esde Samba Member
Joined: October 20, 2007 Posts: 6354 Location: central rust belt
Posted: Tue Dec 05, 2023 6:29 am Post subject: Drilling a 36hp crank and flywheel for 8 dowels |
I have a stock 36hp crank which I would like to convert to 8 dowels. My understanding is that the 8 dowel pattern used on 356 Porsche is the upgrade. I'm looking all over for a drill jig for this pattern but not finding anything, does one exist and could anyone provide a link? The ones for the later 8mm dowel pattern are plentiful but will not work
If needed I may use a 356 flywheel to make my own jig, but I'd rather just buy the jig and spend my time elsewhere..
Many thanks. SD _________________ modok wrote:
56samba Samba Member
Posted: Wed Dec 06, 2023 1:49 am Post subject: Re: drilling a 36hp crank and flywheel for 8 dowels |
I was in the same situation recently during the restoration of my Okrasa engine and couldn't find a drill jig.
Using a 356 flywheel as a jig worked surprisingly well. Subsequent reaming of the holes is recommended. |
Robert Chambers Samba Member
Posted: Wed Dec 06, 2023 10:07 am Post subject: Re: drilling a 36hp crank and flywheel for 8 dowels |
How about using a 356 or 912 metal flywheel gasket as a pattern? _________________ '63 OG 117 Herbie Replica
'56 Euro Oval Deluxe
'52 Standard Zwitter
'63 OG 117 |
esde Samba Member
Posted: Wed Dec 06, 2023 3:54 pm Post subject: Re: drilling a 36hp crank and flywheel for 8 dowels |
Robert Chambers wrote: |
How about using a 356 or 912 metal flywheel gasket as a pattern? |
Probably not as accurate/ easy as I would like. It's a lot more work to find the center of a hole in the gasket than the actual flywheel. I may use a flywheel, and get some 6mmx8mm bushings. This way I can drill through the flywheel with a 6mm pilot. Then remove the flywheel and bushings, drill to the final size and ream. _________________ modok wrote:
Posted: Wed Dec 06, 2023 5:27 pm Post subject: Re: drilling a 36hp crank and flywheel for 8 dowels |
I have the flywheel. You can use it if needed. I plan to do the same thing to my crankshaft. _________________ '63 OG 117 Herbie Replica
'63 OG 117 |
IN2VWS Samba Member
Joined: January 29, 2006 Posts: 2550 Location: Australia
Posted: Sun Mar 03, 2024 12:18 am Post subject: Re: drilling a 36hp crank and flywheel for 8 dowels |
_________________ ( ⫏ ⫐ )
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹ ¹⁹⁵⁸
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³ |
TomSimon Samba Member
Posted: Sun Mar 03, 2024 2:24 am Post subject: Re: drilling a 36hp crank and flywheel for 8 dowels |
Very nice! Replaceable hardened drill bushings, a piece of professional tooling. And that patina! _________________ 2-time NASA Pro Racing Champion, Bonneville 130 Club and 150 Club Memeber, BRS Pro Gas racer |
esde Samba Member
Posted: Sun Mar 03, 2024 4:46 pm Post subject: Re: drilling a 36hp crank and flywheel for 8 dowels |
Amazing.
So, it has a VW number. Did any VW have an 8 dowel crankshaft from the factory? I'm wondering what the factory made the tool for?
Is one of the pins offset? Maybe it was to repair a crankshaft that had damaged holes? _________________ modok wrote:
RolandD Samba Member
Joined: January 15, 2017 Posts: 279 Location: Menomonee Falls, Wis
Braukuche Samba Member
Posted: Tue Mar 05, 2024 8:59 am Post subject: Re: drilling a 36hp crank and flywheel for 8 dowels |
There’s no need to eight dowl it unless you are building an engine capable of running the same high RPMs as a Porsche 356. In that case why wouldn’t you buy a 69.5 stroker crank that’s already eight dowled? _________________ Go Reds! Smash state!
Retirement is here!
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
1989 Westfalia |
esde Samba Member
Posted: Tue Mar 05, 2024 3:03 pm Post subject: Re: drilling a 36hp crank and flywheel for 8 dowels |
Braukuche wrote: |
There’s no need to eight dowl it unless you are building an engine capable of running the same high RPMs as a Porsche 356. In that case why wouldn’t you buy a 69.5 stroker crank that’s already eight dowled? |
That's not really accurate.
Drag race starts and hard shift are what usually oval out the dowel holes, but cars that are driven hard are well known to do it also. Especially. cars that are driven with a lot of downshifting/ compression braking. The 4 little 6mm pins are barely adequate for 36hp.
Of course at hight rpm, there is more mass (30lbs of flywheel and clutch assembly!) and that inertia is more likely to kill the pins, but it does happen even on stock street driven cars. _________________ modok wrote:
Iowa Mark Samba Member
Posted: Tue Mar 05, 2024 5:48 pm Post subject: Re: drilling a 36hp crank and flywheel for 8 dowels |
esde wrote: |
Braukuche wrote: |
Of course at hight rpm, there is more mass (30lbs of flywheel and clutch assembly!) and that inertia is more likely to kill the pins, but it does happen even on stock street driven cars. |
I have to agree. Way back in 1968 my 1957 stock bug spun the flywheel. I was just your typical teen-age boy driving up and down Grand Ave on a friday night. No, honestly! |
RWK Samba Member
Posted: Wed Mar 06, 2024 7:41 am Post subject: Re: drilling a 36hp crank and flywheel for 8 dowels |
Could you drill the 4-6mm pins to 8mm? PM me, I could possibly build a drill jig, do you know the bolt circle, or radius from center, or pin center to center? _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
esde Samba Member
Posted: Mon Mar 11, 2024 5:50 am Post subject: Re: drilling a 36hp crank and flywheel for 8 dowels |
RWK wrote: |
Could you drill the 4-6mm pins to 8mm? PM me, I could possibly build a drill jig, do you know the bolt circle, or radius from center, or pin center to center? |
To jump from 6 to 8mm, there would be .5mm between the dowels and the inside/ outside edges of the crankshaft, probably not enough material. To oversize the existing pins, you could use 1/4" (6.32mm), 7mm, or 9/32 (7.14mm)
I have started to make a jig, based on the pattern that DPR uses. If it works well, I will share the details. _________________ modok wrote:
Posted: Mon Mar 11, 2024 6:09 pm Post subject: Re: drilling a 36hp crank and flywheel for 8 dowels |
Please do share the geometry details.
Roland |
Joined: June 24, 2015 Posts: 874 Location: Rialto. CA
RWK Samba Member
Posted: Fri May 24, 2024 7:45 pm Post subject: Re: drilling a 36hp crank and flywheel for 8 dowels |
I have the 231b I believe it is for the 36, it has a bolt hole radius of 19mm, 6mm drill bushings, someone got a crank to measure? I don't!
The add says those are 231c and I see it has 8mm drill bushings, they are probably for larger 40 and up which is a 20.5mm hole radius, so measuring would be prudent.
I'll post pics of mine at some point, one of which has PN covered in patina  _________________ 73 Type 181
63 Type 113
RWK Samba Member
Posted: Sun May 26, 2024 5:59 pm Post subject: Re: drilling a 36hp crank and flywheel for 8 dowels |
Drill jig I picked up at swap, 6mm holes on a 19mm radius, 36HP 4 each drill bushings, for hole size (5.75mm) and follow up 6mm reamer, and jig for flywheel and crank.
Liners are 10mm ID, switch bushings around for each operation drill and ream, little handles make it easy, unlike production style jigs.
63 Type 113
Posted: Mon Dec 02, 2024 5:06 pm Post subject: Re: drilling a 36hp crank and flywheel for 8 dowels |
On a damaged flywheel, I was able to measure and confirm the 19mm radius of the bolt circle. The offset pin measured very close to a 5 degree shift.
Can anyone confirm or discredit these numbers before I make a drill fixture?
Roland |
dangerous Samba Member
Joined: December 05, 2017 Posts: 4 Location: Australia
Posted: Sat Jan 11, 2025 3:41 pm Post subject: Re: drilling a 36hp crank and flywheel for 8 dowels |
This is what I found and matched a VW crank to an aftermarket flywheel. I used a 38PCD (19 radius as you said) and one dowel is off-set 5 degrees. |
