ezytroopy Samba Member
Joined: February 25, 2016 Posts: 35 Location: Southern Tablelands
Posted: Sat Dec 23, 2023 1:25 am Post subject: Volkswagen Vehicle Section |
Hello all. I havent been on this forum for a long time. probably an silly question, but which section should i be using? I have just recovered a September 1957 beetle (big back window). I guess it would be the same as the 58 on as it has not got an oval window.
Cheers in advance |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22681 Location: NYC/Upstate/ROW
Posted: Sat Dec 23, 2023 4:54 am Post subject: Re: Volkswagen Vehicle Section |
Beetle 1958-1967
You might find it’s a split pan and body in which case you might need to play in the pre 1957
You can buy a ticket that covers both Fora here , though!
_________________ .ssS! |
Puppy67 Samba Member
Joined: October 04, 2022 Posts: 221 Location: Bristol, UK
Posted: Sat Dec 23, 2023 6:09 am Post subject: Re: Volkswagen Vehicle Section |
Had a similar dilemma with mine, an August 67 with lots of the "67 only" features, but mostly 68 model year, and a few parts unique to a couple of months of that year. I ended up in Readers rides for the main restoration and use the model year forums for year specific bits. It seems pre 67 aren't interested in the "fat chicks", but the post 68 is mostly supers, so I'm happy surfing the crossover. You may have to do the same, using pre 57 and post 58 depending on what you're after, and choosing post 58, Readers rides, or here for any bigger build thread.
I find similar with the Vintage speed section being 40hp and earlier. Okrasa interest seems limited to the 25/30hp based engines, so the TSV1800 engine I recently found and plan on re-building doesn't fit, but it also doesn't seem to really be big enough for interest in the Performance section. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69838 Location: Phoenix Metro
Posted: Sat Dec 23, 2023 1:45 pm Post subject: Re: Volkswagen Vehicle Section |
If you need help in both Fora there are people who will help, and the ignore function is perfect for those who have dull axes about what car is “kewl” _________________ .ssS! |
