harrymarlin Samba Member
Joined: June 07, 2018 Posts: 790 Location: Washington, DC
Posted: Tue Dec 19, 2023 10:40 am Post subject: Where to put Beetle tow lights? |
I'm looking to flat tow my Beetle, but I'm uncertain where to put the tow lights, as the magnets work best on a flat surface, which my convertible Beetle does not have a lot of.
Perhaps I should be using a different type of tow light? Are there types I can clip to my bumper, or put in the rear window?
Ideas on how I can ensure I don't scratch the paint? I would rather not modify the wiring in the car - although it would be great if I could just use the existing lights. _________________ -Harry
1967 Ruby Red Convertible Beetle ("Becky")
ISO Albuquerque "Imported Motors" dealership paraphernalia |
WM971252 Samba Member
Joined: September 10, 2004 Posts: 1783 Location: Franklin CT
Posted: Tue Dec 19, 2023 2:47 pm Post subject: Re: Where to put Beetle tow lights? |
Past Tow truck driver and have used "draglights" for years so I know. I have also moved many a bug included my own.
The easiest place to attach tow lights is on the rear sides just after the 1/4 windows (it gives you ears). It is best to have ones that have a pivot between the base and the light. To protect the paint first make sure your magnets are clean and stay clean. You can use stuff like wax paper or crash wrap (the white stuff on wrecks to cover the holes) but the easiest is a piece of paper (steno pads are a perfect size). |
bigdog1962 Samba Member
Joined: August 11, 2010 Posts: 1586 Location: Augusta, Georgia
Posted: Wed Dec 20, 2023 5:53 am Post subject: Re: Where to put Beetle tow lights? |
I bungee cord mine to the rear bumper and they have padding that keeps them from scratching. I bought them from Harbor Freight. _________________ Oprn wrote: I'm getting to the age that any self propelled woman (no wheel chair or walker) looks HOT!! Oooo! look at that Babe! She made it from the dining room all the way to the TV room without help!! Hubba, hubba!! |
esde Samba Member
Joined: October 20, 2007 Posts: 6394 Location: central rust belt
Posted: Wed Dec 20, 2023 6:01 am Post subject: Re: Where to put Beetle tow lights? |
I made a bar for the back of my vert as the magnetic lights kept falling off. It's just a length of uni-strut, with the lights mounted to each end. I've got some J-bolts that go down through it to hook the bumper bracket, and I throw a shop rag under it so it doesn't scratch the bumper. One light is plastic wrapped as the lens was busted after hitting there ground..
_________________ modok wrote:
slayer61 Samba Member
Posted: Wed Dec 20, 2023 8:19 am Post subject: Re: Where to put Beetle tow lights? |
| esde wrote: |
I have a home made rig just like that, that I use padded strut straps (cush clamps) and clamp it right to the roll cage in the buggy. _________________
| Cusser wrote: |
... Most folks are idiots when it deals with electrical !!! |
| 67rustavenger wrote: |
3/4 race cam? What's missing, one of the lobes?  |
Paul
'68 Manx clone... Sears??
RLR/Strange brakes
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
Garrett turbo
Tim's stage II turbo heads
MSD Box and distributor
Car Craft turbo header |
Posted: Fri Dec 22, 2023 9:38 am Post subject: Re: Where to put Beetle tow lights? |
Thanks, everyone for the pictures, comments, and ideas. I'll work on mine, and see what works best based on those! _________________ -Harry
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11220 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Mon Dec 25, 2023 3:19 pm Post subject: Re: Where to put Beetle tow lights? |
When I was building my Dune Buggy.. it was going to be flat towed more than any VW I've ever owned...
I created a fused umbilical from the truck trailer harness to the factory VW circuits to be able to use the VW mounted (1967) lights on the fiberglass body.
EXAMPLE
Trailer tail lights to VW tail
Trailer turns to left and right to VW left and right
Works fairly flawlessly... unless you have serious OCD issues.
The only hiccups it uses the rear turn signals of the VW for both turn and stop.
It also back feeds and illuminates the front turns with turn and stop.
IMO.. works well as side turn markers.
Also... depending on park light configuration... it can illuminate front parks via rear back feeding tail circuits trough the headlight switch..... again, works well for markers IMO.
All that can be worked around with some relays and or diodes.. but I prefer the simple. I now pre wire all my VWs this way.
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11591 Location: Oregon
Posted: Mon Dec 25, 2023 4:05 pm Post subject: Re: Where to put Beetle tow lights? |
| VOLKSWAGNUT wrote: |
EXAMPLE
I did the same 20+ years ago. I was towing my 69 Baja behind my pickup, and got tired of renting tow lights.
I don't remember the details, but there was a little experimentation involved to get the lights to work correctly and play well with the pickup trailer plug.
Now I have a set of bluetooth wireless tow lights that take all of 3 minutes to attach to the car and insert into the truck trailer plug. The lights are magnetic and rubber covers protect the paint. The whole package stores in a well padded plastic container. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
Posted: Tue Dec 26, 2023 4:25 pm Post subject: Re: Where to put Beetle tow lights? |
| Now I have a set of bluetooth wireless tow lights that take all of 3 minutes to attach to the car and insert into the truck trailer plug. The lights are magnetic and rubber covers protect the paint. The whole package stores in a well padded plastic container. |
What bluetooth wireless tow lights are you using? I would like to look into if that would work best for me, as well. _________________ -Harry
Posted: Tue Dec 26, 2023 4:41 pm Post subject: Re: Where to put Beetle tow lights? |
https://www.harborfreight.com/magnetic-led-wireless-towing-light-kit-58469.html?_br_psugg_q=towing
No wires taped to the car body. Just plug the sender into the trailer light socket and power up the rechargeable tow lights. _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Tue Dec 26, 2023 5:24 pm Post subject: Re: Where to put Beetle tow lights? |
Where do you attach them? _________________ -Harry
Posted: Tue Dec 26, 2023 5:40 pm Post subject: Re: Where to put Beetle tow lights? |
I have a sedan. I place them just aft of the rear quarter windows.
For a cabrio, you can make metal brackets that attach to the bumper support brackets.
Or you can mount the lights as close to the top of the rear fender arch on the body of the car as you can. _________________ I have learned over the years.
Buy Once, Cry Once!
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15604 Location: Deep in the 405
Posted: Wed Dec 27, 2023 12:04 am Post subject: Re: Where to put Beetle tow lights? |
Don't overthink this. Lay a 2x4 across the rear bumper and brackets. Used a couple Bunji cords to hold it down. Forget about the magnets and screw the lights onto the 2x4. Simple, cheap, and easy. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
OldSchoolVW's  Samba Member
Joined: July 03, 2020 Posts: 1596 Location: San Diego
Posted: Tue Jul 22, 2025 11:00 pm Post subject: Re: Where to put Beetle tow lights? |
Just wanted to throw my solution into this discussion for anyone working on this project …
The bumper brackets for ’68-’72 bugs already have these holes in them. (I’m not sure what they are intended for, but someone will enlighten us.)
I bought a couple of Simpson A311 angle brackets at Home Depot https://www.homedepot.com/p/Simpson-Strong-Tie-3-5.../100375057 , drilled holes in them to align with the holes in the bumper brackets and attached them with 1/4”x 1” bolts, fender washers, lock washers and wing nuts (quick and easy to mount).
The angle bracket can be twisted using using a pipe wrench after it is securely attached to the bumper bracket.
The towing lights have a magnetic base, which grabs the angle bracket pretty well, but I used ball bungees to help secure them.
Final result (the tow lights are about 6” higher than the taillights):
I secure the wiring to the passenger door handle and tow bar with velcro straps. It’s a pretty minimalist set up … everything fits in a shoebox when not in use and it’s quick and easy to install.
Hope this is helpful. _________________ Tom
"Following distance is proportional to IQ."
"It's okay to think."
"If you don't do it this year, you'll be one year older when you do." Warren Miller
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback |
