Nodnol Samba Member
Joined: October 09, 2023 Posts: 158 Location: North Carolina
Posted: Sat Feb 17, 2024 9:31 am Post subject: Testing a coil |
Hi I just need some help with testing my ignition coil, not Sure if I did it right
since i not to familiar with this multimeter, any help is welcome
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 4166 Location: Georgia
Posted: Sat Feb 17, 2024 10:50 am Post subject: Re: Testing a coil |
Well, to start with, it’s not turned on. _________________ Volkswagen!
(Compression 8.7:1) |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79687 Location: Sneaking up behind you
Posted: Sat Feb 17, 2024 11:40 am Post subject: Re: Testing a coil |
jeffrey8164 wrote: |
Well, to start with, it’s not turned on. |
D'oh _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Nodnol Samba Member
Posted: Sat Feb 17, 2024 11:57 am Post subject: Re: Testing a coil |
Yea I know that but I don't know what setting to use |
APPLEGREENVW Samba Member
Joined: November 30, 2003 Posts: 2557 Location: Seekonk,Massachusetts USA
bsairhead Samba Member
Joined: October 08, 2008 Posts: 4508 Location: viroqua wi.
Posted: Sat Feb 17, 2024 1:45 pm Post subject: Re: Testing a coil |
It's 200 Ohm but its always safe to start at the highest and work back. My Simpson 260 has a 100 value. |
Nodnol Samba Member
Posted: Sat Feb 17, 2024 2:34 pm Post subject: Re: Testing a coil |
From positive to negative it's 4.0 measured at 200 and at + or - to center it's 7.37 measured at 20 k |
Franklinstower Samba Member
Nodnol Samba Member
Posted: Sat Feb 17, 2024 11:37 pm Post subject: Re: Testing a coil |
Alright now I know that the coil is good, next test is the condenser, what's the general resistance for it? |
jinx758 Samba Member
Joined: October 04, 2014 Posts: 1037 Location: half a bubble from plumb
Posted: Sun Feb 18, 2024 12:53 pm Post subject: Re: Testing a coil |
Howdy ...
Testing a condenser, aka capacitor :
*Remove insulated female connector (or ring)& (usually green) wire from the negative side of coil
*Touch the end of wire to bare metal immediately.
This will discharge the stored voltage & render it harmless.
VERY IMPORTANT !
*Turn on DVOM & place on resistance (Ohms) function.
About 20K will do (what I use on my Fluke3).
*Hold red lead on end of wire & black lead on condenser body.
The display should jump UP in value, stopping around 19 or so & then show 1.0 .
This shows the condenser is able to charge.
*Place DVOM on DCvolts & hold leads opposite way.
The value on the display should jump DOWN.
This shows the condenser is able to discharge.
Simplified version but there ya go.
Technically the condenser holds a charge while the points are open & discharges when the points close.
It gives a jump start to the coil to help it ramp up quickly;
same principle as a stereo amplifier or a fan motor in an HVAC system uses a capacitor to help during peak usage needs - ie heavy bass or at start up.
Hope this helps ... stay safe
jinx
PS :
Some people just switch the leads with it in Ohms mode.
This is NOT the correct procedure & could harm the circuits over time.
I was dealing with battery chargers that ramped up to 49amps with 480/3phase AC when initialized.
SAFETY FIRST ! _________________ " It's not valuable unless you learn something from an experience. " Henry Ford
It's not unlike the same difference ...
My Craigslist rescued 100 footer :
1971 Standard Bug
1776cc dual port
034 distributor
38mm EGAS Carburetor |
Nodnol Samba Member
Posted: Sat Feb 24, 2024 11:24 am Post subject: Re: Testing a coil |
Howdy ...
Ok, here we go.
I've never tested a condenser while on the car but not sure if that matters.
A few thoughts :
*Maybe the batteries aren't very potent in DVOM. They're either 3volt (AA batteries times 2 @ 1.5volts each) or 9volt.
*The circuits in that DVOM aren't sensitive enuff (read cheap).
*The engine is grounded through the transaxle strap. If that isn't shiny clean perhaps it could sway the reading.
The "M" on DCvolt setting stands for millivolt.
I think yours has a capacitance setting. It's opposite the 200M setting. It's all by itself & the symbol is a 2part or broken plus sign. This is also known as a diode tester. On an alternator test the magic # is 3.4-ish. Maybe store this in memory for future use.
Your test showed a falling reading from a discharged condenser - good. The charging reading did not cut off - not good.
A U-tube vid (or a member on here) cut one open & it shows a foil strip with an insulator on one side covered in a mystery waxy type semifluid. The length & width determined its values.
Condensers are cheap.
The Eschlin brand from Napa are usually OK.
Did you do ALL the tests in the video posted by APPLEGREENVW ?
Keep at it, you got this ... stay safe
jinx _________________ " It's not valuable unless you learn something from an experience. " Henry Ford
1971 Standard Bug
1776cc dual port
034 distributor
Nodnol Samba Member
Posted: Sat Feb 24, 2024 4:14 pm Post subject: Re: Testing a coil |
I fully tested the coil and it's good, went ahead and removed the condenser so I can test it again, and now it's not giving any readings. Not sure what I'm doing wrong but Il probably just get a new one |
Joined: April 27, 2002 Posts: 6810 Location: Pentwater, Michigan
Posted: Sun Jul 20, 2025 1:06 am Post subject: Re: Testing a coil |
Look for NOS new old stock not brand new. Echlin Standard brands or, if NOS Bosch. Do not buy a newly manufactured condenser. _________________ Roads Scholar
Member# 2059 |
runamoc  Samba Member
Joined: June 19, 2006 Posts: 6212 Location: 37.5N 77.1W
Posted: Sun Jul 20, 2025 8:11 am Post subject: Re: Testing a coil |
Here is a schematic of a coil. To really test one, use a 'pulsing' relay and actually 'see' the spark
_________________ Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires |
Blandyp Samba Member
Posted: Mon Jul 21, 2025 11:18 am Post subject: Re: Testing a coil |
jinx758 wrote: |
Howdy ...
I think yours has a capacitance setting. It's opposite the 200M setting. It's all by itself & the symbol is a 2part or broken plus sign. This is also known as a diode tester. |
That one that looks a bit like a capacitor symbol is a battery symbol - to test 9V and 1.5V batteries.
The diode test is the one with the arrow and bar across the tip of the arrow at about 5 O'clock in the photo.
Not that this helps with testing the coil, but y'know... _________________ Idling insignificantly |
Posted: Tue Jul 22, 2025 2:27 pm Post subject: Re: Testing a coil |
Quote: |
Not that this helps with testing the coil |
The measurement of a coil's inductance is henries.
How the coil on your car works: Counter Electromotive Force = is a phenomenon that occurs in electrical circuits when an inductive load, such as a motor or coil, is powered off. As the current in the circuit decreases, the magnetic field generated by the load induces a voltage in the opposite direction of the applied voltage. This induced voltage is the back EMF, and it can significantly affect the circuit’s behavior and make a spark across the plug electrodes.
The coil is nothing but a long wire. Measuring it with a VOM induces a DC voltage in the coil and gives the reading in ohms meaningless. All it really does is 'tell' you if the coil is shorted or open. _________________ Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
