Matra Tools w/photos
67rustavenger
67rustavenger is offline
PostPosted: Sun Dec 24, 2023 1:17 pm    Post subject: Re: Matra Tools w/photos Reply with quote
I picked up a Matra 310 at the NW Bug Run a couple years ago.
It's not in as good of condition as Fishynos72.
It has been painted blue and the handle is not og. But the 310 is serviceable.
Unfortunately, all but one of my engines are 8 dowel. So I can only use it on my 1600 SP.
Curious what the value of the Matra 310 is?
I can clean mine up and repaint it. If I know the closest match to the Matra tool color is.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
Fishynos72
Fishynos72 is offline
PostPosted: Mon Dec 25, 2023 10:14 pm    Post subject: Re: Matra Tools w/photos Reply with quote
Not the easiest of questions to answer. Demand will dictate the price.
Given you said you can use it with a 1600, I'd suggest it's 310A for 40hp use and up.
A 310a would be for most workshops, even most enthusiasts a more useful version of the tool. the 310 non a being limited to only 36hp usage.
Based on 3 sold samba listings from 310A- pricing was between 150- 250 euro.
Assuming they sold for the asking price.
They were in varying states of condition, usually a thick coat of whatever paint scheme suited it's workshop décor.
Post some photos here and you might have someone reach out.
Collector of all things Volkswagen, Hazet and Matra.
1957 old speed fun
https://youtu.be/8A7JyvR-eiA?si=q7Rxfxrspk6zCd6p
2005 Caddy panel van chaos
https://youtube.com/playlist?list=PL2xEOS4ROOAQkVmo-vvYzYY-rGMv3ZkHL&si=cnzqpamsnBr5HlMH
BulliBill
BulliBill is offline
PostPosted: Tue Dec 26, 2023 12:49 pm    Post subject: Re: Matra Tools w/photos Reply with quote
nshaddox wrote:
VW293. Mine I think is too narrow for later bearings by memory but it’s been a while since I’ve torn down a 3.88 pinion shaft so I’m not sure. I’ll have to dig up a later style pinion bearing and make sure the bracket clears.
Edit: added socket and different view.
"If" you ever end up getting the piece of this tool on the right in the lower illustration made locally, I'd be interested in one. A buddy recently gave me the VW 293 device on the left side used to hold the cluster, but the socket-like "do-hickie" was long gone. Anyway, put me on the list "if" you make any of that socket-like part of this tool... Thanks!
Bill Bowman
I'm looking for these license plate frames from old Volkswagen dealerships for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help!
Fishynos72
PostPosted: Tue Jan 09, 2024 7:06 pm    Post subject: Re: Matra Tools w/photos Reply with quote
Hello again.
Have been using my vw214 recently, bought a new Ludwig Hunger reamer for it and decided I'd had enough of the water damaged storage box.
I need to work on the finish as the original paint is smoother and more "powdery""
1957 old speed fun
BulliBill
PostPosted: Tue Jan 09, 2024 10:29 pm    Post subject: Re: Matra Tools w/photos Reply with quote
Nice work Sir! Collecting those tools is fun enough, but to go for the outfield fence by restoring the cool German boxes some of these tool sets come it is awesome!
I have that same set and although I've never used it (yet) it's very cool and I was delighted when I got it! I've always wondered if I have all the pieces of it...
Bill
Fishynos72
PostPosted: Tue Jan 09, 2024 10:52 pm    Post subject: Re: Matra Tools w/photos Reply with quote
A new level of obsession indeed.
There's a German VW tool group on Facebook with similar restorations happening. To an even greater level of detail
Post up photos of the kit you have. Many knowledgeable members here and someone should be able to advise if your missing any pieces
1957 old speed fun
Fishynos72
PostPosted: Sun Feb 11, 2024 3:55 am    Post subject: Re: Matra Tools w/photos Reply with quote
Figured a good bump for this thread as I've been putting a 36hp together this weekend, and I got to crack out a bunch of tooling, some of them Matra.
There's more on my 1958's thread if anyone is interested in having a look.
1957 old speed fun
henry roberts
henry roberts is offline
PostPosted: Sun Feb 11, 2024 8:12 pm    Post subject: Re: Matra Tools w/photos Reply with quote
Beautiful!
BulliBill
PostPosted: Fri Feb 16, 2024 3:37 pm    Post subject: Re: Matra Tools w/photos Reply with quote
Here is the VW 214 set that I have... It might be missing a part or two or have too many collars or parts, who knows? It may be a updated kit that started out as a #214 kit, and may have been supplemented later with updated later pieces making it an #214"A", "B" or ? set? Here are a few photos:
Bill
Fishynos72
PostPosted: Fri Feb 16, 2024 3:45 pm    Post subject: Re: Matra Tools w/photos Reply with quote
Almost identical to the assortment in my kit.
Definitely has some double ups and later additions, but it's hard to know what originally came in the kit as the tool listings suggest it's sparse so the dealership could order what they need.
It's actually a very well thought out tool for the job, and you appear to have everything there to straighten rods and ream new bushes.
Reamers can still be purchased new through Ludwig Hunger in Germany.
A nice addition is the bush removal tool.
1957 old speed fun
BulliBill
PostPosted: Sat Feb 17, 2024 6:52 am    Post subject: Re: Matra Tools w/photos Reply with quote
Hey, thanks for the reply about my #214B tool set. I've never used it yet. It would be cool to search YouTube to see if there is any videos of someone using the #214 tool set to both check rods for straightness, ream bushings and then using it to straighten out a slightly bent connection rod! Do you know the tool number (or have a photo) for the bushing removal tool you suggested. I'll have to keep an eye out for that one! Thanks!
Bill
Fishynos72
PostPosted: Mon Feb 19, 2024 1:43 pm    Post subject: Re: Matra Tools w/photos Reply with quote
Vw 212a
1957 old speed fun
BulliBill
PostPosted: Wed Feb 21, 2024 12:17 pm    Post subject: Re: Matra Tools w/photos Reply with quote
Holy crap! Thanks "Fishynos72" for the photo of that small end bushing puller! I just checked my tool collection and found that I actually have #212A !!! I thought it looked a bit familiar...
Bill
Fishynos72
PostPosted: Wed Feb 21, 2024 12:26 pm    Post subject: Re: Matra Tools w/photos Reply with quote
Excellent Bill.
Super simple tool, but it works very well.
1957 old speed fun
Herbie62
Herbie62 is offline
PostPosted: Fri Mar 22, 2024 4:20 am    Post subject: Re: Matra Tools w/photos Reply with quote
Hello Guys,
I 've just bought this one. It looks like a 118/30 but has different writings (3487 47-30, WB 84/50) with a 3/4" end. Anyone has infos on it ?
Fishynos72
PostPosted: Fri Mar 22, 2024 9:20 pm    Post subject: Re: Matra Tools w/photos Reply with quote
That's a love bit of kit, and if you paid the 40euro listed price it was a good bargain.
it's of zero help- but I see the WB and think Warren&brown as they make Torque wrenched- maybe they did a calibration on it at some point?
I would suggest the handle stampings would be to label it for a shop, or even a trolley or set number across multiple work stations.
Keep in mind Matra used to make general high quality tooling not just VW group tooling.
WB might also stand for something in German or French that wouldn't even cross my mind.
1957 old speed fun
Herbie62
Herbie62 is offline
PostPosted: Sun Mar 24, 2024 1:54 pm    Post subject: Re: Matra Tools w/photos Reply with quote
Thanks for you answer. I can't see any meanings in French for WB
But it seems I found another tool with WB stamping :
Fishynos72
PostPosted: Sun Mar 24, 2024 1:58 pm    Post subject: Re: Matra Tools w/photos Reply with quote
Ok. Perhaps a vehicle brand WB as the Volkswagen tools have VW numbers
1957 old speed fun
vwtoby64
vwtoby64 is offline
PostPosted: Sun Jun 16, 2024 10:59 am    Post subject: Re: Matra Tools w/photos Reply with quote
This is a new old stock (NOS) factory tool kit designed for maintaining early VW industrial engines. Most of the tools still have their Cosmoline coating. This one is a rare version designed exclusively for 25hp and 36hp engines. These kits contain the most likely needed tools for field service of early industrial engines.
This one is earlier than the ones that have been pictured in the gallery. The others have additional tools for 40hp and newer engines as well. It is stamped 1965 inside the lid versus 1966 like the others. I am not sure if this was a Matra part number, or a production year?
Toby from Averres and later Avery's Air Cooled. After 23 years currently working for Weyerhaeuser Longview Lumber.
Collector of all things Hazet.
For guidance on Hazet toolkits: Hazetguide.com
1964 Ruby red sedan
1962 Yukon yellow convertible
2018 Black Tiguan SEL Premium
1500king
1500king is offline
PostPosted: Wed Jun 19, 2024 1:27 pm    Post subject: Re: Matra Tools w/photos Reply with quote
grind it off.
Paint code is RAL7031. Earlier tools had RAL7032.
Fishynos72 wrote:
Anywho, finally after nearly 5 years of ownership/ procrastination, my matra 308 is free from the 'C' channel someone thought needed to be welded to it.
Here is is when I first bought it, and took off most of the blue paint.
Notice the 'C' channel welded to the side.
Here's how it stands currently. (HAHAHA get it?)
Does anyone know how I can remove the remaining welded sections of 'C' channel? I'm trying not to ruin the original steel, and given the welded bit is nearly 10mm thick, a grinder may not be the most efficient way to do it. But at this point a whole lotta grinding disks might be my only option. Ideally I need a way to cut it down, and finish off with the grinder.
Page 8 of 9
