Barndoor brake Reservoir ?
Page: Previous  1, 2
Kasten68
Kasten68 is offline
PostPosted: Wed Mar 15, 2023 2:35 am    Post subject: Re: Barndoor brake Reservoir ? Reply with quote
My NOS one for reference
VW über alles !
RockStock
RockStock is offline
PostPosted: Wed Mar 15, 2023 8:12 am    Post subject: Re: Barndoor brake Reservoir ? Reply with quote
Cool
Any sign of seal 25?
Looking for a source for that lid rubber seal 24, if anyone has one
-StockRocks-
j.pickens
j.pickens is offline
PostPosted: Wed Mar 15, 2023 10:35 am    Post subject: Re: Barndoor brake Reservoir ? Reply with quote
Two gaskets stacked? Thats unusual.
BeaterBarndoor wrote:
Red Fau Veh wrote:
PostPosted: Wed Mar 15, 2023 5:10 pm    Post subject: Re: Barndoor brake Reservoir ? Reply with quote
I'm wondering if it's metal too since it's not black
djfordmanjack
djfordmanjack is offline
PostPosted: Thu Mar 16, 2023 12:53 am    Post subject: Re: Barndoor brake Reservoir ? Reply with quote
I wonder if this has something to do with helping to undo the cap. The aluminium caps are known to really freeze solid. Add brake fluid and moisture and a rubber seal. 2 layers of seals may help in reducing friction.
That NOS master cyl. must be one of the ultimate BD/WB collectibles ! It should be displayed at a museum !!! It is just so strikingly beautiful ( along with the design of the original ATE boxing) Exclamation Embarassed
(total nerd mode).
62 Dickholmer, custom color Seeblau L360
RockStock
PostPosted: Thu Mar 16, 2023 1:36 am    Post subject: Re: Barndoor brake Reservoir ? Reply with quote
I think it looks cool too 🙂
What’s people’s advice to stop the lid seizing?
-StockRocks-
LAGrunthaner
LAGrunthaner is offline
PostPosted: Thu Mar 16, 2023 2:23 am    Post subject: Re: Barndoor brake Reservoir ? Reply with quote
100% agree, stunning, get that into a display case Cool
(total nerd mode).
Maui Roadsters VW Logo
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote:
djfordmanjack
PostPosted: Thu Mar 16, 2023 2:32 am    Post subject: Re: Barndoor brake Reservoir ? Reply with quote
In general I like to use Liqui Moly copper grease ( or any other brake caliper copper grease) just make sure you just put it only on the cap and cup threads, and under no circumstance, let it get into/ mix it with brake fluid ( alcoholic based DOT3)!
You can lube the rubber seal with any good conventional brake cup assembly paste ( I like to use og ATE).
Or you can do away with it all and used DOT 5.0 silicone brake fluid. I have done it many times and works great, but you have to make sure to either clean out/flush the entire system thoroughly from old DOT3 brake fluid, or assemble with all completely new brake parts ( cylinders, hoses and lines) to be safe.
It is great ! especially when using rare and precious NOS components, and on cars that are mostly garaged and rarely driven. From my own experience I have to say it is recommended to also replace DOT5.0 every 5 years or so, because, on an open circuit ( all our old master cylinders have a breather cap), dampness can and will get into the system as well, and with silicone, it will not mix with the brake fluid, but instead collect at the lowest points ( wheel cylinders). I like to use Harley Davidson DOT5.0 silicone.
Kasten68
Kasten68 is offline
PostPosted: Thu Mar 16, 2023 4:30 am    Post subject: Re: Barndoor brake Reservoir ? Reply with quote
RockStock wrote:
Cool
nope, only the # 24 seal
VW über alles !
RockStock
PostPosted: Mon Feb 12, 2024 3:50 pm    Post subject: Re: Barndoor brake Reservoir ? Reply with quote
Thank you both
RockStock wrote:
Cool
Maybe this is gasket 25…card
Part number 611 377
(Remains of rubber gasket 24 on the right?)
-StockRocks-
djfordmanjack
PostPosted: Tue Feb 13, 2024 2:35 am    Post subject: Re: Barndoor brake Reservoir ? Reply with quote
that absolutely makes sense now. the cardboard will go between the cap and breather shield. When the shield and rubber sticks to the reservoir, the cap can still be undone.
From the looks of the crumbled pieces, it rather looks like rubberized cork than pure rubber, maybe. Both gaskets could be easily cut from Klingerit and rubber (cork) sheets.
RockStock
PostPosted: Tue Feb 13, 2024 8:50 am    Post subject: Re: Barndoor brake Reservoir ? Reply with quote
But the diagram doesn’t show it in that order?
Cover c/w splash guard 23
then
Rubber gasket 24
then
Card gasket 25
The splash guard (breather shield) doesn’t want to separate from my cap.
I also have a couple of caps with no splash guards. Makes me wonder if some came without splash guards.
-StockRocks-
djfordmanjack
PostPosted: Tue Feb 13, 2024 10:11 am    Post subject: Re: Barndoor brake Reservoir ? Reply with quote
I realized before that the order of parts shown on the diagram was different. But even VW wasn't perfect all the time.
We have no way of knowing about ongoing improvements on the cap. whether they started w or w/o the shield and/or card gasket.
Using common sense, the cap must seal against the reservoir with a rubber seal, as it sees fluid splashing all the time. the cap needs to be vented anyways, as the m/c would not work otherwise ( in case of brake fluid loss, the reservoir has to provide new fluid into the m/c bore, which will not work against a vacuum on top). even with a breather shield inside the cap, eventually some fluid mist or drops will get up and between the actual cap and shield. The cap has to be sealed against the shield, or the fluid will not drain back in the reservoir, but drain around the rubber seal and bleed down through the cap threads, making an awful mess of the m/c and pedal pan underneath.
This is just talking from technical common sense. Not according to any VW literature.
I wonder if the breather shield is sealed/stuck/glued inside the cap, or maybe locked with a few peens? Or maybe just seized because of corrosion?
djfordmanjack
PostPosted: Tue Feb 13, 2024 10:25 am    Post subject: Re: Barndoor brake Reservoir ? Reply with quote
Maybe the card gasket was simply replace with the rubber seal ?
I checked Mercedes parts catalogs for similar year, and although it has a different reservoir, it has a similar illustration and say that one is replacement for the other. parts 31 and 31a
https://www.niemoeller.de/de/ponton/w120-mercedes-180/B010/422601
edit, found these pics in my files (originally from TS ad). obviously an NOS cap kit. does not have the card gasket and shield separates from cap.
Page: Previous  1, 2
Page 2 of 2
