Rear Seat Covers on Bay Frame and Pads
[email protected]
rohweder@hbci.com is offline
PostPosted: Sun Feb 25, 2024 10:52 am    Post subject: Rear Seat Covers on Bay Frame and Pads Reply with quote
Would new split rear seat covers fit full length Bay rear frame and pad
Lind
Lind is offline
PostPosted: Sun Feb 25, 2024 11:10 am    Post subject: Re: Rear Seat Covers on Bay Frame and Pads Reply with quote
The bay rear seat is about 3/4" narrower than a split bus seat. The padding and cover are not as much of an issue as the top brackets to the body. I just modify the top frame by widening it, and don't bother with the bottom frame.
Wanted:
Clara Premium Member
Clara is offline
PostPosted: Sun Feb 25, 2024 11:56 am    Post subject: Re: Rear Seat Covers on Bay Frame and Pads Reply with quote
You can generally order the seat covers in the fabric you want to fit the frames you have. Ask the place you order seat covers from.
I mean, ideally you have the correct frames for the bus, but sometimes you don’t.
Or you can modify the frames.
Or get covers that fit your frames.
