Lock cylinder
SkinnyFat
SkinnyFat is offline
PostPosted: Sat Jan 20, 2024 10:38 am    Post subject: Lock cylinder Reply with quote
I want to learn how to set these cylinders. Any advice from all you badaz T3'rs? Anybody have experience with these?
Peas
SF
Howesight
Howesight is offline
PostPosted: Sat Jan 20, 2024 11:17 am    Post subject: Re: Lock cylinder Reply with quote
Google “Vanagon lock cylinder rekeying” for images. That will yield dozens of helpful images and articles.
'86 Syncro Westy SVX
MarkWard
MarkWard is offline
PostPosted: Sat Jan 20, 2024 1:49 pm    Post subject: Re: Lock cylinder Reply with quote
Without an assortment of tumblers it is going to be difficult to match an existing key. Actually swapping the tumblers is easy. If you want a sense of what is going on, insert the wrong key and you will see that the brass tumblers are not going flush to the cylinder.
If one is close, you might get away with filing it down. If one is not close, you could get away with removing it and the spring completely. I don't think the thieves are actually picking the lock.
Howesight
PostPosted: Sat Jan 20, 2024 5:17 pm    Post subject: Re: Lock cylinder Reply with quote
I agree, Mark. When I syncronized ( Wink ) the mis-matched locks in our rig, many of the swapped tumblers were close, but still needed filing to work smoothly.
DanHoug
DanHoug is offline
PostPosted: Sat Jan 20, 2024 5:50 pm    Post subject: Re: Lock cylinder Reply with quote
can buy the whole kit for all locks!
https://burleymotorsports.net/product/vanagon-door-handles-and-ignition-lock-cylinder-bundle/
or you can buy kits of VW lock wafers/reeds but dunno which style is for Vanagon.
-dan
www.thefixitworkshop.com
fxr
fxr is offline
PostPosted: Sat Jan 20, 2024 6:02 pm    Post subject: Re: Lock cylinder Reply with quote
Or get matching barrels for all five locks with four keys from Vancafe:
https://vancafe.com/lock-cores-w-4-keys-and-ignition/
Jim Crowther
Vespa GTS 300
ALIKA T3
ALIKA T3 is offline
PostPosted: Mon Jan 22, 2024 2:03 pm    Post subject: Re: Lock cylinder Reply with quote
These barrels are aftermarket new ones, which use a AH key profile I believe, as opposed to the N profile of the Vanagon.
I'm not sure the wafers are the same...
SkinnyFat
PostPosted: Mon Jan 22, 2024 8:59 pm    Post subject: Re: Lock cylinder Reply with quote
What if I have 6 doors and the ignition.... Shocked
Five and the ignition work but the other door is just not working.
Razz
SF
MarkWard
MarkWard is offline
PostPosted: Tue Jan 23, 2024 8:29 am    Post subject: Re: Lock cylinder Reply with quote
Pull both front door handles off. Remove the tumbler barrel from each. When you insert the key into the working barrel, you will notice the brass tumblers are all flush with the barrel.
Now insert the key into the barrel that does not work. You will see which tumblers are not correct because they are not flush. You might be able to mix and match the tumblers in the barrel to improve how well they work. For the ones that don't, a file or deleting will get you there.
The above details are for when you don't have an assortment of brass tumblers to try.
erdonline
erdonline is offline
PostPosted: Tue Jan 23, 2024 8:59 pm    Post subject: Re: Lock cylinder Reply with quote
Same wafers for the AH (and previous iterations like HV, VB, etc.) and the Vanagon N cylinder.
'85 Vanagon Westfalia
'84 Vanagon 7-passenger
'98 Mexican air-cooled Beetle
ALIKA T3
ALIKA T3 is offline
PostPosted: Tue Jan 23, 2024 11:16 pm    Post subject: Re: Lock cylinder Reply with quote
Thank you for the info Cool Cool
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Wed Jan 24, 2024 3:35 pm    Post subject: Re: Lock cylinder Reply with quote
Razz
SF
Convert to power doorlocks, so you'll rarely if ever need to use a key for anything except the ignition.
Casey--
'01 Weekender --> full camper
y u rune klassik?
syncrodoka
syncrodoka is offline
PostPosted: Wed Jan 24, 2024 9:22 pm    Post subject: Re: Lock cylinder Reply with quote
That looks like the slider lock cylinder. You can rekey it easily, there is a thread here that covers it. If this is an aftermarket handle and the original N profile key blank doesn't fit into the cylinder then rekeying it won't get you any closer to using 1 key for the entire vehicle.
