Wheel ID…
fastbacker
fastbacker is offline
PostPosted: Mon Jan 15, 2024 10:35 pm    Post subject: Wheel ID… Reply with quote
Looking to buy a set of 15” wheels for my 84. This stamping make sense…
VW
701 601 627B
fastbacker
PostPosted: Mon Jan 15, 2024 10:45 pm    Post subject: Re: Wheel id… Reply with quote
Or maybe…
701 601 027B
fastbacker
PostPosted: Mon Jan 15, 2024 10:53 pm    Post subject: Re: Wheel id… Reply with quote
Looks like they are from a eurovan. Will they fit?
campism
campism is offline
PostPosted: Tue Jan 16, 2024 6:52 am    Post subject: Re: Wheel id… Reply with quote
The wheels should also have the ET number stamped on them and I believe the Eurovan numbers (44-ish) indicate a fit that puts the centerline of the wheels too far inward for a proper Vanagon (37-ish) fit. I could be wrong but the correct info is out there.
Steve M.
Steve M. is offline
PostPosted: Tue Jan 16, 2024 10:51 am    Post subject: Re: Wheel ID… Reply with quote
Talk to Christpher at T3Tecnique.com
He is an expert at Vanagon wheel knowledge.
jimf909
jimf909 is offline
PostPosted: Tue Jan 16, 2024 11:48 am    Post subject: Re: Wheel ID… Reply with quote
Entering the part number shows wheels with an offset of ET51 so it probably won't fit (tires will rub on the UCA).
OP, you need five wheel dimensions to know if a wheel will fit a Vanagon:
Roughly:
- Wheel diameter:14" - 16" although fancy people make larger diameters work and sometimes look way cool.
- Wheel width: 6"* - 7.5" although different widths can be made to work
- Bolt pattern: 5x112 mm. Not variable
- Center hole diameter: >67mm(?)**
- Offset: ET 37ish, a lower number, say down to the low 20s, can work but a higher number moves the tire inward.
- You'll also need the correct lug nuts to match the wheels - they're not sll the same.
* Is 5.5" a standard width?
** I'm stretching my tired memory cells if the 67 mm figure is correct
As mentioned, Christopher has the snswers
- Jim
Butcher wrote:
Guilty as charged.
