nasty task of removing the latching mechanisms and cleaning um up.
That's gonna suck!
We are having atmospheric rivers (shit loads of rain) here this week. You have to wait for the rain breaks to get anything done outside here. _________________ I have learned over the years.
Buy Once, Cry Once!
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11225 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Sun Dec 10, 2023 1:45 pm Post subject: Re: 1967 door lock woes, replacement? |
It has wear ... a couple of tips..
Squeeze the "C" or "U" shaped piece in the door together a little at a time. ...
The paddle wears on the door handle .. it looses the amount it needs to throw the lock..
ALSO.. you must be absolutely sure as you install the handle its not already pressing on the same C/U piece. If it is.. it wont allow the lock to move to lock/unlock correctly.
Sometimes it takes a combination of tweaking and filing to get the right combination.
| VOLKSWAGNUT wrote: |
Clean and lube is important...
A non worn handle paddle is important....
But a worn paddle can be faked, take a pair of needle nose pliers and squeeze the "C/U" tab inside the door a little tighter to form a tighter "C/U""..
Also be sure that it' isnt bent at an angle. The flat edge should align with the handle opening..
I've had my share of those "C/U"'s be bent down and cause issues..
Sometimes it takes a bit of finesse to get the "U" just in the right spot to offer both perfect unbiased lock and unlock movement.
They are very easy to bend with a screwdriver and something to protect the paint. Just visualize which way it needs to be bent to give the required reaction.
| Orvil1 wrote: |
Thanks, I'll try that. So how can a worn paddle be "faked"?. |
By
take a pair of needle nose pliers and squeeze the "U" tab inside the door a little tighter to form a tighter "U""..
If the end of the soft paddle doesnt quite have enough throw tightening the "U" will use the available paddle... hence faking it..
If you tweak and finesse the "U" in the appropriate direction, it will help the feature you need.
It doesnt take much "Adjustment" to make a note able reaction.
The other REAL important issue that arises with these is being sure when the handle is fully seated the paddle and foot CAN NOT be pressing inward on the "U". There must be a little space between the foot/paddle and the "U". If it is resting and pressing in on the "U" it will effect the unlocking and or locking with the key.
It is normal for these latches to wear and allow the "U" to move further and further outward until it begins to touch the handle foot.. then it begins to effect the designed features...
I like to dab some grease on the "U", install the handle and see if there is
interference.. If so some tweaking must be performed..
The idea is the paddle is just resting in the "U".. and nothing should really be touching until the handle button is pressed or the key is turned in its lock cylinder...
It is common to have to tweak the parts to make them match after years and years of use...
_________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
aviator8 Samba Member
Posted: Sun Dec 10, 2023 4:36 pm Post subject: Re: 1967 door lock woes, replacement? |
Similar issues here. I'm doing a full restore so I had the luxury of time and doors being fully stripped down. The door handles are one issue but the actuator mechanism can wear out as well. I posted some video documenting what I did that got things back into working order.
https://www.youtube.com/playlist?list=PL6r3FnacHZjBgtgYVyISPGfuc1l46Ypkp |
Posted: Sun Dec 17, 2023 9:14 am Post subject: Re: 1967 door lock woes, replacement? |
So I did the "squeeze" on the "U-C" shaped piece of my door lock mechanism. After a few tries, My door lock will lock/unlock with the key.
Is it perfect? No. But I can now unlock my door without fighting and doing the half depressed key twist dance in the grocery parking lot.
Thank you for the suggestion on the lock mechanism adjustment Ken. _________________ I have learned over the years.
Buy Once, Cry Once!
