The poor 64 - father/son project
Page: Previous  1, 2, 3, 4
buntist
buntist is offline
PostPosted: Sat Jan 08, 2022 10:44 am    Post subject: Re: The poor 64 - father/son project Reply with quote
Really quick work! Front and rear clip were real snappy work. makes me feel like i have been dragging my feet way too much!
Nice Project!
Sjstretch
Sjstretch is offline
PostPosted: Sat Jan 08, 2022 10:10 pm    Post subject: Re: The poor 64 - father/son project Reply with quote
[quote="racerock"]
Sjstretch wrote:
The 2332 has been through the test fitting stage, engine tin all modified to fit better, etc… Time to pull it back apart and put it together for real.
Did you use a new doghouse shroud? If so what brand it is and did it hold up?
If you went doghouse did you also change to the larger fan inside?
If you went doghouse did you do anything to allow more air into the engine compartment (no air ducts on engine lid)?
It is a Concept-1 dog house shroud for the type 4 cooler. Two extra rows of cooling. (I had two new type 4 coolers from a package buy). Not sure it will actually make a difference. The shroud does have internal fins.
Going to try and run it without an external cooler, but I will add one if temperatures say I need it.
It has a welded and balanced fan that is the correct width for the dog house shroud.
I have the deck lid off-set/open at the bottom. Air ducts in the engine lid might still happen.
Sjstretch
PostPosted: Sat Jan 08, 2022 10:12 pm    Post subject: Re: The poor 64 - father/son project Reply with quote
Nice Project!
Thank you! It was a lot of work…
Sjstretch
PostPosted: Sat Jan 08, 2022 10:32 pm    Post subject: Re: The poor 64 - father/son project Reply with quote
More setup/progress…working my way toward the break in stand. Need to order some parts, work on venting, fuel lines, lower engine tin sleds, etc…
Ignition will be a crane HI-6N setup when finished.
Sjstretch
PostPosted: Fri Jan 21, 2022 4:16 pm    Post subject: Re: The poor 64 - father/son project Reply with quote
Little side project for running an engine outside of the car. Idea came from the vwjawbreaker YouTube channel
Sjstretch
PostPosted: Mon Dec 26, 2022 3:43 pm    Post subject: Re: The poor 64 - father/son project Reply with quote
New “project” for the bug.
It was missing with “w” spring (made one), had broken spot welds (welded), was missing the shift knob (empi on there for now) and the main wire broke taken the shifter apart (made one).
It did come with the original bottom plate. Those are missing a lot of times..
Fun little project…
Sjstretch
PostPosted: Tue Jan 30, 2024 7:36 am    Post subject: Re: The poor 64 - father/son project Reply with quote
Got the trans back from an upgrade. Setup with 4.12 and 3.08/2.06/1.32/0.89. Welded, hardened keys, 4 gear super diff modified for better oiling, etc…
Trans back in the car…
Sjstretch
PostPosted: Tue Jan 30, 2024 7:40 am    Post subject: Re: The poor 64 - father/son project Reply with quote
Engine back in the car.
Working on a filter mount and oil lines. Fram filter was just in my parts bin…I will find something better to actually use.
Sjstretch
PostPosted: Wed Apr 23, 2025 3:47 pm    Post subject: Re: The poor 64 - father/son project Reply with quote
Ordered and installed a new fuel sender from cip1 and it looks a lot like the original 1964 VDO.
75-911S
75-911S is offline
PostPosted: Thu Apr 24, 2025 5:55 am    Post subject: Re: The poor 64 - father/son project Reply with quote
What size is your crankshaft pulley? (7 inch?). If so where did you get it?
75-911S
75-911S is offline
PostPosted: Thu Apr 24, 2025 5:56 am    Post subject: Re: The poor 64 - father/son project Reply with quote
What size is your crankshaft pulley? (7 inch>). If so where did you get it?
Sjstretch
PostPosted: Thu Apr 24, 2025 2:13 pm    Post subject: Re: The poor 64 - father/son project Reply with quote
That is a 7” pulley, for sand seal, from CB performance.
Eric&Barb
Eric&Barb is offline
PostPosted: Thu Apr 24, 2025 7:12 pm    Post subject: Re: The poor 64 - father/son project Reply with quote
Need to loosen up the axle boots and rotate them so the seam is at or close to horizontal. The seams do not flex well, so will crack up the boots if left in the vertical position you have them now.
In Stereo, Where Available!
75-911S
75-911S is offline
PostPosted: Fri Apr 25, 2025 5:18 am    Post subject: Re: The poor 64 - father/son project Reply with quote
Thanks for the pulley info.
Page 4 of 4
